#71
Good stuff going on here. Glad to see you're from MN too![]()
Pushing 20V at a time
#72
Brute 20mm Connecting Rods, ACL Bearings, Wiseco 83mm Pistons, FSI Crank, AEB Head, CatCams 3658, PagParts GT3076R Bottom Mount V-Banded Turbo Kit, PagParts Garret 550HP Core, VF Engineering Motor Mounts, SEM IM, Labonte W/M, 70mm TB, Tial Q BOV, Tial Wastgate, Turbosmart Dual Stage Boost Controller, Peloquin LSD, Clutchmasters FX400, 910cc Injectors, IE Surge Tank, Eurodyne with Maestro.... PAGPARTSClear Water Dubs
#74
#75
#78
#79
Fuel lines done
Just waiting for welder to call me with my intercooler pipes... Also have to figure out something still for a filler neck/resevoir for the coolant
#80
How snug was the 3/8 fitting? Looks like it is coming together. I like how you secured the lines under the car that good thinking.
#81
How much are we looking at so far? $$$$$
and when can we hear it?
#82
I just broke the original clips and grinded them round that held the old fuel lines in place... holds them good... Not sure about your question on how snug the 3/8 fitting???
$$$ for this year or everything??? I lost track anyway, its better to loose track so you can honestly tell the wife I have no clue how much I have in it
I wish I could post a vid of how it sounds nowI hope within a couple weeks, I'm crazy busy at work
#83
#84
#85
It is actually for our 5/16ths factory lines and goes to 6an, it fits perfect
Brutes 20mm $480
ACL coated con rod bearings $60
ACL main bearings like $100
overbore head gasket $100
misc seals maybe $100
3658 Cams around $650
FSI crank $800
Wiseco Pistons $600
ARP mains $100
ARP head studs $200
valve Guides $10 each so $200
Valve seals cant remember
Supertech Ex valves $260
Supertech intake $240
IE spring and retainer kit $650
Machine work for block $300 (can't remember for sure as machinest when it was all done owed me because of overbore)
Arnold assembled head like 4-500 can't remember for sure
Hydro lifters can't remember
new oil pump ??
non vvt tensioner ???
used AEB head $350
And other Misc stuff like lube ect
Hope that helpsI'm sure I'm forgetting some stuff
#87
Well still waiting for my IC pipes so got bored and made a bracket to hold dipstick tube down so when I remove my dipstick the tube doesn't come with it
I have some mad fabbing skills![]()
#88
Here is an interesting article i found about braided lines
Do You Smell Gas?
By John McLelland
We've had reports from customers who have had the experience of opening their garage door and being assaulted by the strong smell of gasoline. Their first impulse was to check if gas was leaking from the vintage muscle car or street rod parked there.
The gasoline odor seemed strong enough to cause worry about a potential explosion. After opening the hood, checking the carburetor, fuel pump, fuel filter, rubber fuel lines, and then moving back to the gas tank, no leak sources could be found. The next step toward solving the problem involved disconnecting the line from the fuel pump to the carburetor. Again, no obvious leaks. Further examination revealed that the hose appeared to be letting fuel vapors pass right through its walls. The exterior of the hose felt moist and a finger rubbed along its length smelled strongly of gasoline. This phenomenon is called permeation, and its presence absolutely rules out the use of common rubber fuel lines in any modern hot rod application. Vapor permeation, as it is officially termed, happens because today's unleaded pump gas, with myriad additives, creates vapors that can eventually pass right through the walls of rubber fuel hose. Permeation could involve older vintage street rods, muscle cars, and trucks where standard fuel hose or high performance stainless braided rubber hose was installed originally when pump gas was not as unfriendly to rubber as it is today. Many of these hoses have now been on the cars for several years and could cause some severe permeation issues. Most modern, unleaded fuels are blended with 10% ethanol along with countless additives and harsh detergents to keep fuel injectors clean and emission levels down.
