VWVortex.com - My 20v Timeline And Build
    Page 4 of 28 FirstFirst 1234567814 ... LastLast
    Results 76 to 100 of 692
    Thread: My 20v Timeline And Build
    1. Member rains's Avatar
      May 30th, 2008
      Sherwood Park
      1995 Saturn SW1
      05-13-2012 03:46 PM #76
      good thread
      This thread is now about car cakes.
      Things I learned today: You don't have to pass grade 12 English to Manage a Honda dealership.
    2. Member 1.8T_Guy's Avatar
      Feb 8th, 2011
      Brooklyn Park, MN
      06 GTI
      05-13-2012 05:43 PM #77
      Quote Originally Posted by One-Eight GTI View Post
      Thanks Man... I need to get this thing done so I can enjoy it while its summer, in a couple months we will have snow again
      What software are you running??
      Damn right. LOL.
      As of right now, my GTI is down and I just got a newborn. So it will be down even longer. I'm currently running APR stg 2 reflash. Still debating if I should continue building the BT setup or just go back to stock turbo.
      Pushing 20V at a time
    3. Banned dubinsincuwereindiapers's Avatar
      Jan 16th, 2008
      InYourMom
      Bugatti Veyron
      05-13-2012 05:48 PM #78
      Quote Originally Posted by 1.8T_Guy View Post
      Damn right. LOL.
      Finish it while you still can. Kids are cheap while they're young. Don't stop now, or you wont have the opportunity again for quite some time. My 2¢
    4. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      05-17-2012 07:33 PM #79
      Fuel lines done
      Just waiting for welder to call me with my intercooler pipes... Also have to figure out something still for a filler neck/resevoir for the coolant
      Brute 20mm Connecting Rods, ACL Bearings, Wiseco 83mm Pistons, FSI Crank, AEB Head, CatCams 3658, PagParts GT3076R Bottom Mount V-Banded Turbo Kit, PagParts Garret 550HP Core, VF Engineering Motor Mounts, SEM IM, Labonte W/M, 70mm TB, Tial Q BOV, Tial Wastgate, Turbosmart Dual Stage Boost Controller, Peloquin LSD, Clutchmasters FX400, 910cc Injectors, IE Surge Tank, Eurodyne with Maestro.... PAGPARTS Clear Water Dubs
    5. Member Dameon's Avatar
      Oct 5th, 2008
      Michigan
      2011 Jetta, 1982 rabbit
      05-17-2012 10:03 PM #80
      How snug was the 3/8 fitting? Looks like it is coming together. I like how you secured the lines under the car that good thinking.
    6. 05-18-2012 01:32 AM #81
      How much are we looking at so far? $$$$$
      and when can we hear it?
    7. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      05-18-2012 08:02 AM #82
      Quote Originally Posted by nebio_b5 View Post
      I just broke the original clips and grinded them round that held the old fuel lines in place... holds them good... Not sure about your question on how snug the 3/8 fitting???
      Quote Originally Posted by MK420TH92 View Post
      $$$ for this year or everything??? I lost track anyway, its better to loose track so you can honestly tell the wife I have no clue how much I have in it
      I wish I could post a vid of how it sounds now I hope within a couple weeks, I'm crazy busy at work
    8. Member Dameon's Avatar
      Oct 5th, 2008
      Michigan
      05-18-2012 08:54 AM #83
      So ordered old faithful (Hootyburra said this one worked on his car) 799-640863
      Sorry, this is the fitting I am talking about. The description says 3/8 to 1/2 lines. Does it seem snug or tight enough when attached to the stock fuel line?
