With the Aristos I liked the 10 F & 20 R I had.
With my new wheels (Neuspeed RS10) I think an 8 in the rear is enough i've been looking at 42DraftDesign spacers.
#1
I'm about to buy spacers for my R and I'm not sure what I should get...
The car has stock suspention.
20mm for the back?
10-15mm for the front?
What do are you guys running?
Thanks.
Also I have stock wheels on the car.
#2
#4
#5
Am I going to need to buy the bolts for the spacers? I was just looking on ecstuning and theyhave the spacers for sale with the bolts and without the bolts. There's a $25 difference between with or without so just checking to see if I need to purchase the bolts or not.
Thanks.
#6
of course you'll need bolts for the spacers.
Good technical info at the bottom of the page on 42DD's site.
#7
#8
currently 10mm spacers for the front and 20mm for the rear! i like it
#9
Bluewater Performance has spacers available that come with extended lug bolts (in either conical or ball seat, iirc). I think Forge is the manufacturer. PM either Gabe or Andrew for pricing and available sizes.![]()
#11
Length....if you use your stock lugs with a 10mm spacer, you *might* catch 2 threads which is nowhere near what you need.
#12
#13
#15
If you're still running Aristos then go with ball seat. If you have aftermarket wheels, most will take a conical seat.
#16
im running 20mm in the rear. no suspension work on stock wheel setup!
pictures don't do justice but in person compared to before it looks a lot better!
i took off the 10mm spacers on the front. There H&R 5x100 HubCentric. Hope this helps in any way
support and like my VeeDub Motion Facebook Page. Thanks!
http://www.facebook.com/pages/VeeDub...59957820756642
with spacers...
pic without spacers...
pic of 10mm spacers
#17
10mm front 20mm rear /thread