There are at least 23 different blends of gasoline being sold in the United States so it's impossible to know what fuel is coming out the pump at any given time, or how it's affecting the fuel hose. One thing is for sure, the pump gas of today is harmful to the old nitrile rubber fuel (SAE30R7) hose, originally rated for low-pressure (up to 50 PSI) and used on every passenger car and truck into the '80's. Even many high performance braided stainless reinforced hoses use nitrile and are subject to the same deterioration and permeation rate (passing 30 times more hydro-carbons than SAE30R9fuel injection hose).This is especially true when the fuel stagnates in the hose for a long period of time (like it does in seldom driven street rods or muscle cars). Availability of replacements for old stock factory nitrile rubber hose is limited. The only hose replacement found is the fuel injection (SAE30R9)hose, readily available, and suitable replacement hose at a modest cost. These hoses retain the "stock factory look", but are chemically engineered for modern unleaded pump gas, and E85fuels. Be careful of lower cost, so-called budget brands. Hoses manufactured "across the pond" can look the same as USA made stainless steel branded hose, but with no Society of Automotive Engineers (SAE)in place to monitor standards, the stainless steel braid may not be bonded or extruded correctly through the rubber, the hose bore may not be concentric or of even thickness which will eventually result in vapor permeation, not to mention ballooning and leakage or failure, especially at the fittings. These days it's difficult to tell just where any aftermarket hoses are really manufactured. There are numerous private label brands on the market. Carefully research each hose product before making any purchases. Most companies have recommended I.D. and 0.0 hose specifications and these are important when purchasing the correct hose ends. Spending less now, might hurt your pocket book later.
Almost all of the manufacturers we contacted are either making permeation proof hose or working on development of same. All highly recommended the use of Teflon" (PTFE) hose to be sure of eliminating the permeation problem. Although not as flexible as rubber hose, Teflon" hose definitely keeps vapors contained. (NOTE: aluminum hard line can also be used in place of rubber or braided hose.)
Keep in mind that once any hose has been installed, preventative maintenance is the key to long term elimination of the vapor problem. Also, it might be wise, if storing a car for long periods of time, to purge the fuel system completely.
*Teflon is a registered trademark of Dupont
#89
Very interesting, I guess we will find out if that happens to me, otherwise it might be a representative promoting Dupont teflon
Got intercooler pipes back today from the welder
No more broken tab, pretty beefy now on my intake pipe
Got a bung welded on for my Water/meth, just gotta get it tapped for the nozzle
Now just have to go fit it up, cut bumper apart some more and then get these to the powder coater![]()
#90
Bumper fits, the pipes look okay in there, had to trim out alot to get them to fit, I think I need an R32 bumper
I still need to get a resevoir and filler for my coolant and want to mount it somewhere above brake ABS controller and by the Catch can, any suggestions would be great, wes gonna use some leftover 2.5" IC piping I have leftover and weld a couple 6AN fittings on there and a filler neck, and run the coolant return line from turbo to that res and from there go to the return line going into block
Thanks for looking
#92
Looking good.
Sent from my MB860 using Tapatalk 2
#93
Thanks for the kind words guys
Where can a guy source these connectors??
Injector Connector Adapter, Bosch Jetronic EV1 to USCAR EV14
There pretty cheap on Eurodynes Website but if you factor in shipping its rediculous, 70 bucks for shipping is a bit much![]()
#94
Forget the last question Arnold is gonna get me some![]()
#95
If your willing to re do your harness, in pretty sure those are the same plugs gm used on their sunfires. On my 16vt I scored a set of cobalt ss stage 1 injectors, and had to use a harness from said sunfire.
#96
Thanks Dave but I got my harness adapters yesterday from Arnold over at PPT....
Well 35 yrs old todaygoing into garage to bleed brakes with Motive power bleeder, install injector clips and finish with wiring this thing up... Dropped off my IC pipes and coolant res off to powdercoater so should have them next week, if all goes well hopefully firing this thing up next weekend
#98
#99
Looks good-The ic pipes+tb and mani look clean. I love the your driver side setup. I have an rmr+hemi tb passenger side and things get freakin crowded over there.
#100
This is such a nice build! Love the attention to details.![]()
#101
those welds are really impressive you lucked out
20th build ~9:5:1 wiseco 81mm forge pisons~IE 20mm rifle drilled H beams~Calico rod bearings~snowperformance single injection water/meth~stock small port AWP head matched to a IE intake manifold~hemi throttlebody~Custom downpipe/turboback~Self maestro tuned~tial 38mm wastegate~GT3076r .63ar Vband~6 puck Clutchnet~PTE600.
#102
#103
Got my pipes and coolant res back from powdercoater this afternoon
has finger prints on the res but will look good in bay
#104
coating looks great Brad, and god does it get addicting. have you tried connectoing the BOC to that flange since it is now coated? hopefully it seals well. Just a thought. keep it up.
and I will do my best to get you an update as well. I am just about to head back into the garage for a bit.![]()
#105
