Results 1 to 23 of 23
Thread: *** GROUP BUY - Density Line Dogbone Mounts & Engine/Transmission Mounts ***
  1. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    B7 Audi A4 2.0T FSI Quattro
    04-17-2012 05:35 PM #1
    Group Buy Status: CLOSED
    We're hosting a VWvortex Group Buy on our Density Line Dogbone Mounts and Engine/Transmission Mounts for the MkV & MkVI! The Group Buy will be open until 05/11/2012, or until 25 people area added to the list, whichever comes first.
    To get on the list, please PM me with the following information:
    • Your Full Name
    • Your Email Address
    • Your Shipping Address
    • Mounts Desired
    • Engine (2.0T/VR6/2.5L)
    These mounts are in-stock and ready to ship! Once your payment is received, the order will ship in 1-2 business days.
    Density Line Dogbone Mount Pair
    034Motorsport's Density Line Mounts are the new standard in comfort and performance. Our mounts are redesigned with performance in mind, and manufactured from high-durometer rubber for increased performance and durability, without sacrificing comfort. Density Line Mounts are void-free and fluid-free, eliminating the slop associated with the factory mount.
    The Density Line Dogbone Mount Pair is manufactured from 60 durometer rubber, which is approximately 35% stiffer than stock. Since the mounts are also void-free and solid-filled, the resulting mount is approximately 85% stiffer than stock.
    The result is greatly reduced drivetrain slop, crisper shifting, and minimal wheel hop, without any significant increase in noise, vibration, or harshness (NVH) inside of the cabin. These mounts are a completely re-engineered performance solution, not just inserts for use with the factory mount.
    Features:
    • Manufactured from 60 Durometer Rubber with Void-Free Construction
    • Reduced Drivetrain Slop
    • Decreased Engine Movement Under Load
    • More Direct Power Transfer
    • Improved Shifting Feel
    • Complete Drop-In Replacement of Factory Mounts
    • Sold in Pairs
    Fitment:
    • 2006 - 2013 Audi A3 (8P)
    • 2006 - 2013 Audi TT / TTS / TTRS (8J)
    • 2005 - 2009 Volkswagen Eos / GLI / GTI / Jetta / R32 / Rabbit (MkV)
    • 2010 - 2013 Volkswagen Eos / GLI / Golf / GTI / Jetta / R (MkVI)
    Installation Instructions:
    Warranty:
    • 1 Year Limited Replacement Warranty (If you encounter any issues with our products outside of the warranty period, we will work with you to provide a resolution.)
    Retail Price: $60
    Group Buy Price: $45
    Street Density:
    The Street Density Engine Mount Pair is manufactured from 60 durometer rubber, which is approximately 35% stiffer than stock. Since the mounts are also void-free and solid-filled, the resulting mount is approximately 60% stiffer than stock. The cast aluminum mount bodies have also been redesigned to cope with the added stress of spirited driving.
    The result is greatly reduced drivetrain slop, crisper shifting, and minimal wheel hop, without any significant increase in noise, vibration, or harshness (NVH) inside of the cabin. These mounts are a completely re-engineered performance solution, not just inserts for use with the factory mounts.
    Track Density:
    The Track Density Engine Mount Pair is manufactured from 80 durometer rubber, which is approximately 90% stiffer than stock. Since the mounts are also void-free and solid-filled, the resulting mount is approximately 120% stiffer than stock. The cast aluminum mount bodies have also been redesigned to cope with the added stress of spirited driving.
    The result is a locked-down drivetrain, solid shifting, and virtually no wheel hop. Track Density Mounts will cause a noticeable increase in noise, vibration, and harshness (NVH) inside of the cabin. These mounts are a completely re-engineered performance solution, not just inserts for use with the factory mounts.
    Features:
    Manufactured from 60 Durometer (Street Density) or 80 Durometer (Track Density) Rubber with Void-Free Construction
    Complete Drop-In Replacement of Factory Engine/Transmission Mounts
    Sold in Pairs (One Engine Mount & One Transmission Mount)
    Fitment:
    • 2006 - 2013 Audi A3 (8P) - 2.0T FSI / 2.0 TSI / 3.2L 24V VR6
    • 2006 - 2013 Audi TT / TTS (8J) - 2.0T FSI / 2.0 TSI / 3.2L 24V VR6
    • 2005 - 2009 Volkswagen Eos / GLI / GTI / Jetta / R32 (MkV) - 2.0T FSI / 2.0 TSI / 3.2L 24V VR6
    • 2010 - 2013 Volkswagen Eos / GLI / Golf / GTI / R (MkVI) - 2.0 TSI
    Warranty:
    Retail Price: $240
    Group Buy Price: $195
    High-Durometer Rubber vs. Polyurethane:
    Density Line Mounts are manufactured from high-durometer rubber instead of polyurethane for a number of reasons. While vulcanized rubber mounts are more expensive to prototype due to increased complexity of manufacturing and high initial tooling costs, rubber is inherently better than polyurethane as a damping medium for mounts and bushings.
