Results 1 to 15 of 15
Thread: seized hub. help please
  1. Junior Member ghostkid's Avatar
    Apr 17th, 2012
    North Houston tx
    72 ghia. 06 forester. 79 vespa. 84 gti.
    04-18-2012 02:22 AM #1
    Replaced my front driver side wheel bearing with a janky local mechanic and got it back and I quickly bolted it back on since this is my daily driver. Took it a half mile down the road and just as I slowed to turn around the wheel locked up. Towed it home and the in is seized in the spindle. Did I misplace a washer somewhere? What happend? And how can I prevent this from happening? Should I just buy a new spindle bearing hub assembly? Thanks. Been digin this forum for a while now.
  2. Member rabbitnothopper's Avatar
    Oct 19th, 2009
    little d BIG D - texas
    81 VW Rabbit 1.7L EN 4-speed 020 GP, 78 VW Rabbit 1.5L EH 4speed 020 GC->GP
    04-18-2012 06:07 AM #2
    Quote Originally Posted by ghostkid View Post
    ...hmm ok
    yes there is a washer behind the large 30mm nut
    the torque for the nut is 150lbs/ft OR MORE but less than 250lbs/ft
    you NEVER reuse that nut, always replace with new
    why your bearing locked up? i dont know.....
    normally the axle might not fit 100mm or 90mm...but since you didnt change anything except a bearing....
    yes you can get the spindle+bearing+hub all completely assembled from http://www.partsplaceinc.com/
  3. Junior Member ghostkid's Avatar
    Apr 17th, 2012
    North Houston tx
    04-18-2012 12:08 PM #3
    Thanks. Is there a washer that goes between the cv and spindle? It looks like the hub went too far in and now the outer metal casing of the spindle is against the hub
  4. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    04-18-2012 12:10 PM #4
    What is the car year and model?
  5. Junior Member ghostkid's Avatar
    Apr 17th, 2012
    North Houston tx
    04-18-2012 12:15 PM #5
    84 rabbit gti
  6. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    04-18-2012 12:18 PM #6
    Did you swap a new axle or outer CV on that same side when you did the wheel bearing? GTI's have a slightly different spindle than non GTI's and most of the available aftermarket axles and CV's are for the non-GTI's and they will hit the spindle and lock up the wheel.
  7. Junior Member ghostkid's Avatar
    Apr 17th, 2012
    North Houston tx
    04-18-2012 12:32 PM #7
    Na. It's the same cv
  8. Member WackyWabbitRacer's Avatar
    Apr 24th, 2001
    Charlotte, NC USA
    1978 WackyWabbit (sold)
    04-18-2012 04:30 PM #8
    Only washer is on the outside of the hub carrier bearing, just behind the large 30mm axle nut.
    Guess you will have to disassemble the hub carrier (ie spindle) and do a post morten inspection. Apparently some portion of the bearing installation was not correct.
    Cheers, WWR.
    WWR
    signature edition
    Harry Puckett R.I.P. 01-24-2010. You are gone too soon. We had races
    to race, jokes to tell, laughter to share, and cold beers to drink.
  9. Junior Member ghostkid's Avatar
    Apr 17th, 2012
    North Houston tx
    05-04-2012 08:04 AM #9
    Update. Tore it apart and there was lots of fused metal junk all over my hub so I hit it with my grinder to smooth it out. Got it pressed in and put back on my car and torque the axle nut then backed it up half a turn as recommended by the dude down the way. Rolled around my yard a bit them set off down the road. Got to third gear and I heard and felt bad grinding like it was locking up again. Loosened the nut another full turn and eased it home. Is that about right? Or maybe the guy I bought the car from put the 100mm driveshaft in and not the 90mm?
  10. Member
    Jun 14th, 2001
    Music City USA
    79 Scirocco 82 Rabbit Truck 85 Golf D 87 GTI 97 Passat TDI 03 TT
    05-04-2012 10:56 PM #10
    local dude down the road doesn't know jack.
    if its a 90 vs 100mm mismatch it is obvious.
    I would venture your bearing is trashed and wouldn't trust the hub after what it has been subjected to.
    a washer goes on the outside, then the big nut. I torque the nuts to 195 ft lbs.
    if you roll the car without the axle in the bearing, you ruin the bearing. It has to have the stub axle for support.
  11. Member grizzlyone's Avatar
    Nov 8th, 2002
    RDU
    your mom
    05-05-2012 10:59 AM #11
    Quote Originally Posted by antichristonwheels View Post
    Agreed, your local dude is an idiot about VW's.
    Your bearing is done for now, if it wasnt before from an improper install.
  12. 05-05-2012 02:22 PM #12
    I have a set of knuckles with new bearings and hubs, with TIG welded studs and propper ball-seat nuts if you need them. Boxed and ready to go.
  13. Member wantacad's Avatar
    Apr 3rd, 2003
    Belleville,Ill
    I haz a bunnah
    05-05-2012 06:11 PM #13
    no, either the local dude is a total retard or you mistook his information. Front wheel bearings you do not loosen up after torquing them down. Rear wheel bearings are the ones you tighten then loosen up.
    Time to go buy another bearing and redo your mistake and buy a bentley manual too.
    Quote Originally Posted by WackyWabbitRacer View Post
    You're new here but don't be a DORK.....
    Cheers, WWR.
    Quote Originally Posted by dsleggett View Post
    I have a great idea, upgrade to the big 3: periods, commas and capital letters! I realize I'm old but I cannot read some of this s**t.
  14. Junior Member ghostkid's Avatar
    Apr 17th, 2012
    North Houston tx
    05-06-2012 03:42 PM #14
    Well its doing fine... handles well and rolls fine it seems. Not heat or rubbing. Drove over 100 miles on it yesterday. But I do plan to get a new hub soon.
  15. Member
    Jun 14th, 2001
    Music City USA
    05-07-2012 12:26 PM #15
    don't go too far from home.
