Page 1 of 7 1 2 3 4 5 ... LastLast
Results 1 to 35 of 215
Thread: Mk4 Wheel Offset and Stance Picture Index
  1. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    Car that looks good from afar.
    04-18-2012 09:46 PM #1
    So it's obvious that many users (including myself) ask for help on offsets and mk4's. Thankfully, there is now a stickied thread where people can get advice and suggestions from others. But, what may be equally as helpful is seeing pictures of those wheel and offset specs. This thread is the solution to that.
    Essentially, this thread will be used as an index/glossary/lookup containing wheel information and photos of mk4's. Below you you will see a list of wheel sizes by diameter and width. Within each section will be hotlinks to other posts in this thread grouped by Offset. See below for a scenario:
    If you want to know what an 18x8.5 et35 looks like you can look in the list and click on any links you find in the "18x8.5" section listed as "et35" to be taken to those posts. Boom, done!
    NOTE: This thread is NOT for making comments or asking wheel/offset/tire questions. If you need help with anything along those lines, please post in the Mk. IV Offsets and Tire Sizes Request Thread.
    The more people that contribute, the more this thread will grow and be useful. Even if your same specs have been posted for another user's car or you're just running steelies that are spaced out, post anyway. The more the merrier!
    If you'd like to contribute, please use the Template below. I will modify the glossary as often as possible with a hotlink to your post for others to view. Also, PLEASE double check your specs are correct and contain no typos before submitting. That will help prevent incorrect hotlinks after I add your post to the index. Thank you!
    Template: (replace the italicized text with your information)
    Front: WheelDiameter x WheelWidth etFinalOffset TireSpecs
    Rear: WheelDiameter x WheelWidth etFinalOffset TireSpecs
    Fenders Rolled: Yes/No
    Fenders Pulled: Yes/No
    (Then please include pictures of your car at good angles, side-shots may not be the most helpful. Close-ups of just the fender and wheel or also distant shots showing the car as a whole may work better.)
    Example:
    Front: 18x8.5 et30 215/40/18
    Rear: 18x9.5 et30 225/40/18
    Fenders Rolled: Yes
    Fenders Pulled: Yes
    (images would then be posted here under the specs)
    Let's make this work and thanks to everyone for helping out
    ** 15" Wheels **
    15x6
    et35 --> Front & Rear - Clean PG
    15x6.5
    ** 16" Wheels **
    16x6.5
    et22 --> Rear - TheColbster
    et22 --> Rear - Blackwolf15
    et27 --> Front - TheColbster
    et27 --> Front - ak47tdi
    et27 --> Rear - ak47tdi
    et27 --> Front - Blackwolf15
    et32 --> Front - Blackwolf15
    et32 --> Rear - Blackwolf15
    16x7
    16x7.5
    16x8
    ** 17" Wheels **
    17x7
    et18 --> Front & Rear - mk3_vdub
    et18 --> Rear - BIG_TNZ
    et38 --> Front - BIG_TNZ
    17x7.5
    et12 --> Rear - im_lower
    et17 --> Rear - Pssst...passedyou
    et17 --> Rear - amotion578
    et18 --> Rear - Kampy
    et20 --> Rear - bluebora20v
