VWVortex.com - Air in supply line coming from injection pump right after being shut down. 1.6na
    Results 1 to 12 of 12
    Thread: Air in supply line coming from injection pump right after being shut down. 1.6na
      Nov 6th, 2006
      Gettysburg Pa
      81 VW Diesel caddy, 86 VW Cabriolet
      04-18-2012 03:46 PM #1
      Got a clear line on the supply line to the injection pump to make sure there is no air in the causing my issues of rough idle. Got the truck started and running and got fuel going through the line and watched it to see if it was leaking any air in to the line both at idle and under acceleration. There was no air in the line while running so nothing was sucking air. When i shut the truck down air comes out of the pump and the fuel moves about four inches away from the inlet back to the filter and stopped. I was wondering if this is normal as i have never had a clear portion of line on the truck. I had to leave right after shutting the truck down so i do not know if it moved any more i am going over to check shortly. Could there be a like in the injection pump itself allowing air to get in to the fuel and cause the rough idle and the air to go in to the line when shut down. The truck also takes a couple cranks more than it use to to get it started. The engine is rebuilt and awaiting a compression tester to check and make sure the compressions good. Any help will be great. thanks in advance
      Jul 14th, 2011
      outside philadelphia
      '86 mk2 D/ '86 mk2 D '98 TDI
      04-18-2012 10:20 PM #2
      sounds like the air in your system is the main problem and that it is abormal, solve it first and then you may have no problems.
      Type I's
      the "little" D
      also 962 -0 to 60 in 4 years-
      why??more than 1 wire to shut her off?? a blasphemy!
      Jul 14th, 2011
      04-18-2012 10:25 PM #3
      open upper timing cover and see if its wet near inj pump, turn engine small amount so a big 'hole' in inj pump gear is down and get a light on 'it'. also change fuel filter?? check all connections of fuel filter are snug, and 1 screw on top is tight and bottom is snug too. cracks in line feeding ip? hope not.
      Type I's
      the "little" D
    4. Member Rockerchick's Avatar
      May 10th, 2005
      Cary, NC
      '03 BMP 20th GTI, '84 TD Jetta
      04-18-2012 10:31 PM #4
      So a 4" bubble? That seems a little much. We get a small bubble every now and then on our TD but doesn't seem to affect starting or anything. When we had larger and more bubbles before the rebuild though, it was a bit rough.
      Make sure all of your connections are tight at the fuel filter and IP. Was the IP rebuilt as well?
      Quote Originally Posted by TM87 View Post
      VW-making mechanics out of owners since 1957.
      The project - '84 Jetta 1.6TD
      The Wheelbarrow - '82 Rabbit Pickup
      Hers - '03 BMP 20thAE GTI
      His - '16 GLI SE
      Nov 6th, 2006
      Gettysburg Pa
      04-19-2012 08:28 AM #5
      It was about three years ago when i bought it. Took it off the truck for about a month to rebuild the engine and now i have this issue with the truck. I am awaiting my compression tester to try and rule out the engine having low compression. I did have the truck running with no air in the supply line until i shut it down. My worry is the pump is sucking air through a seal causing the rough idle and the air to come from the pump in to the supply line.
    6. Member
      Jul 14th, 2011
      04-19-2012 11:23 AM #6
      right; only you may have to remove gear to see leak, dont do it with out knowing how to do it!
      turn motor over and look thru big openings of gear maybe you can see moist made by a possible leak, use a light and look at bottom esp
      Type I's
      the "little" D
      Mar 31st, 2008
      PNW - Oregon
      04-19-2012 01:35 PM #7
      Quote Originally Posted by air-cooled or diesel View Post
      dont listen to this guy, hes wrong!
      its an air leak somewhere..
      could be coming from your feed/return lines, or from your pump input shaft seal..
      Nov 6th, 2006
      Gettysburg Pa
      04-19-2012 01:41 PM #8
      I will check my return lines as i did not think they matter much on air getting in. I thought it was just the supply line. I will check those. If no change and i find out my engine has proper compression then i will just order another pump. I have had pumps leak diesel but run fine. Never had on that doesnt leak that i know of but runs like crap. Oh well i will stick with it. I am bound to fix it at some point lol. Thanks for the help folks
      Jul 14th, 2011
      04-19-2012 02:00 PM #9
      Quote Originally Posted by Glegor View Post
      how am i wrong you practically said same thing
      Type I's
      the "little" D
    10. Member
      Jul 14th, 2011
      04-19-2012 02:06 PM #10
      bottom of pump thru a big 'hole' in gear
      Type I's
      the "little" D
    11. 04-20-2012 07:37 AM #11
      I used to get air in my lines after I got my 1.6D (running no less) and found when doing a tune up that the PO had replaced the fuel filter and didn't notice the o-ring didn't come off the first filter. Basically the o-ring in the center was double stacked so the outer one wouldn't seal. I've heard this isn't uncommon for people to have done this.
    12. Junior Member
      Oct 24th, 2011
      Gloversville, NY
      1981 rabbit diesel, 4 door and 2 door
      10-06-2012 01:33 PM #12
      i'm having the same issue. i put on a different injector pump and replaced all the return lines last night. problem is now worse. did you find out anything?
