Results 1 to 8 of 8
Thread: Faulty Range Reading
  1. 04-18-2012 11:55 AM #1
    On a road trip getting down around a quarter tank of fuel remaining I noticed the [I]Range[I] reading in the MFI actually climbing rapidly. Scrolled over to the Current Consumptionscreen and sure enough it just showed dashes as if the vehicle were at a standstill. After refuel and restart the Current Consumption reading returned to normal but the Rangeis just floating around some where below its 2000 mile max.
    Coding seems unchanged. Did I lose an Adap or something?
    My Tablet hibernated in the middle of Autoscan so I'm unsure whether there were Faults lost. Here is the present scan:
    Tuesday,17,April,2012,12:04:56:34689
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 7L - VW Touareg
    Scan: 01 02 03 05 06 08 09 11 15 16 17 18 19 1C 22 29 34 36 37 39
    46 47 56 68 69 6C 6E 76
    VIN: WVGPT77L46D062013
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 070 906 016 CQ HW: 028 101 196 2
    Component: V10 5,0L EDCG000AGMª8472
    Revision: --H02--- Serial number: VWZ3Z0F6455356
    Coding: 0060575
    Shop #: WSC 31414 000 00000
    VCID: 61C2339FBB528B1
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09D-927-750.lbl
    Part No SW: 09D 927 750 DP HW: 09D 927 750 DP
    Component: AL 750 6A 0856
    Coding: 0004200
    VCID: 7F0695E72DE65D1
    Part No: 09D 927 750 DP
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
    Part No: 7L0 907 379 G
    Component: ESP ALLRAD MK25 0203
    Coding: 0022786
    VCID: 3D7AAFEF676A8F1
    No Faults Found
    Address 05: Acc/Start Auth. Labels: None
    Part No SW: 7L0 909 137 A HW: 5WK 485 02
    Component: 29 Kessy 6700
    Coding: 0147688
    VCID: 316283DFAB327B1
    Part No: 7L0 909 137 A
    Part No: XXXXXXXXXXX
    Component: ELV XXXX
    No Faults Found
    Address 06: Seat Mem. Pass Labels: None
    Part No: 7L0 959 760
    Component: Sitzverstellung 0701
    Shop #: WSC 00000 000 00000
    VCID: F7F6FDC785D6E51
    No Faults Found
    Address 08: Auto HVAC Labels: 7L6-907-044.clb
    Part No: 7L6 907 044 T
    Component: CLIMAtronic 2+2 4222
    Coding: 0020030
    VCID: 458AC70F0FBAC71
    Part No: 7L6 907 049 E
    Component: CLIMAtronic FOND 0400
    No Faults Found
    Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
    Part No: 7L6 937 049 N
    Component: 3002
    Coding: 0111836
    VCID: 4796CD0735B6D51
    Component: 3002
    No Faults Found
    Address 11: Engine II Labels: Redir Fail!
    Component: V10 5,0L EDCG000AGSª8472
    Coding: 0060575
    Part No: 070 906 016 CQ
    No Faults Found
    Address 15: Airbags Labels: 3D0-909-601.lbl
    Part No: 3D0 909 601 H
    Component: 05 Airbag 8.4E++H01 0562
    Coding: 0012341
    VCID: 28546EBB98E83A9
    Part No: 7L0 959 339 C
    Component: BF-Gewichtsens. 006 0008
    No Faults Found
    Address 16: Steering wheel Labels: 7L6-953-549.lbl
    Part No: 7L6 953 549 H
    Component: Lenksäulenmodul 3401
    Coding: 0010032
    VCID: 448CDA0B0480FE9
    No Faults Found
    Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
    Part No: 7L6 920 981 R
    Component: KOMBIINSTRUMENT RB8 3211
    Coding: 0005231
    VCID: 4894CE3B38A8DA9
    No Faults Found
    Address 18: Aux. Heat Labels: Redir Fail!
