VWVortex.com - 2012 RNS-850: HD Radio stations all in mono, not <<==STEREO==>>
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 32
    Thread: 2012 RNS-850: HD Radio stations all in mono, not <<==STEREO==>>
    1. Junior Member Eugene-Dave-1's Avatar
      Apr 18th, 2012
      2012 Touareg Lux TDI
      04-18-2012 12:45 PM #1
      New here, my first post. I have a new 2012 Touareg Lux TDI.
      From Day 1, I noticed the RNS-850 nav/radio didn't sound right when tuned to an FM station broadcasting in HD Radio. I finally figured it out.
      The RNS-850 plays HD Radio in mono, not stereo. Sound comes from all the speakers, but it's in mono. And in fact it's only the content from the left channel. The right channel information is completely missing.
      Thinking this had to be a problem with my RNS-850, I tried 2 other Touaregs at the dealer, both with RNS-850. They do exactly the same thing: They will not play HD Radio in stereo. One of those Tregs had the DynAudio premium sound system.
      My previous car was a 2011 Tiguan with RNS-510, which also supports HD Radio. It worked perfectly. I then tried a 2012 Passat at the dealer, also with an RNS-510, and it worked fine.
      Dealer reported the issue to VW. VW opened a case. They had the dealer take a scan of my car and send it to them for analysis.
      Their response: The RNS-850 is working "as designed". There must be a problem with the radio stations here, or the signal is too weak, or I don't know what I'm talking about.
      There are at least 4 FM stations broadcasting in HD Radio here: KWAX, KRVM, KLCC, and occasionally KZEL. All 4 stations play HD Radio fine on an RNS-510 but the RNS-850 plays them only in mono.
      The dealer is within 5 miles of the radio station transmitters and has clear line of sight. There is no possibility of this being a weak signal issue. Nobody is able to explain to me why the 850 would do this but the 510 is fine (according to me).
      Note that you need to be listening to music to detect this problem. Talk isn't in stereo and you would never notice there's a problem.
      • If the RNS-850 locks onto an HD Radio signal, the "HD Radio" display icon turns bright white and you should have perfect digital sound.
      • If the signal is weak, the icon will be grayed out, in which case you're listening to conventional analog FM.
      • If the icon isn't on at all, either the station isn't broadcasting in HD, or the signal is too weak to get a digital lock.
      Does your RNS-850 play HD Radio in stereo?
      HD Radio Station Directory (US)
      How to enable HD Radio on the RNS-850:
      • Settings
      • Radio
      • Place a check mark in the "HD Radio" option box
      Now tune to an HD Radio station playing music. Is it in stereo, or is it in mono? If you're not sure, you can go back to the menu and toggle HD Radio on and off and listen for the difference. Note than when you check the box to enable it, the station you're listening to will take a few seconds before HD locks in.
      If you believe your RNS-850 has this issue, please report it to VW Customer Care!
      800-822-8987
      If you want, tell them to refer to existing Case #120196851.
      If VW doesn't hear from more RNS-850 owners about this, they're not going to take it seriously.
      Thanks.
    2. 04-18-2012 09:30 PM #2
      How do I know if I have RNS-850 in my T?
    3. Junior Member Eugene-Dave-1's Avatar
      Apr 18th, 2012
      04-19-2012 12:23 AM #3
      Good question. I haven't researched all VW cars that get the RNS-850, but I know the 2011-2012 Touaregs equipped with nav have it. The Touareg may be the only one.
      Note that this HD Radio problem is probably unique to North America, maybe just the US. RNS-850s are used in Europe too but I don't think they use the same system for digital radio.
      I talked to a professional car audio guy about it. He claims there are "issues" with some HD Radio chipsets used in 12 Volt applications like cars.
      I'm going to try to make a video with stereo audio to demonstrate this problem. May post it to YouTube if it turns out good...
