Results 1 to 18 of 18
Thread: Spacers
    Feb 28th, 2012
    Minnesota
    .:R32
    04-17-2012 11:31 AM #1
    I'm about to buy spacers for my R and I'm not sure what I should get...
    The car has stock suspention.
    20mm for the back?
    10-15mm for the front?
    What do are you guys running?
    Thanks.
    Also I have stock wheels on the car.
  2. Member nkgneto's Avatar
    Dec 4th, 2004
    West Burbs, IL
    04 VW R32 TRed, 05 Jetta Wagon Blk/Orange
    04-17-2012 11:33 AM #2
    With the Aristos I liked the 10 F & 20 R I had.
    With my new wheels (Neuspeed RS10) I think an 8 in the rear is enough i've been looking at 42DraftDesign spacers.
    Opti-Coat applications in the Chicago Area! * United Motorsport Flashing in the Chicago Area *
    Quote Originally Posted by webcrawlr View Post
    Luis has been the most responsive person I've dealt with in the VW world. There's a lot of big name shops that could learn a lot from his customer service skills.
    Quote Originally Posted by Polz View Post
    All of the above four points. Plus I have received great service from Jeff and from Luis at Automobile Day Spa.
    Feb 28th, 2012
    Minnesota
    .:R32
    04-17-2012 11:35 AM #3
    okay, and also any good brand name spacers to go with?
  4. Member Cspence's Avatar
    Nov 23rd, 2008
    Meriden, CT
    '09 CC VR6 / '97 Jetta TDI / '87 GTI VRT (Soon)
    04-17-2012 12:23 PM #4
    Quote Originally Posted by nkgneto View Post
    This.
    My new wheels I run 10 in the rear (19x8 ET27) but thats kinda cuz thats what I had...
    Feb 28th, 2012
    Minnesota
    .:R32
    04-17-2012 12:44 PM #5
    Am I going to need to buy the bolts for the spacers? I was just looking on ecstuning and theyhave the spacers for sale with the bolts and without the bolts. There's a $25 difference between with or without so just checking to see if I need to purchase the bolts or not.
    Thanks.
  6. Member nkgneto's Avatar
    Dec 4th, 2004
    West Burbs, IL
    04-17-2012 12:47 PM #6
    of course you'll need bolts for the spacers.
    Good technical info at the bottom of the page on 42DD's site.
  7. Member Cspence's Avatar
    Nov 23rd, 2008
    Meriden, CT
    04-17-2012 07:04 PM #7
    That's $25 that'll save your life and many others...
  8. Member vw-tim's Avatar
    Sep 14th, 2010
    California
    04-17-2012 10:01 PM #8
    currently 10mm spacers for the front and 20mm for the rear! i like it
  9. Member loosefalcon's Avatar
    Sep 19th, 2009
    Colorado Springs, CO
    No Haldex :(
    04-17-2012 10:07 PM #9
    Bluewater Performance has spacers available that come with extended lug bolts (in either conical or ball seat, iirc). I think Forge is the manufacturer. PM either Gabe or Andrew for pricing and available sizes.
    Feb 28th, 2012
    Minnesota
    .:R32
    04-18-2012 03:10 AM #10
    What's the difference in the 2 lug bolts?
  11. Member Cspence's Avatar
    Nov 23rd, 2008
    Meriden, CT
    04-18-2012 07:32 AM #11
    Length....if you use your stock lugs with a 10mm spacer, you *might* catch 2 threads which is nowhere near what you need.
    Feb 28th, 2012
    Minnesota
    .:R32
    04-18-2012 11:24 AM #12
    Quote Originally Posted by loosefalcon View Post
    I ment to say the difference between conical or ball seat?
    Will either one work or?
  13. Member Cspence's Avatar
    Nov 23rd, 2008
    Meriden, CT
    04-18-2012 12:07 PM #13
    Quote Originally Posted by nickmn View Post
    OEM is ball seat, most aftermarket is conical
  14. Member
    Feb 28th, 2012
    Minnesota
    .:R32
    04-18-2012 12:54 PM #14
    So which should I get in your preference?
  15. Junior Member choppeR32's Avatar
    Apr 24th, 2010
    Rhode Island
    MKIV BMP .:R32
    04-18-2012 03:59 PM #15
    If you're still running Aristos then go with ball seat. If you have aftermarket wheels, most will take a conical seat.
  16. Member
    Apr 17th, 2011
    California
    2004 VW .:R32
    04-19-2012 01:30 AM #16
    im running 20mm in the rear. no suspension work on stock wheel setup!
    pictures don't do justice but in person compared to before it looks a lot better!
    i took off the 10mm spacers on the front. There H&R 5x100 HubCentric. Hope this helps in any way
    support and like my VeeDub Motion Facebook Page. Thanks!
    http://www.facebook.com/pages/VeeDub...59957820756642
    with spacers...
    IMAG0402
    IMAG0406
    pic without spacers...
    IMAG0372
    IMAG0313
    IMAG0165
    pic of 10mm spacers
    IMAG0397
  17. Member TurboREX's Avatar
    Aug 6th, 2006
    NYC
    .:Ruined
    04-19-2012 08:41 AM #17
    10mm front 20mm rear /thread
    Quote Originally Posted by Pasquallies View Post
    your car is looking like when you pull down a girls underwear and find out it is freshly shaved
  18. Member
    Feb 28th, 2012
    Minnesota
    .:R32
    04-19-2012 02:18 PM #18
    Anyone running more than 20mm in the back?