    et22 --> Front - im_lower
    et22 --> Front - amotion578
    et24 --> Front - Pssst...passedyou
    et26 --> Front - Kampy
    et27 --> Front - bluebora20v
    17x8
    et4 --> Front - j-man41
    et5 --> Front - DFWSKATE
    et10 --> Front - Twilliams83
    et10 --> Front - YNO WGN
    et12 --> Front - sikknasty28
    17x8.5
    et5 --> Front - Bazmcc
    et7 --> Front - GaugeDoisher
    et13 --> Front - Tradethedeadx
    et17 --> Rear - DubGirl13
    et18 --> Front - Mitch_2.slow
    et18 --> Rear - Mitch_2.slow
    et18 --> Front - __Rac3T!g3R
    et19 --> Front - .Ant
    et21 --> Front - Brah
    et23 --> Front - DubGirl13
    et23 --> Front - Bora_Azul
    et23 --> Front - mk-4-ever
    et28 --> Front - Tradethedeadx
    et30 --> Front - scirockalot8v
    17x9
    et0 --> Front - sikknasty28
    et8 --> Rear - j-man41
    et14 --> Rear - Radvr6T
    et17 --> Rear - Twilliams83
    et18 --> Rear - sikknasty28
    et19 --> Rear - sikknasty28
    et20 --> Rear - YNO WGN
    et23 --> Front - Mikey Pants
    et23 --> Front - __Rac3T!g3R
    et25 --> Rear - DFWSKATE
    et25 --> Front - Radvr6T
    17x9.25
    et20 --> Front - dburg123
    17x9.5
    et13 --> Rear - Tradethedeadx
    et18 --> Front - Bierce IV
    et18 --> Front - DZ_p
    et19 --> Rear - dopesauce
    et20 --> Rear - __Rac3T!g3R
    et21 --> Front - dopesauce
    et23 --> Rear - Bierce IV
    et23 --> Rear - Bora_Azul
    et23 --> Front - _Dirty_
    et23 --> Rear - __Rac3T!g3R
    et25 --> Rear - .Ant
    et36 --> Rear - Tradethedeadx
    17x10
    et19 --> Rear - _Dirty_
    et19 --> Rear - dburg123
    et20 --> Front - blue bags
    et20 --> Rear - Bazmcc
    et20 --> Rear - GaugeDoisher
    et23 --> Rear - Mikey Pants
    et30 --> Rear - scirockalot8v
    et35 --> Rear - Brah
    17x10.5
    et22 --> Rear - blue bags
    17x11
    et28 --> Rear - DZ_p
    ** continued below **
    || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
    || Please don't PM me with offset questions, post in THIS THREAD instead ||
    Don't ever support KOCOUREK WAUSAU IMPORTS of Wausau, WI
  2. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-18-2012 09:46 PM #2
    ** 18" Wheels **
    18x7.5
    et2 --> Rear - tonyb2580
    et15 --> Rear - BIG_TNZ
    et20 --> Rear - SB_GLI
    et20 --> Rear - klove614
    et20.5 --> Rear - Slvrjet
    et22 --> Front - tonyb2580
    et23 --> Rear - ogkhaze
    et23 --> Front - klove614
    et25 --> Front - ak47tdi
    et28 --> Front - Slvrjet
    et30 --> Front - ogkhaze
    et35 --> Front - SB_GLI
    et35 --> Front - BIG_TNZ
    18x8
    et10 --> Rear - mini man
    et15 --> Front - mini man
    et15 --> Rear - DubGirl13
    et17 --> Front - Tradethedeadx
    et18 --> Front - daily_dubber
    et18 --> Front - Tradethedeadx
    et22 --> Front - mk-4-ever
    et27 --> Rear - Vdub407
    et32 --> Front - Vdub407
    18x8.5
    et11.65 --> Front - RG.Jeff
    et14 --> Front - tonyb2580
    et15 --> Front - Clean PG
    et15 --> Rear - xcrunnr93
    et15 --> Front - livinzlyfe
    et15 --> Front - eastcoaststeeze
    et15 --> Rear - Chris Anderson
    et15 --> Front - jordanu
    et15 --> Rear - Blackwolf15
