Mk4 Wheel Offset and Stance Picture Index
2M views 385 replies 209 participants last post by  Brake Weight
#1 · (Edited by Moderator)
So it's obvious that many users (including myself) ask for help on offsets and mk4's. Thankfully, there is now a stickied thread where people can get advice and suggestions from others. But, what may be equally as helpful is seeing pictures of those wheel and offset specs. This thread is the solution to that.
Essentially, this thread will be used as an index/glossary/lookup containing wheel information and photos of mk4's. Below you you will see a list of wheel sizes by diameter and width. Within each section will be hotlinks to other posts in this thread grouped by Offset. See below for a scenario:
If you want to know what an 18x8.5 et35 looks like you can look in the list and click on any links you find in the "18x8.5" section listed as "et35" to be taken to those posts. Boom, done! :)
NOTE: This thread is NOT for making comments or asking wheel/offset/tire questions. If you need help with anything along those lines, please post in the Mk. IV Offsets and Tire Sizes Request Thread.
The more people that contribute, the more this thread will grow and be useful. Even if your same specs have been posted for another user's car or you're just running steelies that are spaced out, post anyway. The more the merrier!
If you'd like to contribute, please use the Template below. I will modify the glossary as often as possible with a hotlink to your post for others to view. Also, PLEASE double check your specs are correct and contain no typos before submitting. That will help prevent incorrect hotlinks after I add your post to the index. Thank you!
Template: (replace the italicized text with your information)
Front: WheelDiameter x WheelWidth etFinalOffset TireSpecs
Rear: WheelDiameter x WheelWidth etFinalOffset TireSpecs
Fenders Rolled: Yes/No
Fenders Pulled: Yes/No
(Then please include pictures of your car at good angles, side-shots may not be the most helpful. Close-ups of just the fender and wheel or also distant shots showing the car as a whole may work better. I recommend uploading them to www.imgur.com for the best longevity as this thread grows old.)
Example:
Front: 18x8.5 et30 215/40/18
Rear: 18x9.5 et30 225/40/18
Fenders Rolled: Yes
Fenders Pulled: Yes
(images would then be posted here under the specs)
Let's make this work and thanks to everyone for helping out 🍺
** 15" Wheels **
15x6
et35 --> Front & Rear - Clean PG
15x6.5
** 16" Wheels **
16x6.5
et22 --> Rear - TheColbster
et22 --> Rear - Blackwolf15
et22 --> Rear - 10 Gauge
et27 --> Front - TheColbster
et27 --> Front - ak47tdi
et27 --> Rear - ak47tdi
et27 --> Front - Blackwolf15
et27 --> Front - 10 Gauge
et32 --> Front - Blackwolf15
et32 --> Rear - Blackwolf15
16x7
16x7.5
16x8
** 17" Wheels **
17x7
et18 --> Front & Rear - mk3_vdub
et18 --> Rear - BIG_TNZ
et38 --> Front - BIG_TNZ
17x7.5
et12 --> Rear - im_lower
et15 --> Rear - Edgecomb56
et17 --> Rear - Pssst...passedyou
et17 --> Rear - amotion578
et18 --> Rear - Kampy
et18 --> Front - staticgti
et20 --> Rear - bluebora20v
et20 --> Front - andrew_b
et20 --> Rear - andrew_b
et22 --> Front - im_lower
et22 --> Front - amotion578
et24 --> Front - Pssst...passedyou
et25 --> Front - Edgecomb56
et25 --> Rear - __Rac3T!g3R
et26 --> Front - Kampy
et27 --> Front - bluebora20v
et30 --> Front - __Rac3T!g3R
17x8
et-1 --> Front - mk-4-ever
et4 --> Front - j-man41
et4 --> Front - coreymccluskey
