VWVortex.com - checking deck
    Results 1 to 6 of 6
    Thread: checking deck
    1. Member ewillard's Avatar
      Apr 21st, 2007
      Lewisberry PA
      1990 16VT CORRADO (500WHP), 2013 Q7, 1976 GMC PICKUP
      04-18-2012 09:25 PM #1
      Can any one explain to me how to tell how much a head has been decked. I'm looking at getting another head and want to make sure it hasent been deck to far. I have a abf rep motor with 159mm and 9:1 comp wosner pistions. I don't want to buy a head and put it on and relize the piston to valve clerence is off.
      Quote Originally Posted by VR6W8 View Post
      Is it a sickness? Yeah, I think so. Why I still tinker with it, and still own it, I have no idea really.
      my build thread pic heavy click for Corrado Bentley PDF
    2. Member Jones84's Avatar
      Sep 6th, 2007
      Gresham Oregon
      84 GTI 2.0 High comp 16vT on MegaSquirt, 00 Subaru Outback
      04-19-2012 01:33 AM #2
      On the Intake valves, it sits just below the head. Not much but if you use your head as a reference and measure how much is there you can get a idea of how much has been taken.
      You can also just look at it and tell most of the time. Any head i have ever had done, the shop will stamp or mark it.
      84 Rabbit GTI, 12.1.1 comp 16VT, 15psi 307whp 278wtq Winner 2012 bugRun Pro class
      JONES PERFORMANCE VW, Swaps, Custom Builds, MS install & tuning. MK1, MK2, Specialists
      2vwjones@gmail.com Website under construction.
    3. Member sdezego's Avatar
      Apr 23rd, 2004
      Hurricane Central FL
      '90 Corrado | '62 Harley Panhead
      04-20-2012 04:27 PM #3
      If there has beed valve work (likely if the head was shaved) you will get inaccurate results.
      The best thing is to measure from the Valve cover Gasket surface to the bottom (or from the Head bolt seat through the hole to the bottom.
    4. Member Geereg's Avatar
      May 8th, 2010
      RWC
      1985 GTI RIP B4 Varaint, RIP B5 Variant, 88GTI, 97GTI
      04-24-2012 02:45 AM #4
      VW states the minimum 16v cylinder head thickness From the head bolt surface to the cylinder head deck surface is 136.00 mm!
    5. Member ewillard's Avatar
      Apr 21st, 2007
      Lewisberry PA
      04-24-2012 03:18 AM #5
      Quote Originally Posted by Geereg View Post
      Thank you that is just whatvi needed
    6. Member Geereg's Avatar
      May 8th, 2010
      RWC
      07-17-2012 11:23 PM #6
      Quote Originally Posted by ewillard View Post
