Results 1 to 9 of 9
Thread: tigerdirect PC service department
  1. Member valfaw's Avatar
    Sep 15th, 2006
    Chicago
    1986 Alfa Spider, 2005 Ford Freestyle
    04-19-2012 03:00 PM #1
    Anyone have experience with Tigerdirect for their service department and their ability to resolve ongoing bsod issues I can't seem to get my head around.
    They had a groupon right now that I could pull the trigger on if I knew I could trust them to give me back my home built all tweaked and adjusted for the bits I have so BSOD's are a thing of the past as I'm still have a couple a day.
    I try to go through the codes and such, update drivers, test ram, etc., etc., and still am having problems.
    I think my build has the ability to run much better than it does if I could get past whatever issues I'm having and can't resolve.
    Thanks in advance for any insight...
  2. Senior Member SAPJetta's Avatar
    Feb 3rd, 2001
    East Bay, CA
    2008 Rabbit S(low), 2012 Outback 2.5 Premium
    04-19-2012 05:01 PM #2
    I'd avoid Tigerdirect like the plague. Nothing but bad experiences with those guys. I sure as hell wouldn't let them touch my system.
    Where are we going and why am I in this handbasket?
    XBL - urparanoid
  3. Senior Member Hostile's Avatar
    May 29th, 2002
    NOVA
    a subaru and a vw
    04-19-2012 05:16 PM #3
    Quote Originally Posted by SAPJetta View Post
    This.
  4. Member valfaw's Avatar
    Sep 15th, 2006
    Chicago
    04-19-2012 07:08 PM #4
    that was my sense but I figured I'd throw it out to comment... thanks
  5. Member x047x's Avatar
    Mar 16th, 2004
    Pittsburgh
    '08 GTI 2.0t
    04-20-2012 07:24 AM #5
    I would just find someone local (and certainly not the Geek Squad). I guarantee there are some small repair shops in your area.
    EDIT: I see you're in Chicago. There has to be a ton of options. Good luck
  6. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    96 Jetta - 300K Club, Truck, Boat, Quad
    04-25-2012 12:56 PM #6
    if you live in CT - bring it to me.
    i <3 tiger direct, but i don't have anyone else but me fix my machines...i only buy parts from TD.
    There aint no OZ in rape.
  7. Member PhReE's Avatar
    Sep 16th, 2004
    Taylorsville, UT
    2004 Turbo VR6
    04-25-2012 04:36 PM #7
    Are you overclocking? If so then you may be going too far, too hot, not enough voltage, too much voltage, etc.
    If you are not overclocking and getting bluescreens it's highly likely you have a bad piece of hardware.
    -James
    04 GTI Silverstone 24vT :: GT35r - TT 264/260 - Unitronic 630cc - Bosch 044 - Area51 SRI - Full 3" TB :: More in progress
    >> http://zingledot.myminicity.com/ | http://sourceforge.net/projects/imagizer2 <<
  8. Member Minker17's Avatar
    Apr 1st, 2004
    Franklin, TN
    1994 Ford Temp GL
    04-25-2012 04:55 PM #8
    Quote Originally Posted by WakusPakus View Post
    We use TD for all our PC stuff at work. Never had them service anything, but our rep is awesome about returning stuff.
    Rick
    1994 Ford Tempo GL
  9. Member valfaw's Avatar
    Sep 15th, 2006
    Chicago
    04-30-2012 09:42 PM #9
    Quote Originally Posted by PhReE View Post
    sorry to not respond sooner...
    no overclocking.
    build is a;
    i5 2500k
    gigabyte z68 ud3h b3
    m4 crucial 128gb
    16gb of patriot g2
    antec 750w gamer series bronze
    win7 premium oem
    mobo was already swapped out.
    memtest ram clean for the memory
    replaced the original HD with the SSD noted as I thought it was the problem initially
    still getting memory management, irql, all the different flavors of bsod. last couple of days I've had multiple windows explorer stopped working messages on top of the bsod crashes.
    want to throw the box out he window. very frustrated as I didn't realize there was this much to getting all the little tweaks worked out to get a system stable. I've tried as best I can to update drivers/bios, debug and solve issues but I'm feeling this is over my head at this point.
    I've not changed out memory as that's my last thought as I've read that memtest can not always call out problematic memory sticks. I've also come to note that the memory I'm running is on the approved list for the mobo I have.
    I've also heard that the graphics portion of the cpu can be problematic sometimes. I'm not running a gpu yet and wonder if that is playing any part of this mess.
    also getting volume errors on a new install ssd that tests fine...
    I get few hundred thousand interrupts so there is something going on...
