Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 71
Thread: Blitz BRW 02 16x9.5 +0 4x100/114.3
  1. 04-18-2012 08:14 PM #1
    Center/first step is gunmetal, outter barrel/inner is flat black
    $3200 OBO
    This isn't your run of the mill step lip rebarrel as we used a "half step" from the original Blitz barrel as well; so these wheels are a stepped lip and a half.. or something..
    16x9.5 +0.....
    msg me @ 949 385 1504
    CACKYWHEELS
    WHEEL REFINISH SPECIALIST
  2. 04-19-2012 07:21 PM #2
    ray bans for 55 bucks what it do http://bit.ly/HLO7Dw
    CACKYWHEELS
  3. 04-20-2012 12:13 AM #3
    Hello
    I am interested in buying the Blitz BRW 02 16x9.5 +0 4x100/114.3 that you have placed for sale, and I would want to know about the present condition, as well as some detail about you. I expect this timely enough.
    As for the payment, I would need you to get back in touch with the last asking price then I get a Cheque or Or Moder sent.
    Would you please reply back to me at: automiles01@aol.com
    I will be looking forward to hear from you soon.
    Yours interestingly,
    Raymond Griffith
    CACKYWHEELS
  4. 04-20-2012 02:51 PM #4
    CACKYWHEELS
  5. 04-21-2012 08:25 PM #5
    54312354314537655341654531
    CACKYWHEELS
  6. 04-24-2012 06:41 PM #6
    will trade for 15" te37 ce28 regamasters cp-fs ssr type-c other monoblocks.. preferably forged..
    CACKYWHEELS
  7. 04-25-2012 09:01 PM #7
    I don't understand the pricing, care to further explain the work put into these?
  8. 04-25-2012 09:35 PM #8
    Wheels were rebarreled, while also using part of the original Blitz barrel..
    I bought four new barrels.. Barrels are what you see on the outter part of the wheel.. Not including the mesh you see in the center.. Those are called centers.
    Since the centers were not large enough to just weld into the new barrel, I used part of the original barrel that the centers came on from the factory. I had them cut at the first step, and welded into the new barrels that I purchased in the beginning of my post.
    I then had the lug holes (where you mount the wheels to your car using the studs/lugnuts/etc) filled and drilled so that they would be 4x100 and 4x114.3 (100mm and 114.3mm so that the wheels are now two different bolt patterns, allowing them to fit on a wider range of cars).
    The wheels were then stripped (stripping is the process of taking all the pre existing paints/plating/powder/etc off) and powdercoated (this is a process in which you shoot powder to an electronically charged metal object, and then baking) the wheels. I'm having the barrels (again, the outter part of the wheels up until the mesh center) painted over in matte black (color)
    Hope this helps
    CACKYWHEELS
  9. 04-28-2012 04:09 PM #9
    definiately appreciate the reply.
    I was sure there was severe work done to this set, just not use to seeing this pricing on a single piece wheel. very labor intensive & I dig the amount of heart involved.
    free bumps.
  10. 04-28-2012 07:00 PM #10
    This is actually a 2pc welded wheel.. Easy to break the weld and do as you please, like I did already.. Actually this is now a 3pc welded wheel since the face is welded into the first barrel which is then welded into the new 16" barrel..
    But yeah you're not gonna find many people who can even do this type of work
    CACKYWHEELS
  11. 05-03-2012 03:12 AM #11
    17x8 35 17x9 38 regamaster EVO and 18x9.5 18x10.5 10 ssr vienna on the way
    CACKYWHEELS
  12. 05-05-2012 02:21 PM #12
    rewrew
    CACKYWHEELS
  13. 05-09-2012 11:11 PM #13
    gondiddy
    CACKYWHEELS
  14. Member absentee's Avatar
    Jun 26th, 2010
    SEPA - the 717
    81 Rabbit TD
    05-10-2012 03:06 PM #14
    This is the most unorthodox thread that i have ever read... "Easy to break the weld and do as you please" 3200$ wheels that break easily? whaaaa?
    Im sick of typical... 81 TD Rabbit LE19: Bugsy
  15. 05-10-2012 04:32 PM #15
    Haha if you don't know anything about wheel customization then please go do some research.
    When changing the offset / rebarreling / etc you always take the welds off and reweld
    CACKYWHEELS
  16. 05-18-2012 04:42 PM #16
    should be updating with new pictures this week.
    CACKYWHEELS
  17. 05-22-2012 06:00 PM #17
    234234
    CACKYWHEELS
  18. 05-25-2012 12:27 AM #18
    rewrew
    CACKYWHEELS
  19. 05-28-2012 03:52 AM #19
    r32r32
    CACKYWHEELS
  20. 05-30-2012 07:53 PM #20
    sasasa
    CACKYWHEELS
  21. 06-05-2012 04:48 PM #21
    1234567896
    CACKYWHEELS
  22. 06-11-2012 12:50 AM #22
    dewqf4t5g5443
    CACKYWHEELS
  23. 06-14-2012 09:15 PM #23
    r3r32r32
    CACKYWHEELS
  24. 06-18-2012 02:49 PM #24
    Running of the bulls
    CACKYWHEELS
  25. 06-25-2012 07:09 PM #25
    321321
    CACKYWHEELS
  26. 06-26-2012 08:46 PM #26
    CACKYWHEELS
  27. 07-01-2012 07:08 PM #27
    r32r32r32
    CACKYWHEELS
  28. 07-03-2012 09:53 PM #28
    rewrewrew
    CACKYWHEELS
  29. 07-06-2012 02:12 PM #29
    gregregre
    CACKYWHEELS
  30. 07-11-2012 12:22 AM #30
    dewt534543
    CACKYWHEELS
  31. 07-17-2012 12:34 AM #31
    45132554435y564153
    CACKYWHEELS
  32. 07-20-2012 06:17 PM #32
    Tomto2243
    CACKYWHEELS
  33. 07-22-2012 12:03 AM #33
    CACKYWHEELS
  34. 07-25-2012 06:35 PM #34
    dsdsds
    CACKYWHEELS
  35. 07-28-2012 03:44 PM #35
    t435437654654
    CACKYWHEELS