et5 --> Front - DFWSKATE
et10 --> Front - Twilliams83
et10 --> Front - YNO WGN
et12 --> Front - sikknasty28
et12 --> Front - ArthurJ26
et18 --> Front - Leray
et18 --> Rear - Leray
et20 --> Front - samstdi04
et20 --> Rear - samstdi04
et23 --> Rear - BIGJ541
et30 --> Front - BIGJ541
17x8.5
et5 --> Front - Bazmcc
et7 --> Front - GaugeDoisher
et13 --> Front - Tradethedeadx
et15 --> Front - DUBgoon
et17 --> Rear - DubGirl13
et18 --> Front - Mitch_2.slow
et18 --> Rear - Mitch_2.slow
et18 --> Front - __Rac3T!g3R
et18 --> Rear - staticgti
et19 --> Front - .Ant
et20 --> Front - carlhuebner
et20 --> Front - LC6X
et21 --> Front - Brah
et23 --> Front - DubGirl13
et23 --> Front - Bora_Azul
et23 --> Front - mk-4-ever
et28 --> Front - Tradethedeadx
et30 --> Front - scirockalot8v
17x9
et0 --> Front - sikknasty28
et3 --> Rear - MsKi3m
et6 --> Front - MsKi3m
et8 --> Rear - j-man41
et8 --> Rear - coreymccluskey
et14 --> Rear - Radvr6T
et15 --> Front - DerekKoch
et15 --> Front - geffect
et15 --> Rear - geffect
et17 --> Rear - Twilliams83
et18 --> Rear - sikknasty28
et18 --> Rear - mk-4-ever
et19 --> Rear - sikknasty28
et20 --> Rear - YNO WGN
et20 --> Front - DUBgoon
et23 --> Front - Mikey Pants
et23 --> Front - __Rac3T!g3R
et23 --> Rear - ArthurJ26
et23 --> Front - ArthurJ26
et25 --> Rear - DFWSKATE
et25 --> Front - Radvr6T
17x9.25
et20 --> Front - dburg123
17x9.5
et13 --> Rear - Tradethedeadx
et18 --> Front - Bierce IV
et18 --> Front - DZ_p
et18 --> Front - sponcar
et19 --> Rear - dopesauce
et20 --> Rear - __Rac3T!g3R
et21 --> Front - dopesauce
et23 --> Rear - Bierce IV
et23 --> Rear - Bora_Azul
et23 --> Front - Dirty
et23 --> Rear - __Rac3T!g3R
et25 --> Rear - .Ant
et30 --> Rear - __Rac3T!g3R
et36 --> Rear - Tradethedeadx
17x10
et5 --> Rear - ArthurJ26
et17 --> Rear - sponcar
et19 --> Rear - Dirty
et19 --> Rear - dburg123
et20 --> Front - blue bags
et20 --> Rear - Bazmcc
et20 --> Rear - GaugeDoisher
et20 --> Rear - carlhuebner
et23 --> Rear - Mikey Pants
et25 --> Rear - DUBgoon
et27 --> Rear - LC6X
et30 --> Rear - scirockalot8v
et30 --> Rear - carlhuebner
et35 --> Rear - Brah
17x10.5
et22 --> Rear - blue bags
et22 --> Rear - DUBgoon
et24 --> Rear - DerekKoch
17x11
et28 --> Rear - DZ_p
** continued below **
See less See more
#136 ·
BBS RS Hybrid wheel Setup
Fronts= (RS321)17x9 ET 25 205/45/17
Rear: (Rs 329) 17x9 ET14 205/45/17
Fenders Rolled: Yes
Fenders Pulled: NO
#150 ·
Front: 18x7.5 et38 225/35/18 OEM BBS RC's 10mm spacers
Rear: 18x7.5 et38 225/35/18 OEM BBS RC's 17.5mm spacers
Fenders Rolled: No
Fenders Pulled: No
#152 ·
Does anyone know a link where i can find a formula to get the rigth adapter size. I see here all final offsets but how do i know what size adapter to use. I drive a mk4 vr6 jetta. Original wheels are 15x7 35mm offset and am getting some17x8 with 52 offset. I need to find out how to calculate for adapters thickness. Thanks in advance for any help
#155 ·
does anyone have any pics of poke like this and can help me get my car like that =P buying new wheels tires and spacers in like a month:mad:
definetly 18" wheels... for the rest of the stance, check the index on the first page of this thread, and if you want a stretch like that, don't go less than 9"
#161 ·
square fitment
Front: 17x8.5 et18 205/45R17 Pirelli P Zero Nero
Rear: 17x8.5 et18 205/45R17 Pirelli P Zero Nero
Fenders Rolled: Yes
Fenders Pulled:Slight pull on rears
Had to throw this in:laugh: Before pulling the rears it's safe to say it rubbed a bit