    Rubber is able to deal with stress under both tension and compression, while polyurethane mounts rely on the damping medium to be effective only under compression. Rubber is also excellent in shear, where polyurethane is ineffective, making it ideal for control arm bushings that apply a shear force to the bushing during articulation.
    Rubber does not pack and wear like polyurethane does, which ultimately results in a long-lasting part with consistent performance and comfort.
    Street Density vs. Track Density:
    We recommend Street Density Mounts for all daily-driven vehicles. They offer a significant increase in performance with a minimal increase in NVH transfer into the cabin. Track Density Mounts are recommended for purpose-built track cars, or those who do not mind significantly increased engine noise and vibration in the cabin.
    Feel free to contact me via email or PM if you have any questions!
    The List:
    1. BlueJetta2.0T (Paid)
    2. lour32 (Paid)
    3. DOQ fastlane (Paid)
    4. getaJettamkv (Paid)
    5. NoRegrets78 (Paid)
    6. Candy Vhite (Paid)
    7. tmw2442 (Paid)
    8. coolstorm92 (Paid)
    9. quietA3guy (Paid)
    10. DerekH (Paid)
    11. gugu1981 (Paid)
    12. Zaytri (Paid)
    13. Peteski (Paid)
    14. nafljhy (Paid)
    15. dubman6 (Paid)
    16. Logical (Paid)
    17. CC Deville (Paid)
    18. mk5rabbit07 (Paid)
    19. Brokedgli (Paid)
    20. bryans2k (Paid)
    21. CobraKing (Paid)
    22. Ironhorse (Paid)
    23. Evo V (Paid)
    24. xtravbx (Paid)
    25.
  2. Member intent_vr6's Avatar
    Sep 13th, 2006
    Eagan MN
    06 GLI
    04-17-2012 05:42 PM #2
    when will this end?
  3. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    04-17-2012 05:46 PM #3
    Quote Originally Posted by intent_vr6 View Post
    when will this end?
    Whoops, that's an important detail to leave out...
    The Group Buy will remain open through 05/11/2012, or until the list fills to 25 people, whichever comes first.
  4. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    04-18-2012 12:35 PM #4
    All PMs responded to!
    Dec 19th, 2007
    Mount Airy MD
    mk3 gti 2.0l, mk3 golf, MK5 GTI
    04-18-2012 03:23 PM #5
    Will this effect the cars alignment?
  6. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    04-18-2012 04:30 PM #6
    Quote Originally Posted by s0eur0 View Post
    The engine/transmission mounts will not affect the car's alignment.
    If you install the dogbone by dropping the subframe, just mark it accurately and put everything together properly, and you're good to go.
  7. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    04-19-2012 08:18 PM #7
    Thanks for the orders!
  8. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    04-20-2012 05:27 PM #8
    Plenty of room left on the list! We can also split up the engine/transmission mount pair if you're just looking for one or the other.
  9. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    04-23-2012 02:24 PM #9
    I have updated the list. Thank you for the orders!
  10. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    04-24-2012 07:18 PM #10
    Still plenty of time to get in on this Group Buy!
  11. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    04-26-2012 03:24 PM #11
    Bump! Thank you for the orders and feedback!
  12. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    04-27-2012 07:21 PM #12
    Friday bump!
  13. 04-30-2012 12:07 AM #13
    I'm interested in the dog bone mount, do you have replacement rubber for the 2.5l trans and engine mounts? Also, will you ship to canada? Ontario specifically.
  14. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    04-30-2012 02:00 PM #14
    Quote Originally Posted by DerekH View Post
    If your 2.5L uses the 3-bolt style transmission mount, the n our Density Line one will work for you.
    We don't have anything for the engine side on the 2.5L, though.
  15. 04-30-2012 07:19 PM #15
    Quote Originally Posted by Laszlo@034 View Post
    Bummer, ok i guess i have to rebuild them with poly :S
    Sign me up for the dogbone mount though. How do we do you want me to pay? Any extra shipping charges for sending them to ontario?
  16. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    04-30-2012 07:42 PM #16
    PM sent!
  17. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    05-01-2012 05:34 PM #17
    Bump! Still have plenty of spots left on the list!
  18. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    05-04-2012 04:02 PM #18
    Bump! One week left to get in on this Group Buy, and 10 spots left on the list!
  19. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    05-08-2012 08:03 PM #19
    Thanks for all of the orders! I'll get the list updated tomorrow. Should still have a couple of sports left!
  20. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    05-09-2012 06:20 PM #20
    Only 2 spots left! Who wants them?!
  21. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    05-10-2012 12:42 PM #21
    One spot left! Thanks for the orders!
  22. Member nunumkv's Avatar
    Jul 5th, 2010
    Tampa, Florida
    2005 MKV Jetta 2.5L, 2012 GLI
    05-10-2012 12:50 PM #22
    I pmed you
    UroTuning
    GulfCoast€urosTampa's Home for Euro Enthusiasts!
  23. Banner Advertiser Laszlo@034's Avatar
    Apr 16th, 2012
    Fremont, CA
    05-12-2012 02:06 PM #23
    This Group Buy is now CLOSED! Thank you to everyone who participated and provided their feedback.
    Feel free to post or PM me with any questions.
