Results 1 to 7 of 7
Thread: Is it supposed to be doing this?
  1. 04-19-2012 12:39 PM #1
    Now before you read and rage and /urwrists i posted this here b/c this isnt a serious break question. 99% of you will probably know the answer to this.
    So anyway i changed my wheels today. Took the car out of gear to see if they would clear my struts. Took the wheel off again and spun the rotor and it was rubbing against my breaks. It doesn't take much strength at all to turn the rotor but i did rub a little bit. Should i just leave it and let the breaks wear out so it can stop the rubbing or should i just redo them????
    Yes i know noob question.
  2. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    2002 1.8T JETTA & 2000 TTQ
    04-19-2012 12:48 PM #2
    The 'brakes' not breaks and I presume you mean pads...are supposed to rub against the rotors
    You probably hit your brake pedal when you took it out of gear, which compressed your piston inside your caliper a little and now it 'rubs' as you say
  3. 04-19-2012 01:34 PM #3
    Ok cool. I was thinking the same thing but just wanted to make sure.
  4. Member Humb1e's Avatar
    Jan 19th, 2012
    La Crosse, WI
    2003 GTI 1.8T
    04-20-2012 02:54 AM #4
    Brake pads always have contact with the rotors.
    Schaeffer's Advantage
  5. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    IY 20th in America, Evolution IV in 沖縄, 日本
    04-20-2012 03:18 AM #5
    No. brake pads do NOT always drag against the rotor. That is wrong.
    Was the car doing this before you changed your wheel?
    And OMG, this IS the wrong forum for that. You should be posting this question in the model specific (mk4 likely) forum. Or the brake technical forum.
  6. 04-20-2012 11:19 AM #6
    Quote Originally Posted by Humb1e View Post
    +1
    Unless for whatever reason the caliper retracts enough to pull the pads away. But generally, the pads always rub on the rotor. It's normal.
  7. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    04-20-2012 01:10 PM #7
    Quote Originally Posted by 87vr6 View Post
    Brake pads, almost always slightly touch the rotor. They might not always 'drag' against the rotor with force, but they are 'somewhat' touching which is normal.
