VWVortex.com - 1998 Supercharged Jetta $6500obo **Mechanic Owned/Maintained**
    Results 1 to 10 of 10
    Thread: 1998 Supercharged Jetta $6500obo **Mechanic Owned/Maintained**
    1. Member 2PointGoGoGo's Avatar
      Sep 11th, 2005
      Blackhawk
      2008 Sierra, 2014 Tiguan, 2000 Cabrion
      04-17-2012 05:29 PM #1
      Looking for $6500obo
      1998 Jetta GLX VR6
      Engine:
      128K Miles
      VF engineering Stage 2 supercharger kit
      DSR 256 Cams
      A/C delete with VF Idler Pulley Kit
      SAI deleted 42 Draft plug
      Techtonics Down Pipes
      Test Pipe
      Techtonics 2.5 Catback
      2.9 Manifold
      Chains were done at 100K
      New Plugs
      New Coilpack
      New Oil Pan
      Catch Can
      New Valve Cover Gasket
      New Throttle body Gasket
      Evolution Motorports Phelonic Spacer
      Oil Changed ever 1500miles since blower
      Vortech Rebuilt the Blower about 1000 miles ago
      All VF Engineering Motor Mounts
      42 Draft Y-Water Pipe
      C2 Motorsports Software
      New 3" aluminum intake pipe (Tig welded professionally)
      4" MAF
      New Air Filter
      New Front and Rear Oxygen Sensors
      New Intake Air Temp Sensor
      New Coolant Temp Sensors
      Suspension and Brakes:
      H&R Ultra Low Coilovers
      Zimmerman Cross Drill Brakes all around
      New Rear Wheel Bearings
      New E-brake Cables
      Trans:
      LW Steel Flywheel
      South Bend Stage 1 Clutch
      Peliquin Diff
      AMS Oil Transfluid
      DieselGeek Short Shifter
      Interior:
      Beige Leather interior
      MOMO Steering Wheel
      VDO pilot series boost gauge in 42 draft gauge plate
      Exterior:
      VR front lip spoiler
      Smoke E-codes (headlights)
      Smoked side markers
      exterior modifications are very minimul and probably not noticed by most.
      Also Have and will go with car:
      Corbeau Seat
      Schroth Harness
      Car just passed Emmissions last week and is daily drive. Car is very Reliable and fun to drive. All work was done at Dub Werks (where I work) over the last 6 years I have owned the car. Car has never been tracked or raced. Thank you! Sorry for the old Pictures. the Dyno was done prior to the exhaust, intake and new software.
      Any additional photos I currently have of the vehicle can be found here.
      http://s14.photobucket.com/albums/a3...r/1998%20Jetta
    2. Member 2PointGoGoGo's Avatar
      Sep 11th, 2005
      Blackhawk
      04-23-2012 04:35 PM #2
      TTT
    3. Member 2PointGoGoGo's Avatar
      Sep 11th, 2005
      Blackhawk
      05-09-2012 01:04 PM #3
      TTT
    4. 05-10-2012 06:31 PM #4
      Have any videos of it running? I am not looking for hard pulls, just normal engine speeds/highway speeds?
    5. Member 2PointGoGoGo's Avatar
      Sep 11th, 2005
      Blackhawk
      05-10-2012 06:43 PM #5
      Unfortunately not. where are you located maybe you can just swing by dubwerks.
    6. 05-10-2012 08:02 PM #6
      I am Dow/over in st. Louis.
    7. Member 2PointGoGoGo's Avatar
      Sep 11th, 2005
      Blackhawk
      05-11-2012 10:17 AM #7
      dang thats kind of a haul. well let me know if you get some time.
    8. Member 2PointGoGoGo's Avatar
      Sep 11th, 2005
      Blackhawk
      05-12-2012 10:43 AM #8
      TTT
    9. n00b ejurgen's Avatar
      May 10th, 2010
      Chicago, IL
      1998 golf Golf GTI VR6 (Ginster)
      08-04-2012 10:45 AM #9
      Hi there, just want to know if this beautyis still for sale or not?
      thanks!
    10. Member SciroccoMan 11's Avatar
      Sep 21st, 2008
      97 vr6 Jetta ,85 stock Scirocco,85 2.0 16v Scirocco
      08-06-2012 11:51 PM #10
      Where are you located? Im about two hours west of Chicago...
      85 stock Scirocco
      85 2.0 16v Scirocco
      97 Vr6 Jetta
      AUTOHAUS
