slicks should not be stored outdoors in the winter and as they get older they loose the rubber will harden
check mickey thompsons site for faqs on tire storage
#1
My slicks were in the garage all winter... does the cold screw up the tire compound? My 60 foot times were crap this last weekend, which was the first race of the season. Also, I noticed that they got A LOT worse as the day went on and everything heated up, almost a 15 degree swing.
Did the track get greasy or do my slicks need replaced.
#2
11.91@121 mph. slicks, pump gas, full exhaust vrt v.2.0
12.09@127 mph. 205 40 17 falkens, pump gas, full exhaust vrt v.3.0
member since 2002 -banned several times
#3
every winter i bring the slicks in bags and store them in my basement next to the heat.
67mm - vrt
mad slow
#4
any tire should not be left in plastic bags, it dries them out, they need to breathe.
tire totes are convinent and breathable
#5
Now a days you can even go with a drag radial and not have to worry as much...We run a 32 ford in the 9s at english town for 3 seasons now and never have even taken the tires off the car..BTW the car is all motor and runs on pump gas![]()
#6
Not drag race tires, but I store mine in the basement over the winter to keep them from freezing. I also bag them.
Chris
2007 GTI 16v, 4 door, 6sp (well really that one is Brandy's)
2004.5 Passat Wagon 20v, 1.8t, 4mo, 5sp
1986 GTI 8v road racer - DIYAutoTune.com
#7
In a word yes, but to different degrees on different cars Slick size vs hp vs weight vs launch technique.Some cars depend more on the adhesion than others.
How much are you losing on your 60 ft? Everything else about your time-slip seems to be close to average for the E.T. vs speed.
I can still produce high 1.6s on three year old slicks that sit in the garage through the winter.
