Adjustment bolt down in the slot, and you get less pressure at the same ride height.
Adjustment bolt up in the slot, and you get more pressue at the same ride height.
The type and the condition of the tires, the pavement, the brake rotors, and the brake pads will also affect when the brakes will lock up and which end of the car locks the brakes first.
Maybe you need to replace the front brake pads with a more aggressive compound.