    9. 05-18-2012 02:31 PM #84
      Just wondering how much it was for the fully built engine. Planning to do something like this myself later on in the future once i save up some cash. And post some vids once you get a chance. Ill be monitoring
    10. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      05-18-2012 05:08 PM #85
      It is actually for our 5/16ths factory lines and goes to 6an, it fits perfect
      Brutes 20mm $480
      ACL coated con rod bearings $60
      ACL main bearings like $100
      overbore head gasket $100
      misc seals maybe $100
      3658 Cams around $650
      FSI crank $800
      Wiseco Pistons $600
      ARP mains $100
      ARP head studs $200
      valve Guides $10 each so $200
      Valve seals cant remember
      Supertech Ex valves $260
      Supertech intake $240
      IE spring and retainer kit $650
      Machine work for block $300 (can't remember for sure as machinest when it was all done owed me because of overbore)
      Arnold assembled head like 4-500 can't remember for sure
      Hydro lifters can't remember
      new oil pump ??
      non vvt tensioner ???
      used AEB head $350
      And other Misc stuff like lube ect
      Hope that helps I'm sure I'm forgetting some stuff
    11. 05-19-2012 05:47 PM #86
      ^^^ damn... that a lot.. i got a a lot of saving up 2 do.
    12. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      05-20-2012 10:05 AM #87
      Well still waiting for my IC pipes so got bored and made a bracket to hold dipstick tube down so when I remove my dipstick the tube doesn't come with it
      I have some mad fabbing skills
    13. Member Dave926's Avatar
      Mar 30th, 2005
      Rhode Island
      1989 Helios GLI 1997 Mk3 ****box
      05-20-2012 12:07 PM #88
      Here is an interesting article i found about braided lines
      Do You Smell Gas?
      By John McLelland
      We've had reports from customers who have had the experience of opening their garage door and being assaulted by the strong smell of gasoline. Their first impulse was to check if gas was leaking from the vintage muscle car or street rod parked there.
      The gasoline odor seemed strong enough to cause worry about a potential explosion. After opening the hood, checking the carburetor, fuel pump, fuel filter, rubber fuel lines, and then moving back to the gas tank, no leak sources could be found. The next step toward solving the problem involved disconnecting the line from the fuel pump to the carburetor. Again, no obvious leaks. Further examination revealed that the hose appeared to be letting fuel vapors pass right through its walls. The exterior of the hose felt moist and a finger rubbed along its length smelled strongly of gasoline. This phenomenon is called permeation, and its presence absolutely rules out the use of common rubber fuel lines in any modern hot rod application. Vapor permeation, as it is officially termed, happens because today's unleaded pump gas, with myriad additives, creates vapors that can eventually pass right through the walls of rubber fuel hose. Permeation could involve older vintage street rods, muscle cars, and trucks where standard fuel hose or high performance stainless braided rubber hose was installed originally when pump gas was not as unfriendly to rubber as it is today. Many of these hoses have now been on the cars for several years and could cause some severe permeation issues. Most modern, unleaded fuels are blended with 10% ethanol along with countless additives and harsh detergents to keep fuel injectors clean and emission levels down.
      There are at least 23 different blends of gasoline being sold in the United States so it's impossible to know what fuel is coming out the pump at any given time, or how it's affecting the fuel hose. One thing is for sure, the pump gas of today is harmful to the old nitrile rubber fuel (SAE30R7) hose, originally rated for low-pressure (up to 50 PSI) and used on every passenger car and truck into the '80's. Even many high performance braided stainless reinforced hoses use nitrile and are subject to the same deterioration and permeation rate (passing 30 times more hydro-carbons than SAE30R9fuel injection hose).This is especially true when the fuel stagnates in the hose for a long period of time (like it does in seldom driven street rods or muscle cars). Availability of replacements for old stock factory nitrile rubber hose is limited. The only hose replacement found is the fuel injection (SAE30R9)hose, readily available, and suitable replacement hose at a modest cost. These hoses retain the "stock factory look", but are chemically engineered for modern unleaded pump gas, and E85fuels. Be careful of lower cost, so-called budget brands. Hoses manufactured "across the pond" can look the same as USA made stainless steel branded hose, but with no Society of Automotive Engineers (SAE)in place to monitor standards, the stainless steel braid may not be bonded or extruded correctly through the rubber, the hose bore may not be concentric or of even thickness which will eventually result in vapor permeation, not to mention ballooning and leakage or failure, especially at the fittings. These days it's difficult to tell just where any aftermarket hoses are really manufactured. There are numerous private label brands on the market. Carefully research each hose product before making any purchases. Most companies have recommended I.D. and 0.0 hose specifications and these are important when purchasing the correct hose ends. Spending less now, might hurt your pocket book later.