    Part No: 7L6 815 071 D
    Component: Standheizung E1MAC
    Coding: 0000100
    VCID: 336E89D7512E491
    No Faults Found
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<>CAN 0101
    Coding: 0000006
    VCID: F0E4C6DBE0B8B29
    No Faults Found
    Address 1C: Position Sensing Labels: 7L6-919-879.lbl
    Part No: 7L6 919 879 A
    Component: JCI PathPoint 2200
    No Faults Found
    Address 22: AWD Labels: None
    Part No: 0AD 927 755 AT
    Component: TRANSFERCASE 0114
    VCID: 8D1ABF2F974AFF1
    No Faults Found
    Address 29: Left Light Labels: 3D0-909-157.lbl
    Part No: 3D0 909 157
    Component: EVG GDL+AutoLWR(l) 0001
    Coding: 0000003
    VCID: E6C8A083D27C6C9
    No Faults Found
    Address 34: Level Control Labels: None
    Part No: 7L0 907 553 F
    Component: LUFTFDR.-CDC- 3C3P1 3081
    Coding: 0015521
    VCID: 3668B0C3425C5C9
    No Faults Found
    Address 36: Seat Mem. Drvr Labels: None
    Component: Sitzverstellung 0703
    No Faults Found
    Address 37: Navigation Labels: 7L6-919-887-DVD.lbl
    Part No: 7L6 919 887 M
    Component: Navigation 0047
    Coding: 0000101
    VCID: 50A4E65BC0F8129
    No Faults Found
    Address 39: Right Light Labels: 3D0-909-158.lbl
    Part No: 3D0 909 158
    Component: EVG GDL+AutoLWR(r) 0001
    Coding: 0000003
    VCID: E7D6AD87D576751
    No Faults Found
    Address 46: Central Conv. Labels: 7L0-959-933.lbl
    Part No: 7L0 959 933 J
    Component: HSG 5115
    Coding: 0000085
    VCID: 438ED917018EF91
    Component: HSG 5115
    Part No: 7L0 959 701 H
    Component: Tuersteuergeraet FS 0201
    Part No: 7L0 959 702 H
    Component: Tuersteuergeraet BF 0201
    Part No: 7L0 959 703 D
    Component: Tuersteuergeraet HL 0201
    Part No: 7L0 959 704 D
    Component: Tuersteuergeraet HR 0201
    No Faults Found
    Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
    Part No: 7L6 035 456
    Component: 08K Audioverst. 0105
    Note: Excessive Comm Errors
    Address 56: Radio Labels: 7L6-035-186-DVD.lbl
    Part No: 7L6 035 186 E
    Component: Radio 0047
    Coding: 0014042
    VCID: 356AB7CF5F5A571
    Address 68: Wiper Electr. Labels: None
    Part No: 7L0 955 119 K
    Component: Front Wiper 4027
    Coding: 0000341
    Shop #: WSC 31414 000 376832
    VCID: 3C7CA2EB7C70869
    Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 010510 054 0403
    Coding: 00133665
    Shop #: WSC 31414
    Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
    Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
    Component: ANHAENGERELEKTRONIK 8854
    Coding: 0000002
    VCID: 3874BEFB4848AA9
    Part No: 7L0 907 383 G
    No Faults Found
    Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
    Part No SW: 7L6 907 441 HW: 7L6 907 441
    Component: J772__Rearview 0051
    Coding: 0000101
    VCID: F2E0CCD3EEB4809
    Part No: 7L6 907 441
    No Faults Found
    Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
    Part No: 7L6 919 044 J
    Component: DACHDISPLAY 0538
    VCID: 3E78A8E36A6C949
    No Faults Found
    Address 76: Park Assist Labels: 3D0-919-283.lbl
    Part No: 7L0 919 283 F
    Component: 0E Einparkhilfe 1107
    VCID: 3972BBFF7342B31
    No Faults Found
    End ---------------------------------------------------------------------
    2006 Touareg V10 TDI, 2010 A3 TDI, 1995 90 Quattro, 2003 Eurovan
  2. 04-19-2012 11:51 AM #2
    Am I correct that the range calculation is in Address 17?
    What inputs are required?
    Might adaptation reconnect lost inputs?
    Fuel gauge reading was always correct. Current consumption reading, gone when the problem occurred, is now present.
    Possible "red herrings:" Driving through a blinding dust storm. Refueling with engine on.
  3. 04-19-2012 12:38 PM #3
    Is the range calculation made in the Address 17 module?
    Might an adaptation reconnect lost inputs?
    Possible "red herrings:" Driving for hours through a dust storm, refueling with engine on.
  4. 04-24-2012 09:10 PM #4
    Still working on this problem, no faults stored. I did not knowingly erase any DTC's, despite the Log header!
    Channel A03, Consumption Correction, looks to be the problem, or an least an indicator.
    Any advice on how to restore communication there?
    Address 17: DTCs clearedTuesday,24,April,2012,18:27:57:34689
    Adaptation Channel 003:
    Stored value
    ERROR:
    Channel 03
    Not
    Available
    Adaptation Channel 009:
    Stored value 6473
    Mileage
    Mileage
    in 10
    miles
    Adaptation Channel 030:
    Stored value 128
    Tank sensor
    TankSensor
  5. 04-24-2012 11:34 PM #5
    It is illegal to clock cars!
    Jack Shapiro E.P.E. VAS>ASE Extern VST-3/1 LAB (TECH INQUIRIES ARE TO BE IN WRITING )
    7076062 NYS DMV SAE>NASTF>VW-Audi GEKO Authorized
    European Parts Emporium/Performance --- Immobilizer Solutions LLC --------
    Postadresse: 1001 State Route 17K Montgomery New York 12549 USA
    vwemporium@aol.com -845-457-9808 TEL 9AM-5PM --------TAKE CONTROL OF WHAT YOU OWN!!!!!!
  6. 04-25-2012 01:20 PM #6
    Quote Originally Posted by Jack@European Parts View Post
    Jack, I'm totally confused.
    All I want to do is get my missing Range reading back. I have not and will not change anything until I hear from you or another expert.
  7. 06-06-2012 10:17 PM #7
    Following Dana's advice I recoded using same code. A003 still not available so removed, disconnected, reinstalled cluster. A003 still not available but road test showed Range reading restored. Not really sure what fixed it but it appears that this Touareg (T1) doesn't support the A003(consumption correction) channel.
  8. 07-20-2012 05:10 PM #8
    Isn't entertaining when very bright people make assumptions without first reading the actual post and then go off on a tangent... No wonder we have confusion!!!!