    4. Member nicolaisnicer's Avatar
      May 24th, 2006
      boston area
      DD 16 GTI S 4D DSG RES DELETE, NEUSPEED PM, CQUARTZ, AE LEDS, AKD; FUN CAR 911 997 CAB
      04-20-2012 08:58 AM #4
      I can replicate the issue on mine 2011. Vw is going to hear form me
    5. Junior Member Eugene-Dave-1's Avatar
      Apr 18th, 2012
      04-20-2012 11:35 AM #5
      Don't let VW try to tell you this is a problem with a weak station.
      If the "HD Radio" icon lights bright on the display and is steady, you have a strong signal, you're locked in, and you should get "near CD quality" stereo sound. Period.
    6. Junior Member Eugene-Dave-1's Avatar
      Apr 18th, 2012
      04-22-2012 03:57 PM #6
      I uploaded a video to YouTube that attempts to demostrate the defective HD Radio tuner in my RNS-850...
      http://www.youtube.com/watch?v=rXq18aV-jSk
    7. n00b
      Dec 27th, 2011
      Moreland Hills, OH
      2007 Jetta Wolfsburg 2012 Touareg VR6 Lux
      04-23-2012 01:28 PM #7
      Just checked, my 2012 Touareg also has this problem.
      Going to call VW.
      When I have time, I'm going to swing by the Audi dealership and check to see if this affects their radios too.
    8. Junior Member Eugene-Dave-1's Avatar
      Apr 18th, 2012
      04-23-2012 01:55 PM #8
      Quote Originally Posted by Billiken View Post
      Going to call VW.
      Yeah, I just found out the Audi MMI 3G (?) is basically the same unit. I might post about this on a couple Audi forums and see if anyone can confirm whether it has the same issue.
      Don't let VW tell you it's "weak reception". If the signal is strong enough for the HD Radio icon to light bright and remain on, you have a digital lock and you should be getting perfect stereo.
    9. n00b
      Dec 27th, 2011
      Moreland Hills, OH
      04-24-2012 08:53 AM #9
      Perhaps a letter to Consumer Reports and Car & Driver?????
    10. Junior Member Eugene-Dave-1's Avatar
      Apr 18th, 2012
      04-24-2012 12:59 PM #10
      VWoA once again acknowledged my complaint, including reviewing my video demonstrating the problem. Again they say the RNS-850 is functioning "as designed". Complaint rejected, and they intend to have no further communication with me regarding my issue.
      Interestingly, there are a couple of lawfirms (easily found in a Google search) who are trying to put together a class action suit against auto makers regarding problems and defects with HD Radio. They list a bunch of complaints about HD Radio like it drops out of digital too often, sound skips, etc.
      Here we have a situation where a major car manufacturer is now knowingly selling new cars with 100% defective HD Radio tuners. You tell me.
      Billiken: If you have a chance to try HD Radio in a current-year Audi please let us know the results. If the HD Radio in the Audi works correctly, that suggests a possible firmware issue in the VW RNS-850. On the other hand, if the Audi has the same problem, that suggests a defect in the HD Radio tuner chipset used in these nav systems.
    11. n00b
      Dec 27th, 2011
      Moreland Hills, OH
      04-24-2012 01:50 PM #11
      Quote Originally Posted by Eugene-Dave-1 View Post
      Traveling this week and won't be able to hit the Audi dealership until next week.
    12. Junior Member Eugene-Dave-1's Avatar
      Apr 18th, 2012
      04-24-2012 01:58 PM #12
      Understood. Unfortunately there's no Audi dealer anywhere near me or I'd confirm it myself.
    13. Junior Member Eugene-Dave-1's Avatar
      Apr 18th, 2012
      04-27-2012 10:40 AM #13
      OK, here's my best shot at demonstrating the problem. Please use headphones if possible, and read the description.
      http://www.youtube.com/watch?v=sDi0dUAwRWs
    14. Member
      Dec 14th, 2011
      NJ
      2016 Audi A6 2.0T Quattro, 2008 Porsche C2S, 2003 M-B E320, 2016 VW Golf TSI S
      04-29-2012 09:31 AM #14
      Mine works just fine in all modes.