    et19 --> Front - subisan
    et20 --> Front - xcrunnr93
    et20 --> Front - euro+tuner
    et20 --> Front - vjg1215
    et20 --> Front - Chris Anderson
    et20 --> Rear - Chris Anderson
    et20 --> Front - codergfx
    et22 --> Front - R32 1518
    et22.5 --> Front - xjasongli814x
    et23 --> Front - Pitty
    et23 --> Front - Schumey
    et24 --> Front - agentmaddock
    et24 --> Front - 87vr6
    et25 --> Rear - Billburt
    et25 --> Front - strumski
    et25 --> Front - Markg813
    et25 --> Front - Blackwolf15
    et25 --> Front - JrJanowski
    et25 --> Front - shanewoodworth
    et28 --> Front - 87vr6
    et29 --> Front - 87vr6
    et30 --> Front - Billburt
    et30 --> Front - Blackwolf15
    et30 --> Rear - Blackwolf15
    et35 --> Front - shanewoodworth
    et35 --> Front - Chris Anderson
    18x8.75
    et20 --> Front - wagner17
    et20 --> Rear - wagner17
    et20 --> Front - sincitygti
    et20 --> Front - Myerss
    et20 --> Rear - Myerss
    et22 --> Rear - sincitygti
    18x9
    et6 --> Rear - Tradethedeadx
    et17 --> Front - ohiodub_99.5
    et18 --> Front - livinzlyfe
    et21 --> Front - liquide
    et21 --> Rear - daily_dubber
    18x9.5
    et14 --> Rear - subisan
    et16 --> Rear - ohiodub_99.5
    et18 --> Front - wagner17
    et20 --> Rear - Clean PG
    et20 --> Front - Spaceboy05
    et20 --> Rear - Spaceboy05
    et20 --> Front - klove614
    et21 --> Front - mk-4-ever
    et22 --> Front - eastcoaststeeze
    et22 --> Rear - RDIRTYTOO
    et22.5 --> Rear- xjasongli814x
    et23 --> Rear - Pitty
    et23 --> Front - MARK3GTIVR6
    et23 --> Rear - klove614
    et24 --> Front - RDIRTYTOO
    et25 --> Rear - vjg1215
    et25 --> Rear - jordanu
    et25 --> Rear - codergfx
    et26 --> Rear - tonyb2580
    et28 --> Rear - MARK3GTIVR6
    et28 --> Rear - mk-4-ever
    et28 --> Rear - 87vr6
    et30 --> Rear - agentmaddock
    et30 --> Rear - shanewoodworth
    et30 --> Rear - Schumey
    et35 --> Rear - euro+tuner
    18x10
    et13 --> Rear - eastcoaststeeze
    et13 --> Front - Spaceboy05
    et18 --> Rear - R32 1518
    et18 --> Rear - Spaceboy05
    et22 --> Rear - JrJanowski
    et23 --> Rear - livinzlyfe
    et23 --> Rear - RG.Jeff
    et23 --> Rear - mk-4-ever
    et28 --> Rear - liquide
    et30 --> Rear - livinzlyfe
    et30 --> Rear - 87vr6
    et32 --> Rear - strumski
    et32 --> Rear - Markg813
    et35 --> Rear - ak47tdi
    18x10.5
    et14 --> Rear - mk-4-ever
    et20 --> Rear - eastcoaststeeze
    et34 --> Rear - Schumey
    ** 19" Wheels **
    19x8
    et27 --> Front - foundubbedriver
    et27 --> Front - Dubguy21
    19x8.5
    et10 --> Rear - milwaukeeandy
    et20 --> Front - milwaukeeandy
    et25 --> Front - dubberscrubber
    19x9
    et25 --> Rear - ak47tdi
    et30 --> Front - ak47tdi
    19x9.5
    et15 --> Rear - dubberscrubber
    et31 --> Rear - foundubbedriver
    et31 --> Front - Dubguy21
  3. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-18-2012 09:47 PM #3
    Front: 18x8.5 et15 215/40/18
    Rear: 18x9.5 et20 225/40/18
    Fenders Rolled: Yes
    Fenders Pulled: Yes
  4. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-18-2012 09:47 PM #4
