Page 1 of 2 1 2 LastLast
Results 1 to 35 of 36
Thread: Outlook 2003 is excessively slow, unresponsive, and crappy.
  1. Member maskedSONY's Avatar
    Nov 7th, 2000
    2007 Accord EX-L
    04-18-2012 09:04 AM #1
    I'm looking to solutions for a friends computer. He has a Dell Dimension which runs Windows XP just fine, however his version of Outlook 2003 barely runs properly at all. It's slow to load, unresponsive, and just has become a nightmare to use.
    Does anybody here have any suggestions as to what to do? Or do you have suggestions on how to fix Outlook so that it runs smoothly? He's running Windows XP SP2 at least, most likely SP3.
    Quote Originally Posted by Turbiodiesel!
    It really is the perfect, no excuses all-rounder for the rich guy who's accustomed to having it all - the Hybrid version especially. It's like an F-150 Raptor banged an M5 in the men's room of a biker bar. Nobody really wanted the results, but damn - what a set of genes.
  2. 04-18-2012 09:11 AM #2
    Is he loading from a POP3 account or an IMAP account because that can determine how quickly emails arrive? Or does even get to the point that he sees email before it craps out? Another alternative to see if it is Outlook that is having the problem is to load Thunderbird and have it load up the same mail profile and if it loads slowly there then you know there is something wrong with the connection itself and not Outlook.
  3. 04-18-2012 09:16 AM #3
    How big is the PST file that Outlook 2003 is trying to load? Are there any other plug-ins that Outlook is trying to load? If Windows Search (or some other app) is trying to index a huge PST file, Outlook is going to be slow as balls.
  4. Member maskedSONY's Avatar
    Nov 7th, 2000
    2007 Accord EX-L
    04-18-2012 09:16 AM #4
    Quote Originally Posted by dvlish09 View Post
    Two accounts - a POP3 and an IMAP account. The IMAP account has barely anything on it though and connects just fine. The POP3 account has tons of emails and contacts though.
    The problems show up when he double clicks to load the damn thing.
  5. Member maskedSONY's Avatar
    Nov 7th, 2000
    2007 Accord EX-L
    04-18-2012 09:23 AM #5
    Quote Originally Posted by SpiffyGTI View Post
    Would Windows XP try to index the pst file?
  6. 04-18-2012 09:27 AM #6
    Some search plug-in or something like that might.
  7. 04-18-2012 09:28 AM #7
    Also, start up Performance Monitor and see what your disk I/O looks like when Outlook's open because if that spikes then you know something is ripping through a massive PST file.
  8. 04-18-2012 09:45 AM #8
    Quote Originally Posted by maskedSONY View Post
    yes the OS would do that if set up to index the C Drive. You can always check the properties of the C Drive and make sure that indexing is turned off that should help it a little bit with the loading. But like the other member mentioned if it is a massive PST file the you would need to check for possible corruption of the PST file as well. Once that file approaches 1.8GB its going to self corrupt and there is the possibility of losing email.
  9. Member maskedSONY's Avatar
    Nov 7th, 2000
    2007 Accord EX-L
    04-18-2012 11:12 AM #9
    Oh shyte. Time to archive the old PST file elsewhere and start anew.
  10. Member maskedSONY's Avatar
    Nov 7th, 2000
    2007 Accord EX-L
    04-18-2012 11:15 AM #10
    How well does Thunderbird work versus outlook? I actually do not know many people who use thunderbird but does it have advantages over outlook? Can it handle a beating and a heavy workload?
  11. Member x047x's Avatar
    Mar 16th, 2004
    Pittsburgh
    '08 GTI 2.0t
    04-18-2012 11:31 AM #11
    I like Thunderbird a lot over Outlook ( I use TB at home and Outlook at work). BUT what is he using it for? Simply checking email? If so I would definitely say try TB. Outlook has a ton of integration features but is bloated but since he just has POP and IMAP (and not exchange) I would guess he's mostly just checking email.
  12. Member maskedSONY's Avatar
    Nov 7th, 2000
    2007 Accord EX-L
    04-18-2012 12:14 PM #12
    This individual has a boatload of contacts, does Thunderbird have a contacts/address book feature? Or is it an add on?