      Almost all of the manufacturers we contacted are either making permeation proof hose or working on development of same. All highly recommended the use of Teflon" (PTFE) hose to be sure of eliminating the permeation problem. Although not as flexible as rubber hose, Teflon" hose definitely keeps vapors contained. (NOTE: aluminum hard line can also be used in place of rubber or braided hose.)
      Keep in mind that once any hose has been installed, preventative maintenance is the key to long term elimination of the vapor problem. Also, it might be wise, if storing a car for long periods of time, to purge the fuel system completely.
      *Teflon is a registered trademark of Dupont
    14. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      05-20-2012 03:42 PM #89
      Quote Originally Posted by Dave926 View Post
      Very interesting, I guess we will find out if that happens to me, otherwise it might be a representative promoting Dupont teflon
      Got intercooler pipes back today from the welder
      No more broken tab, pretty beefy now on my intake pipe
      Got a bung welded on for my Water/meth, just gotta get it tapped for the nozzle
      Now just have to go fit it up, cut bumper apart some more and then get these to the powder coater
    15. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      05-20-2012 07:12 PM #90
      Bumper fits, the pipes look okay in there, had to trim out alot to get them to fit, I think I need an R32 bumper
      I still need to get a resevoir and filler for my coolant and want to mount it somewhere above brake ABS controller and by the Catch can, any suggestions would be great, wes gonna use some leftover 2.5" IC piping I have leftover and weld a couple 6AN fittings on there and a filler neck, and run the coolant return line from turbo to that res and from there go to the return line going into block
      Thanks for looking
    16. Member T-Boy's Avatar
      Jul 16th, 2003
      ATL
      05-20-2012 07:45 PM #91
      Clean as hell!
    17. Member schwartzmagic's Avatar
      Apr 29th, 2007
      MIA
      2011 Jetta TDI; 05 VW Jetta GLI 5857BT
      05-21-2012 08:35 PM #92
      Looking good.
      Sent from my MB860 using Tapatalk 2
    18. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      05-22-2012 06:11 PM #93
      Thanks for the kind words guys
      Where can a guy source these connectors??
      Injector Connector Adapter, Bosch Jetronic EV1 to USCAR EV14
      There pretty cheap on Eurodynes Website but if you factor in shipping its rediculous, 70 bucks for shipping is a bit much
    19. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      05-22-2012 07:05 PM #94
      Forget the last question Arnold is gonna get me some
    20. Member Dave926's Avatar
      Mar 30th, 2005
      Rhode Island
      05-22-2012 07:15 PM #95
      If your willing to re do your harness, in pretty sure those are the same plugs gm used on their sunfires. On my 16vt I scored a set of cobalt ss stage 1 injectors, and had to use a harness from said sunfire.
    21. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      05-26-2012 09:40 AM #96
      Thanks Dave but I got my harness adapters yesterday from Arnold over at PPT....
      Well 35 yrs old today going into garage to bleed brakes with Motive power bleeder, install injector clips and finish with wiring this thing up... Dropped off my IC pipes and coolant res off to powdercoater so should have them next week, if all goes well hopefully firing this thing up next weekend
    22. Forum Sponsor Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      91 Audi 80 2.0T
      05-26-2012 11:59 AM #97
      Build looks amazing!
    23. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      05-26-2012 12:20 PM #98
      Quote Originally Posted by Issam Abed View Post
      Thanks Issam, appreciate it, looking forward to finally using the SEM and 70mm that have been collecting dust over the last year
    24. 05-26-2012 01:17 PM #99
      Looks good-The ic pipes+tb and mani look clean. I love the your driver side setup. I have an rmr+hemi tb passenger side and things get freakin crowded over there.
    25. Member Andaloons's Avatar
      Apr 16th, 2004
      Texas
      2004 GLI 02M; 1997 Ford F-150
      05-26-2012 07:12 PM #100
      This is such a nice build! Love the attention to details.
      Please vote for a Maestro Tuning Sub-Forum!
      PM me for Bentley repair manual PDF.