    Front: 18x7.5 et35 225/40/18
    Rear: 18x7.5 et20 225/40/18
    Fenders Rolled: No
    Fenders Pulled: No
  5. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-18-2012 09:48 PM #5
    Front: 18x7.5 et30 225/40/18
    Rear: 18x7.5 et23 225/40/18
    Fenders Rolled: Yes
    Fenders Pulled: No
  6. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-18-2012 09:48 PM #6
    Front: 15x6 et35 195/65/15
    Rear: 15x6 et35 195/65/15
    Fenders Rolled: Yes
    Fenders Pulled: Yes
  7. Member Twilliams83's Avatar
    Jan 24th, 2011
    Wildomar, CA
    04-18-2012 10:12 PM #7
    Front: 17 x 8 et 10 205/45
    Rear: 17 x 9 et 17 205/45
    Fenders Rolled: Yes
    Fenders Pulled: No
    Untitled by todd williams 83, on Flickr
    from tonight by todd williams 83, on Flickr
    Hella4¯\_(ツ)_/¯ My Flickr
  8. Member xcrunnr93's Avatar
    Sep 6th, 2009
    Fredericksburg, VA (UMW)
    a mark4
    04-18-2012 10:41 PM #8
    Front: 18x8.5 et20 225/40/18
    Rear: 18x8.5 et15 225/40/18
    Fenders Rolled: No
    Fenders Pulled: No
    University of Mary Washington| My Flickr | My OEM+ Build Thread
    Quote Originally Posted by bryanboley View Post
    did you go full retard on purpose or was it an accident?
  9. Member Tcatt's Avatar
    Jun 12th, 2006
    Beer Drinking State
    2002 VW Golf GTI
    04-19-2012 12:44 AM #9
    Front 17x7 et 38 235/45/17
    Rear 17x7 et 18 235/45/17
    Fenders Rolled: No
    Fenders Pulled: No
    Relax, i'm from Wisconsin
  10. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-19-2012 12:28 PM #10
    Front 18x9 et17 205/40/18
    Rear 18x9.5 et16 215/40/18
    Fenders Rolled: Yes
    Fenders Pulled: Yes
  11. Member DFWSKATE's Avatar
    Sep 6th, 2007
    dirty souf
    family sedan
    04-19-2012 12:53 PM #11
    Template:
    Front: 17x8 et5 215/40 512s
    Rear: 17x9 et25 205/45 912
    Fenders Rolled: Yes
    Fenders Pulled: No
    Floss Filthy x Watercooled Society
    Quote Originally Posted by justrave View Post
    i wish calvin and jason would move so i could officially say that texas sucks.
  12. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-19-2012 02:03 PM #12
    Rear: 18x7.5 et15 225/40/18
    Fenders Rolled: No
    Fenders Pulled: No
  13. Member LC6X's Avatar
    Nov 2nd, 2006
    Portland, OR
    2001 Baltic Jetta, 2012 GTI 2.0T
    04-19-2012 02:09 PM #13
    Front: 17x8.5 et 23 215/45/17
    Rear: 17x8.5 et 17 215/45/17
    Fenders Rolled: Yes
    Fenders Pulled: No
    With drop plates:
    Meet Crayola | Tuesday Night Beaverton GTG | IG: @mindy13vw | 8v Society #1
    Previous cars: 2013 TBM Jetta TDI, 2012 CW Beetle 2.0T, 2012 CW Jetta SE, 1989 Cabriolet
  14. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-19-2012 08:46 PM #14
    bump for more people to post up. thanks to everyone so far
  15. Member R32 1518's Avatar
    Jan 12th, 2011
    Staten Island, NY
    Bagged MK4 .:R32
    04-19-2012 08:50 PM #15
    I like this idea...good job dude
    wheels - BBS RSII.
    Front - 18x8.5 on 215/40r/18 tires. ET 22.
    Rear - 18x10 on 225/40r/18 tires. ET 18.
    Fenders rolled - yes ( should be for a lowered car )
    Fenders pulled - nope, oem.