  13. Member x047x's Avatar
    Mar 16th, 2004
    Pittsburgh
    '08 GTI 2.0t
    04-18-2012 12:53 PM #13
    Yeah it has a fully functional address book. TB is to Outlook as Firefox is to IE. Like I said, I think it's a better program.
    EDIT: And if he's using Outlook Express, then TB is definitely better. The one thing Outlook (full version) does better is the Calendar and scheduling and stuff but if he doesn't use those functions then go TB and never look back.
  14. Member GreenandChrome's Avatar
    May 24th, 2002
    Washington State
    Sportage
    04-18-2012 12:57 PM #14
    Yes it does.
    I used TB about 5 years ago, and it wasn't much different from Outlook 2003.
    Unless your friend is running Exchange, there's no reason to forcibly use Outlook.
    //// twitter: mbull //// blog ////
    //// Humans are the only beings on the planet that raise trees, cut trees, process trees to make paper, and then write on that paper: "Save the Trees." ////
    //// Stop making things idiot-proof. We're just making better idiots. Not the way we need to be going. ////
  15. Member x047x's Avatar
    Mar 16th, 2004
    Pittsburgh
    '08 GTI 2.0t
    04-18-2012 01:03 PM #15
    Quote Originally Posted by GreenandChrome View Post
    This... TB will also have a much smaller footprint in terms of resources used
  16. Member maskedSONY's Avatar
    Nov 7th, 2000
    2007 Accord EX-L
    04-18-2012 01:20 PM #16
    Then this switchover is happening as soon as I can make it.
  17. Member You are to blame's Avatar
    Jun 1st, 2003
    Vanuatu
    04-18-2012 02:03 PM #17
    Microsoft has a limit of 1.8GB for pst files older than 2002 format. Sometimes they crap out on outlook 03/07 too without even being that big. Run scanpst and then create a new archive and copy old archive into new one just to see if it helps.
    Signatures are for the insecure
  18. Member maskedSONY's Avatar
    Nov 7th, 2000
    2007 Accord EX-L
    04-18-2012 02:24 PM #18
    how to run scanpst? is this a command prompt thingy?
  19. Senior Member SAPJetta's Avatar
    Feb 3rd, 2001
    East Bay, CA
    2008 Rabbit S(low), 2012 Outback 2.5 Premium
    04-18-2012 02:57 PM #19
    How large is the PST file? Has Outlook been repaired/reinstalled?
    Where are we going and why am I in this handbasket?
    XBL - urparanoid
  20. Member You are to blame's Avatar
    Jun 1st, 2003
    Vanuatu
    04-18-2012 03:06 PM #20
    Here are some tips and how to for Scanpst... http://support.microsoft.com/kb/287497
    You should try closing the archive/personal folder/pst files (or whatever you want to call it) then close outlook and open again. If it's still very slow, then try reinstalling ms office/outlook.
  21. Member GeoffD's Avatar
    Aug 13th, 2001
    04-19-2012 10:35 PM #21
    I run both to keep my work email and my personal email totally separate. Thunderbird is very primitive compared to Outlook. I don't do anything fancy with my personal email so it's fine but it would be totally inadequate for what I do at work.
    With Outlook, you pretty much have to auto-archive and change archive folders from time to time to prevent .PST files from getting too big.
  22. Member maskedSONY's Avatar
    Nov 7th, 2000
    2007 Accord EX-L
    04-20-2012 12:33 PM #22
    Windows XP still has security updates that install from time to time. Could any of these cause Outlook to slow down or really get messed up?
  23. Member maskedSONY's Avatar
    Nov 7th, 2000
    2007 Accord EX-L
    04-20-2012 12:35 PM #23
    Quote Originally Posted by GeoffD View Post
    So I take it that at a certain point, you archive all of your emails into a separate .pst file and then the original pst file becomes considerably smaller, correct?
    Does anybody know if there are third party software programs out there which can "move" emails out of a .pst file and keep the original there, just so that the original settings don't get messed up?
  24. 04-20-2012 01:40 PM #24
    If you can drag and drop, you can move files out of a .pst.
