Member
mk2 tail light blinker problem
04-18-2012 07:30 PM
#1
so my tail light blinkers work until i turn on my headlights then they go out. whats up with that?
Member
04-18-2012 11:11 PM
#2
ok so the problem was the bulbs that came with my new smoked turn signals. check this out.
http://forums.vwvortex.com/showthrea...ght=tail+light
same problem
04-19-2012 10:34 AM
#3
I have the same problem on an '06 Jetta 2.5. If you turn your lights off and then on again do they work, and if so do the signals go out when you press your brake?
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
Forum Rules