  16. Member euro+tuner's Avatar
    Jan 31st, 2007
    Carlisle, Pa
    Bagged Econobox
    04-19-2012 09:11 PM #16
    Front: 18x8.5 et20 215/40/18 Falken 512
    Rear: 18x9.5 et35 225/40/18 Falken 512
    Fenders Rolled: Yes
    Fenders Pulled: Fronts slightly/ Rears No
    I lurk l IG: evans89411 l Flickr
  17. Member agentmaddock's Avatar
    Apr 11th, 2007
    Huntington, WV
    02 TDI, 89 Cabby
    04-19-2012 09:38 PM #17
    Privat Kups
    Front: 18x8.5 et24 215/40/18
    Fenders Rolled: Yes
    Fenders Pulled: No
  18. Member mini man's Avatar
    Aug 4th, 2011
    Canada, Ontario
    2001 Jetta Wolfsburg
    04-20-2012 11:48 AM #18
    Front: 18x8 et15 205/40/18 NeoGen
    Rear: 18x8 et10 205/40/18 NeoGen
    Fenders Rolled: Not Yet
    Fenders Pulled: No
    Front
    Rear
    -Stretch on the rim-
    will go lower
    Quote Originally Posted by Kiddie Rose View Post
    That sticker is a variation of the shocker. It means 0 in the pink 1 in the stink. So if there is no pink it's referring to a dude. So you like fingering dudes butts.
    ----> Mk4 Wheel Offset and Stance Picture Index <---- Please Contribute!
  19. Member mini man's Avatar
    Aug 4th, 2011
    Canada, Ontario
    04-20-2012 12:28 PM #19
    this should be made into a sticky, this will surely cut down on the number of threads being posted for Picture Requests on wheel setups..
    Thanks Clean PG for doing this!
  20. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-20-2012 11:21 PM #20
    Quote Originally Posted by mini man View Post
    thanks man now let's get some more people to post up
  21. Member livinzlyfe's Avatar
    Jan 8th, 2008
    MD
    dark red girl car, cop car.
    04-20-2012 11:29 PM #21
    18x9 et 18-ish 205/40 nitto neogen with lip protector removed(by previous owner)
    18x10 et 23-ish 215/40 nitto neogen with lip protector removed(by previous owner)
    fenders: rolled, and slightly pulled from being abused on coils
    quarters: slightly pulled from being abused on coils.
    with IDF drop plates in the rear.
    Flickr l the internet sucks. l it's all about the e-fame.
  22. Member moacur's Avatar
    Sep 22nd, 2006
    05 S4 - 964 911T
    04-20-2012 11:33 PM #22
    Great thread I think one thing that would help even more would be if people said what tires they are running... Since tire sizes are so different brand to brand. Even though that is not the point of this thread.It would still keep alot of questions from being asked
  23. Member livinzlyfe's Avatar
    Jan 8th, 2008
    MD
    04-20-2012 11:38 PM #23
    18x8.5 et 15 with 215/40 falken 512
    18x10 et 30 with 235/40 falken 512
    on coils
  24. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    04-20-2012 11:50 PM #24
    BBS RS 178 with a 56mm offset
    17x9.5 All the way around
    33mm rear and 38mm front adapters
    final offset: 23 mm rear, 18 mm front.
    215/45/r17 falken 512's
    Fenders rolled : Yes
    Fenders Pulled: no
    DSC_0426 by Bierce IV, on Flickr
    DSC_0420 by Bierce IV, on Flickr
    DSC_0446 by Bierce IV, on Flickr
    DSC_0436 by Bierce IV, on Flickr
    DSC_0434 by Bierce IV, on Flickr
    Quote Originally Posted by mk4boost View Post
    If you don't want to break the bank you have the wrong hobby
    My Thread
  25. Member mk3_vdub's Avatar
    Oct 18th, 2006
    Columbia, MD & Morgantown, WV
    03' 24v GTI VR6, 88 AEB Cabby
    04-20-2012 11:56 PM #25
    sounds like a great idea for a thread. maybe should add in a spot on the template for spacer/adapter setup, although final et should be plenty for people to figure it out.