    15. Junior Member Eugene-Dave-1's Avatar
      Apr 18th, 2012
      04-29-2012 11:56 AM #15
      Since I discovered this issue with the RNS-850 and how tough it is to get VW (and others) to understand it, I've asked random people "What do you think the difference is between mono and stereo?". Their answer is usually along the lines of "Well mono is 1 speaker, and stereo is 2 speakers". Of course stereo requires 2 (or more) speakers, but that by itself doesn't make stereo. You can play mono (monaural) material through 2 or 6 or 12 or 20 speakers, and it's still mono.
      Not saying that applies to anyone here. In fact if someone's RNS-850 plays HD Radio in stereo, I'd like to compare VCDS data with you and see if we have different revision head units or something.
    16. Member
      Jun 12th, 2011
      Western Kentucky
      2011 Touareg TDI Sport
      04-29-2012 01:39 PM #16
      I'm sorry to say that I discovered mine doesn't play stereo at all. I tried FM, FM/HD, SDRAM, CD and every single one mode sounded - to me - like monaural. And there's nothing in the manual that suggests a "stereo" indicator that lights up to indicate stereo vs mono FM reception. So I hooked up the VDCS, navigated to Radio (56) and performed the self-test. Confirmed. When I select LF, the same thing plays out of all 4 speakers. When I select RF, same thing. LR and RR, same. This damn car has a thousand+ dollar monaural entertainment system installed.
      I have an appointment with the dealer on the 7th.
      //greg//
    17. Junior Member Eugene-Dave-1's Avatar
      Apr 18th, 2012
      04-29-2012 03:40 PM #17
      Many tracks by The Beatles are perfect for stereo testing, and almost everyone either has them, or can borrow a CD from someone. The tracks have extreme left-right separation. For example Nowhere Man has the backing instrumental track panned hard left, and the vocals panned hard right:
      http://www.youtube.com/watch?v=6H2KgYN74QU
      If that track were played back on my RNS-850's HD Radio tuner (and two other 850s I've tried), it would sound like this:
      http://www.youtube.com/watch?v=ejT78KTuCOQ
      The vocals would be nearly 100% missing because the 850's HD Radio throws out the right channel and plays only the left channel through all the speakers.
      Some early Jimi Hendrix stuff also works great for testing left-right separation. Here's The Wind Cries Mary. The vocals are hard left, the instruments are hard right:
      http://www.youtube.com/watch?v=RGjWBQeVBso
      HD Radio on the 850 would make that song sound something like this because only the left-channel vocals would be present:
      http://www.youtube.com/watch?v=9ya27hOVyr0
      And so on...
      If you have access to these songs on CD or MP3 or whatever, they're great for testing stereo separation.
      Also a lot of radio stations do a Breakfast With The Beatles or Beatles Hour once a week, or more. If you tune into one of those broadcasts it's a good way to hear the stereo separation (assuming they're playing the stereo version of a song and not the mono version!). Or tune into any classic rock or oldies station. A lot of older songs have this very pronounced left-right stereo effect.
    18. Awaiting Email Confirmation
      Feb 27th, 2003
      WI
      2017 Volvo R Design Platinum Polestar equipped 2004 Jag XKR 2012 VW Touareg
      05-01-2012 11:15 AM #18
      yep, same problem on my 2 week old Treg. Any Dynaudio Tregs out there with this issue? If so I would be a really angry Exec owner!
    19. Junior Member Eugene-Dave-1's Avatar
      Apr 18th, 2012
      05-01-2012 11:46 AM #19
      Quote Originally Posted by verde o View Post
      I have confirmed the problem on a Sport with nav, my own Lux TDI, and an Exec with Dynaudio.
      The good news is I think my complaint is finally gaining some traction with VWoA. I shoud know more in a week or so. Meanwhile I encourage everyone with this issue to report it to VW Customer CARE so they have it on the official record: 800-822-8987.