    Do this:
    -Go to File > Data File Management... (I'm going on memory here)
    -Click 'Add..." and name a new pst file, let's say "Archive.pst" or something like that
    -You should probably change the title from "Personal Folders" to "Archive" or "Old Emails"
    -On the left, you should see the new title
    -Right-click the new title and create a new folder, name it "Old Received"
    You probably want to create one for sent items too since mixing them can be a pain in the ass. Go to your original inbox, highlight a bunch of old email, then drag it to the new folder you created on the left.
    Outlook won't immediately compress the OG PST file but it will gradually reduce in size over time.
  25. 04-20-2012 06:22 PM #25
    I am going to place money on the PST file being over 2GB, and since it's Outlook 2003 it's unicode format and probably already corrupted.
    Also, why on earth would your friend willingly use Outlook at home?
    That s**t cray, ain't it jay?
    What she order, fish filet?
  26. Member maskedSONY's Avatar
    Nov 7th, 2000
    2007 Accord EX-L
    04-21-2012 02:24 PM #26
    the outlook file was at 2.7GB. No wonder the damn thing was atrocious.
  27. Member You are to blame's Avatar
    Jun 1st, 2003
    Vanuatu
    04-23-2012 09:26 AM #27
    Ok, since the pst file is corrupt, make a copy of it and further corrupt it using a hex editor tool and then use scanpst to repair the file. Make sure you make a backup copy of the pst before you do anything.
    Here are some instructions: http://www.techrepublic.com/article/...t-file/5054599
  28. Member maskedSONY's Avatar
    Nov 7th, 2000
    2007 Accord EX-L
    04-23-2012 09:33 AM #28
    Here's the thing, Windows in general is being bogged down by this entire mess.
    Once I repair the pst file, should I just ditch outlook entirely or stick with it?
  29. Senior Member Hostile's Avatar
    May 29th, 2002
    NOVA
    a subaru and a vw
    04-23-2012 09:35 AM #29
    Quote Originally Posted by You are to blame View Post
    Outlook 2003 does not have a size limit to PST files, you can let one get as large as you want. 2GB is an artificial limit that people have adopted because of the frequency with which a PST larger than that will corrupt.
  30. Member You are to blame's Avatar
    Jun 1st, 2003
    Vanuatu
    04-23-2012 09:56 AM #30
    It does have a limit if the pst was an earlier format. I see this even in office 2007
  31. 04-23-2012 10:10 AM #31
    Correct, there's a very old format that has a 2GB file size limit. However, I'm pretty sure that by default, Outlook 2003 uses the new file format unless otherwise specified. Anyway, the fact that it's 2.7GB definitely isn't helping Outlook to run fast. You can run ScanPST to fix any potential issues with the file, but that won't magically make it run faster. Your best bet is to create a new PST file, transfer all the old email to that, then remove the file from Outlook. Outlook will slowly but surely shrink the current PST file now that all the excess email has been removed and it will be back to running lean and mean. (or you can choose to "Compact Now" and it'll take a while to manually shrink the file)
    I say stick with Outlook. If you're really convinced that it's Outlook that's crappy and slow, then feel free to switch to Thunderbird.
  32. 04-24-2012 11:57 AM #32
    Drop Outlook like it's hot. It's the gold standard for businesses with on-premises Exhange, but home users should really get a Gmail account.
    BTW I do this for a living so its not like I'm an OS X fanboy trashing everything MS.
  33. Member GreenandChrome's Avatar
    May 24th, 2002
    Washington State
    Sportage
    04-24-2012 12:29 PM #33
    Quote Originally Posted by Angry_Birds View Post
    Using Outlook at home is fine, if you're used to the UI (which 95% of users are*). For the average user, Outlook is definitely overkill. Simple web-based apps work just fine. But there's nothing wrong with using Outlook. It's familiar. It gets the job done, as long as you delete the emails from Gamma that are chain emails from 5-10 years ago.
    Seriously... my mom, who used to work at MSFT, never deleted her deleted folder contents in Outlook.
    * Statistics pulled from my "donkey"
  34. 04-25-2012 11:17 PM #34
    Not everyone wants Google to keep their messages forever and mine their data.
  35. Member maskedSONY's Avatar
    Nov 7th, 2000
    2007 Accord EX-L
    04-26-2012 10:21 AM #35
    Quote Originally Posted by O_G View Post
    I'm becoming increasingly uncomfortable about this. A friend of mine has his own domain and private server for email services and I'm seriously thinking of copying his model and making it mine.