    Wheel: Long Beaches
    Front: 17 x 7 et18 215/45 falken 912
    Rear: 17 x 7 et18 215/45 falken 912
    Fenders Rolled: Yes, and trimmed inside edge where fender liner mounts
    Fenders Pulled: No
    cant go any further out in the back without drop/great plates
  26. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-23-2012 10:05 PM #26
  27. Member Kampy's Avatar
    Oct 1st, 2010
    SF Bay Area, CA
    Low and VERY slow chick car
    04-23-2012 10:22 PM #27
    Quote Originally Posted by Clean PG View Post
    I will once the 162's are finally mounted
    that is unless some people reeeeeaaaaaaallllyyy want sizes on Arietta's....
    8v Society #362
  28. Member dopesauce's Avatar
    Aug 21st, 2008
    MD
    24v gti
    04-23-2012 10:49 PM #28
    Front: 17x9.5 et21 215/45/17 Falken 512
    Rear: 17x9.5 et19 215/45/17 Falken 512
    Fenders Rolled: yes
    Fenders Pulled: no
  29. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-24-2012 02:59 PM #29
    Quote Originally Posted by Kampy View Post
    actually, if you have pics and specs then please feel free to post up the Arietta's. any/all kinds of wheels are welcome and would be helpful for people who may be looking to fit some that are similar in size and offset
  30. Member mk3_vdub's Avatar
    Oct 18th, 2006
    04-25-2012 03:14 AM #30
    bringing this back up ttt, more people need to post up to get this more comprehensive
  31. Member Brah's Avatar
    Mar 5th, 2007
    Parker Ford, PA
    99.5' GTi and a handful more...
    04-25-2012 03:39 AM #31
    Brock B1's
    Front: 17x8.5 et21(final) 205/45/17
    Rear: 17x10 et35(final) 215/45/17
    Fenders Rolled: Yes
    Fenders Pulled: Yes
    **IDF Rear Drop Plates
    RESCUEdubs: We work purely on Technicalities around here.
    99' GTi - 2.2l Stroker foreal | Down Like Syndrome
  32. Member Kampy's Avatar
    Oct 1st, 2010
    SF Bay Area, CA
    04-25-2012 06:02 AM #32
    kk I'll go take better pix tomorrow but this should do for now
    OEM Arietta
    Front: 17x7.5 et38 + 12mm spacer final et26 215/45/17 (BFG Fatness though fits like crap )
    Rear: 17x7.5 et38 + 20mm spacer final et18 215/45/17
    Swapping for 15mm fronts as soon as I mount up some 205/40's for better fitment
    DSC_0008
    DSC_0099
    460817_421228301226224_100000171738242_1736451_172  7691914_o
    8v Society #362
  33. Member eastcoaststeeze's Avatar
    Jul 20th, 2009
    Ridgefield,CT
    bagged B7 S4 DTM Edition
    04-25-2012 06:28 AM #33
    Front: 18x8.5 et15 205/40/18
    Rear: 18x10 et13 225/40/18
    Fenders Rolled: Yes
    Fenders Pulled: No
    Floss Filthy x Team Big Shark x Gengstout x VIP Modular
    I am the east coast dealer for VIP MODULAR Wheels, PM me with all wheel questions pricing, powder coating, chroming, polishing and any other type of finish your little hearts can come up with.
  34. Member eastcoaststeeze's Avatar
    Jul 20th, 2009
    Ridgefield,CT
    04-25-2012 06:31 AM #34
    Front: 18x9.5 et22 215/40/18
    Rear: 18x10.5 et20 225/40/18
    Fenders Rolled: Yes
    Fenders Pulled: No
  35. Member SlayStation's Avatar
    Aug 17th, 2010
    Montreal
    20vT mk1 cabby
    04-25-2012 10:24 AM #35
    Reserved
    Quote Originally Posted by Mr Euro View Post
    ooh I like that, thanks for the snap
    and DON'T GO LOOK UP BLUE WAFFLE, people
    My car is blue, and I'm Belgian. Blue Waffle. That's all it means. Honest!