    20. Member rich!'s Avatar
      Feb 18th, 1999
      SoFLA
      '12 Touareg TDI, '14 CC
      05-01-2012 01:18 PM #20
      haven't noticed (rarely listen to radio) but we have a number of HD stations nearby; i'll see if i can't replicate it. same issue with cds/mp3/etc?
      have you tried talking to the regional rep (can't say i get along with ours ) or touareg executive customer service?
      FireVortex (sorry, no more)... bunch of VWs.
      I came back for #Dieselgate
    21. Junior Member Eugene-Dave-1's Avatar
      Apr 18th, 2012
      05-01-2012 01:55 PM #21
      Quote Originally Posted by rich! View Post
      My RNS-850 seems to work fine with every audio source except HD Radio.
      I have met with the VW district Quality Technical Manager. He was humoring me by agreeing to talk to me, but he could not figure out what I was complaining about. I honestly don't think he knows the difference between "stereo" and "monaural" (mono) nor could he tell the difference when listening. When I pointed out to him that I had an RNS-510 in my 2011 Tiguan and it worked FINE with HD Radio, and asked him why I would say the 510 works but the 850 doesn't, he had no response. *shrug*
      Is Touareg Executive Service for Exec owners only? Or can any Touareg owner talk to them? I've only been going through VW Customer CARE.
    22. Member
      Jun 12th, 2011
      Western Kentucky
      05-01-2012 02:10 PM #22
      I was contacted by phone and by mail - by Touareg Executive Service immediately after purchasing my 2011 TDI Sport last May. They called again after the 90 day courtesy inspection and after the 10K service. Seems pretty clear to me - that it's the Touareg part that counts, not the trim level. Perhaps the selling dealer failed to inform TEG when you purchased yours.
      It's my intention to lay my monaural issue on them, and I can't help but think they'd be of more assistance than the customer service overlord. Perhaps you should give them a call and let them know you own a new Touareg. The number I use is 1-877-589-4928
      //greg//
    23. Junior Member Eugene-Dave-1's Avatar
      Apr 18th, 2012
      05-31-2012 09:49 PM #23
      Apologies for posting the same thing on multiple boards but I'm on a quest now to get the word out on this...
      Update: VWoA now says my problem is weak reception, there is no problem with the RNS-850, too bad, turn off (disable) HD Radio if you don't like it. It's as if they paid no attention whatsoever to my explanation of the problem, which has absolutely nothing to do with weak reception.
      I am very persistent about such things and I am not giving up. It may take time but I honestly think that now that VWoA is knowingly selling luxury SUVs with a defective RNS-850 head unit, they have set themselves up for some expensive legal liability.
      Hint: Google "hd radio farce". If you think your RNS-850 has the HD Radio defect I've described (in great detail including an audio/video demonstration), get your name on the record. It may take a couple years but eventually we will get something from this even if it's just cash instead of what I really want which is an RNS-850 that works correctly.
    24. Member
      Jun 14th, 2005
      Mt Pleasant, SC
      11 TDI Lux, cool silver/anthracite,11 Mazda CX-9 GT, 10 KTM 200 XCW, 11 KTM 250 XCF
      06-10-2012 01:18 AM #24
      Quote Originally Posted by VW/Porsche Fahrer View Post
      Same here, mine works fine in all modes. Even used my trusty pink noise generator to measure frequency on both channels. I'm an old audiophile and always aware of "real" stereo. A good test is to play new and old music by Santana. Definite left and right separation on his guitar solos. Please note that a car is not a great environment for audiophile quality music. Stereo separation over the air is 20dbs at best on FM. Practically all music played over radio stations is digital and compressed to gain storage capacity so stereo and dynamic range suffers. Music will sound more mono now. Music from older CDs will always sound better than MP3 or any other digital media that compress the sound.
    25. Junior Member Eugene-Dave-1's Avatar
      Apr 18th, 2012
      08-11-2012 11:18 PM #25
      I made a new video using an oscilloscope to demonstrate the problem visually:
      http://www.youtube.com/watch?v=7d6QCZbO2UU
      Sorry for posting on multiple boards but I want to get the word out.
