VWVortex.com - 80K
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 48
    Thread: 80K
    1. 04-18-2012 01:10 PM #1
      Hey guys,
      My dealer talked me out of doing all the flushes for my 80K and concentrating more on changing the timing belt. I have a 2006 FSI 2.0t.
      Do you guys agree with that? I will just do oil and filte change and then the whole timingbelt change (and hopefulle swap out the cam follower).
      Too early? Thoughts?
    2. Member Vinnyty's Avatar
      Mar 19th, 2008
      Derry, NH
      2013 Jetta TDI
      04-18-2012 01:22 PM #2
      Nope 80k is being very safe. 90k is pushing it 100k is really really pushing it.
      07 B6 Passat 2.0 turbo - http://unitronic.ca Unitronic Stage 2 HPFP - High flow cat downpipe 3" - ABD Racingwerks intake Stage 2 - HPFPUpgrade.com Stage 1 HPFP - 142 Bar fuel Pressure relief valve - 5 zigen Oil catch tank - Autotech 3" catback - Adams Rotors - H&R Springs teamed with Bilstein Sports.
      http://i51.tinypic.com/153w51g.png
    3. Member BlackJelli's Avatar
      Jul 26th, 2002
      atl
      '07 B6 6MT, '05 V70R, '84 RZ350
      04-18-2012 01:30 PM #3
      I did mine at 90K. I have not heard of the belt failing before 100K so you should be okay up to that point.
      thankyouverymuch
    4. 04-18-2012 01:44 PM #4
      Thanks. They should be able to swap the cam follower really easily now right?
    5. 04-18-2012 04:30 PM #5
      Quote Originally Posted by joakim6945 View Post
      I would be interested in that as well. I'm at 85K now and would like to do my timing belt, tensioner, water pump, cam follower, and this ignition service kit (http://www.ecstuning.com/Volkswagen-...ion/ES2535339/)
      I have heard that the water pump axel is plastic and prone to breaking at 100+ miles. Is this true or a rumor?
      Also, has anybody done an ignition service kit? Is it needed at that point?
    6. Member nodashi's Avatar
      Mar 20th, 2012
      Whidbey Island, WA
      2006 FSI 2.0t Passat
      04-18-2012 04:34 PM #6
      Quote Originally Posted by Cranford803 View Post
      well i do need to change out my spark plugs... might as well change out the coils.
      Oct 14th, 2008
      '07 Passat 3.6 4mo wagon; '05 GLS 4mo wagon
      04-18-2012 04:53 PM #7
      Keep in mind that age and weather conditions play a role in the acutal belt deteriorating as much as mileage. Maybe I've been conservative but I never let 'em age past 7 years if the mileage hasn't been met.
      An audi tech I know made the recommendation a few years ago.
    8. 04-18-2012 05:10 PM #8
      Thats what my rep told me today. Due to the heat in TX the belt will galvanize at a quicker rate than in colder climates. I think the rep also said that they replace the waterpump when replacing the time belt. Does anybody know if this is true?
      Sep 29th, 2007
      Santa Clarita
      06 Passat
      04-18-2012 06:53 PM #9
      Yeah definitely replace the water pump.
    10. Member Weelildubb2.0t's Avatar
      Apr 19th, 2007
      The Sticks, CT
      B6 Passat 2.0 Turbo
      04-18-2012 09:06 PM #10
      Yea replace the water pump and try getting a metal water pump, I think the oem ones are plastic, you can get a whole kit online
    11. Junior Member
      Mar 7th, 2012
      Denton, TX
      2008 Passat Lux wagon FSI auto; also Volvo 1800ES
      04-18-2012 09:41 PM #11
      You might rethink the transmission fluid change. Most posts on all the sites recommend changing tranny fluid and filter at 40k miles. the dealers in the Dallas area all told me it's "lifetime" but I'm changing mine at 43k as a precaution.
      The 6-speed trans is not bullet-proof, so you might have them do the fluid change, too.
      I imaging others will want to weigh in on this . . .
    12. 04-18-2012 11:11 PM #12
      Yeah I actually asked about the transmission oil today, but the guy at Metro VW told me it was not neccessary. What is cool is that they are giving me a loaner for this service. At 80K! Pretty cool. I have never had a problem with Metro VW in Irving.
      What is weird is that I thought he said that they were going to change the water pump as part of this services, but I must have misunderstood. That would be too good to be true.
