Hey Devin, I bought my whole AN setup from Velocity196, so what you see is how I got it, not sure if he had anything special done to it...
As far as my filler neck I was going to get a 16AN filler for it but no matter how I tried to route it, it just wouldn't work for me... The SEM is so damn big and the AN adapters on the radiator wouldn't allow for a descent run with where I'm routing the intercooler piping...
I bought an ECS carbon fiber strut brace new from a member on here, I think I'm going to chop it up and try to have a piece of aluminum in place of the carbon fiber and have someone tig weld my existing filler neck to it along with a couple 6AN males... then I'll take the 6AN line from the turbo return line and go up to a 6AN fitting that will be on it, and take the other male and go 6AN to the stainless line going into block by water pump.... We will see if it works out or not...
You have the same mindset as me as far as the 02J, just trying to keep it together as I already have a bunch of $ into it with the Peloquin LSD and the Clutchmaster FX400... Don't want to go 02M
I would also like to thank you for answering questions I have had during my wiretuck and other random questions I've had![]()
I always wanted to block off a section of the rain tray with an alum cube and mount bulkheads on the firewall for a res.
fuel line doesn't have a tight fit to the o-rings that are in fitting... guaranteed to leak
or is this just because the metal fuel-lines..?
