Results 1 to 7 of 7
Thread: Warm stall workaround
    Nov 23rd, 2010
    chicago
    04-18-2012 01:38 AM #1
    I don't know why I didn't think of this earlier... simply drive with the heat on level one. I turn the dial to defrost. No more warm stall! LOL. It works if you know you're going to be stopping and starting the car a lot.
  2. Member 2003gtivr62.8liter's Avatar
    Aug 31st, 2009
    Mt. Sterling, Ohio
    2003, VW GTI VR6 24v
    04-23-2012 03:16 PM #2
    Just go to ur local dealer and have them flash it. Then u won't have to do that anymore.
    2003 VW GTI VR6 24v; ABD C.A.I., Big Bore Intake, Techtonics Tuning 2.5" Highflow DP, Cat, Cat-Back w/ Borla Muffler,Neuspeed Power Pulleys; Stage 1+ Clutch Kit w/ LW Flywheel; TT 264/260 Cams; UM Tune; ECS Short Shift, Forge Side2side, 42dd shift bushings, BFI Stage 2 Mounts,H&R Rear Sway Bar, Neuspeed Upper Strut Bar, FK Rear Upper Stress,KW V2 Coils, Yellow Optima, Pirelli A/S, OE Euro Tails, Raxles...so on
    Nov 23rd, 2010
    chicago
    04-23-2012 05:15 PM #3
    i went to the dealer and they had no idea what i was talking about.
  4. Member 2003gtivr62.8liter's Avatar
    Aug 31st, 2009
    Mt. Sterling, Ohio
    04-23-2012 06:26 PM #4
    Thats strange.
  5. Member 93audi90's Avatar
    Jan 8th, 2005
    Buffalo, Ny
    2003 24V GLI
    04-26-2012 11:05 AM #5
    same problem once in a while went to the dealer to get a re-flash and they tried to tell me i had a vacuum leak i said no and left, it doesn't happen enough for me to be bothered by it supposedly if you get your car chipped the problem will go away
  6. Member Wolfschnee's Avatar
    Jun 14th, 2009
    North Jersey
    RIP: 2004 VW vr6 gti : 2003 vw vr6 gti almost as good as the last one
    04-27-2012 07:56 PM #6
    I called a dealler a while back. thought i heard their was a recall for it and wanted to make sure the previous owner took the car in for any. I asked if their was a recall for the warm stall. I was told no. Found out it was a bulletin out for the warm stall called back and the guy finally figured it out and said bring it in. I aked the price and it was like $300.
    Seeing how most flashes fix it for the same price i and i don't want to spend $300 i said screw it
  7. Junior Member
    Feb 12th, 2012
    Where the Navy sends me...
    '03 Jetta GLI, '93 Corrado SLC
    04-27-2012 09:11 PM #7
    Yep, I went to a dealership today and even had the TSB number, but they coudn't find any updated software CDs that they would possess to do the flash. The BDF engine was only used for a few years in select cars, so good luck.
    -Holmes
    People are always surprised that my car smells of crayons