    13. Member indyb6's Avatar
      Sep 7th, 2011
      Pittsburgh, PA
      '12 WRX, '13 Mazda3 Skyactiv, 08 Passat FSI 2.0T
      04-18-2012 11:12 PM #13
      How much did they quote you for all this?
    14. Member
      Aug 10th, 2011
      2012 Jetta SE
      04-18-2012 11:14 PM #14
      Everything I have seen in the manual says 120k for timing belt.
      Sent from my iPad using Tapatalk HD
    15. Member Weelildubb2.0t's Avatar
      Apr 19th, 2007
      The Sticks, CT
      B6 Passat 2.0 Turbo
      04-19-2012 11:23 AM #15
      From what I hear with the tranny fluid is it started out as a never needed service and they changed that to service at every 80k (filter and fluid change)
      With the timing belt I wouldn't wait to 120k I did mine at 80k, just a peace of mind I guess
    16. 04-19-2012 02:57 PM #16
      They said it would $880 for my timing belt service alone. i doubt that includes a water pump, right?
    17. Member
      Sep 16th, 2001
      Ottawa
      B6 Wagon 2.0T FSI
      04-19-2012 04:04 PM #17
      I just posted this on PW, hope to share with you
      Little back ground for my car:
      2008 Passat wagon 2.0T Auto, bought used 5 months ago at 98000km mileage, all stock.
      Bring the car(105k km mileage) to my friendly indy for timing belt change, transmission fluid and filter change, cam follower change.(paid CAD$1100,very good deal I would say)
      While he ordering the parts, he said VW parts department not recommend change the trans fluid and cam follower. Which he told me today that the old trans fluid is black in colour and he try hard to get all fluid out for me(7 liters), the cam follower already have no top. lucky, he said no harm has done to the pump and cam. check the picture, I will have my next cam follower at 4-50000km
      Also, I have a CEL now for V201, I assume it is for the a/c system but how can it make my CEL? Also, the a/c temp dial work as it should be(climatic semi-auto system), anyone can help with this?
      97 Ford Contour V6, 96 Aristo Turbo, 97 S600, 98 540i, 2000 ES300, 2000 Aristo 161 Turbo, 2003 CL500, 2005 Skyline 350GT, 2002 Passat 4 motion, 2000 Civic DX, 2003 Ford Focus wagon, 2008 Passat Wagon 2.0T
    18. Member vw_nc_dude's Avatar
      Jan 29th, 2012
      NC, USA
      VW Mk2 Tiguan TSI, VW Mk7 Golf TSI
      04-19-2012 04:07 PM #18
      Hey guys,
      Definitely would do the belt change at 80K. I had a timing belt go bad on a different car and had to pay the price. 80K is a good point.
    19. Member vw_nc_dude's Avatar
      Jan 29th, 2012
      NC, USA
      04-19-2012 04:09 PM #19
      Quote Originally Posted by Ronstanley View Post
      Isn't the 40K tranny service recommended for DSG only? Did not hear before that we need it for our Aisin 6-speed tranny.
    20. 04-19-2012 04:56 PM #20
      Any thoughts about how much a new water pump usually runs?
    21. Member Vinnyty's Avatar
      Mar 19th, 2008
      Derry, NH
      2013 Jetta TDI
      04-19-2012 04:59 PM #21
      I picked up my "metal impeler" water pump on ecs for abour $65 shipped. FCPeuro.com has good pricing as well.
    22. Member Code Red!'s Avatar
      Sep 22nd, 2011
      deep down, in places you don't talk about at parties
      Gee oh elle eff, Vee oh elle tea
      04-19-2012 05:10 PM #22
      Quote Originally Posted by vw_nc_dude View Post
      This was the older process from VW but they've updated it to now say the tiptronic needs servicing at 40k / 80k / etc
    23. Member vw_nc_dude's Avatar
      Jan 29th, 2012
      NC, USA
      04-19-2012 05:19 PM #23
      Quote Originally Posted by coderedcomputing View Post
      Hmm, I did my 40K service at the VW dealer last month and they did not mention this
      Is this something very recent? Do you have a link or pointer to this updated service schedule?
    24. 04-19-2012 05:31 PM #24
      yeah, I asked my dealer this too yesterday and he was like "nope, there is lifetime oil in these transmissions. Nothing needs to be done".
    25. Member
      Oct 14th, 2008
      04-19-2012 07:14 PM #25
      A timing belt job should include the water pump, thermostat and some other accessories. Check out the full timing belt kit at ECS tuning.
