Results 1 to 4 of 4
Thread: FS;;;; MK2 GTI VR6 PROJECT.....$2400 obo
  1. 04-17-2012 07:05 PM #1
    Hello everyone, I have this project that I no longer want to finish. Just got me a german right hand drive gti with a vr6 swap in it. What this gti has is as follows: 98 getta glx vr6 motor with engine harness and all cab harness, mk3 fuel tank with all fuel lines, mk3 5 lug conversion with jetta glx front and rear struts, rear k frame from getta glx, front cross member out of a 93 passat vr6, and radiator support from a 93 passat 16 valve for 98 jetta radiator install. Car is also ready for mk3 dash swap. I have complete dash swap parts. A/C heater core all installed in car. Vr6 tranny also in car. Has been completely gone through. All gears have been chriogenically frozen for extended life wear. I also did arp bolt kit for the differential so it does not grenade in transmission housing when rivets break. Vehicle also has, factory power mirrors which are also heated. I have all original wiring harness to wire these direct to fuse box. Car also has 97 gti front and back seats, already installed. It also has stock 98 jetta wheels, also known as begotti wheels. Car was set up to be smogged ref. It has all smog necessity items installed ready for smog ref inspection. All you need to do is install underdash harness and board. Drive to smog ref and your ready to go. Hurry up and come get your summer project. PM me for pics of vehicle. Can't figure out how to load up into site. PS, forgot one thing....tranny has TDI 5th gear install for that HWY gas mileage. New clutch, new flywheel and new pressure plate
  2. 04-21-2012 12:21 AM #2
    price drop 2000
  3. Junior Member bambojetta's Avatar
    Aug 10th, 2011
    Cali
    Jetta coupe
    04-21-2012 04:56 PM #3
    How do you plan to sell a car with no pics.... also theres no right hand drive they made in germany. pics
  4. Member 1.8T_GoLF's Avatar
    Jan 22nd, 2008
    Cali
    _89 E30 / 89 MkII Golf / MkIV Golf gls 1.8T / 96 MkIII Vr Jti / MkIV 20th #BMP Gti
    04-23-2012 03:55 AM #4
    pics please 626 757 0241
