VWVortex.com - My 20v Timeline And Build
    Page 5 of 28 FirstFirst 12345678915 ... LastLast
    Results 101 to 125 of 692
    Thread: My 20v Timeline And Build
    1. Member Budsdubbin's Avatar
      Jul 14th, 2008
      Buffalo, NY
      BMP20th/00 chevy tahoe
      05-26-2012 08:58 PM #101
      those welds are really impressive you lucked out
      20th Build ~9:5:1 wiseco 81mm forge pisons~IE 20mm rifle drilled H beams~Calico rod bearing~stock port AWP head matched to a IE intake manifold~hemi throttlebody~Custom downpipe/turboback~Self maestro tuned~tial 38mm wastegate~GT3076r .63ar Vband~6 puck Clutchnet~PTE600~USRT 1000cc gen2's~044 IE surge assembly~IE fuelrail~fuelab adjustable FPR
    2. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      05-28-2012 06:49 PM #102
      Thanks guys
      Quote Originally Posted by Budsdubbin View Post
      Yeah there pretty damn good welds, he has been welding for 35 yrs so I was hoping they were going to be good... Its nice to have a local welder that can weld aluminum now
      Brute 20mm Connecting Rods, ACL Bearings, Wiseco 83mm Pistons, FSI Crank, AEB Head, CatCams 3658, PagParts GT3076R Bottom Mount V-Banded Turbo Kit, PagParts Garret 550HP Core, VF Engineering Motor Mounts, SEM IM, Labonte W/M, 70mm TB, Tial Q BOV, Tial Wastgate, Turbosmart Dual Stage Boost Controller, Peloquin LSD, Clutchmasters FX400, 910cc Injectors, IE Surge Tank, Eurodyne with Maestro.... PAGPARTS Clear Water Dubs
    3. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      05-31-2012 06:49 PM #103
      Got my pipes and coolant res back from powdercoater this afternoon
      has finger prints on the res but will look good in bay
    4. Member DBVeeDB's Avatar
      Aug 2nd, 2007
      Des Plaines, IL
      His: 8V A3 Hers: '10 CC Sport 6MT + '03 GTI 1.8T/5MT
      05-31-2012 10:48 PM #104
      coating looks great Brad, and god does it get addicting. have you tried connectoing the BOC to that flange since it is now coated? hopefully it seals well. Just a thought. keep it up.
      and I will do my best to get you an update as well. I am just about to head back into the garage for a bit.
    5. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      06-01-2012 01:09 AM #105
      Quote Originally Posted by DBVeeDB View Post
      Yeah Devin everything sealed up nicely with the BOV that I can tell anyway... I already have well over 40 in this week so gonna have a nice Friday in the garage Gotta finish making the bracket for the Res, already got the pipes mounted and hooked up, so getting there
    6. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      06-03-2012 11:07 PM #106
      Do I need to put KY on my Hitachi coilpack to get them to go down... OEM ones fit fine on the AEB head but my Hitachi ones don't??? What do you guys do?? Only have one OEM one
    7. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      06-03-2012 11:19 PM #107
      Here are a few more pics
      Bay sure filled up quick, don't know how people keep them so clean, Oh well good enough for this summer
    8. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      06-05-2012 08:38 PM #108
      Well guys dumped in a tune from Marc and fired it up... I'm a little worried as I have alot more Clutch Chatter than last year when I was 1.8, clutch and tranny are the same just added Vaps pinion brace and IE reinforced clutch fork...
      In this video you can hear when I push in the clutch, just want your opinions, let it run to operating temp, now gonna go change oil and put my tires back on and front bumper, hopefully take it out and see how it does....
    9. Member T-Boy's Avatar
      Jul 16th, 2003
      ATL
      06-05-2012 08:44 PM #109
    10. Member Rac_337's Avatar
      Sep 23rd, 2004
      Toronto
      337 PTE5857 DBB, Volvo C70
      06-05-2012 09:47 PM #110
      thats a lot of chatter for sure. try taking it around the block and see how it engages from a stop.
    11. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      06-05-2012 09:56 PM #111
      Quote Originally Posted by Rac_337 View Post
      Yeah when I first started it up it scared the sh*t out of me, thought something was knocking in the engine... I gotta finish getting my front bumper and tires on the car.... I Don't know what would cause more chatter in it, I've got my Fluidampr on like last year... I guess when I try to drive it we wil see what happens
      Sep 15th, 2005
      Silver Spring, MD
      '02JETTA (SOLD) '00TTQ (SOLD) '90 C2 964
      06-05-2012 10:08 PM #112
      Quote Originally Posted by One-Eight GTI View Post
      I had the same issue years back. I just cut-off a conical portion from the rubber boot on the coil and it fits right on. Cut it like on the left coil.
    13. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      06-06-2012 12:53 AM #113
      Quote Originally Posted by 18T_BT View Post
      Yeah I just used a dremel and sanded off some material, tight fit but worked good... Thanks for the info anyway
    14. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      06-06-2012 07:23 PM #114
      Well looks like I'm gonna have fun this weekend, gonna pull the transmission and see what is going on in it... Any ideas welcome
    15. Member Issam Abed's Avatar
      Feb 12th, 2004
      EVERYWHERE
      91 Audi 80 2.0T
      06-07-2012 03:18 PM #115
      Any ideas welcome
      Dont start it again until that gearbox comes out.
      Ive seen a simular situation before where (1) of the (4) nuts holding the pinion (now pinion brace) snapped (as in the stud sheared but was still held in place) and was bouncing around in the bell housing.
      I assume in the above vid you put it into first (car is on stands?)
    16. Member formerly silveratljetta's Avatar
      Feb 6th, 2007
      2001 Audi TT Quattro
      06-07-2012 04:35 PM #116
      awesome build
    17. Member Vegeta Gti's Avatar
      Feb 12th, 2003
      konoha village, hawaii
      1984 GLi 20v, '16 M3, '85 Golf, '03 BMP 20th AE
      06-07-2012 05:05 PM #117
      damn dude, that doesn't sound like chatter, that sounds like something is barely holding on. def pull the trans, hope you get it sorted.
      :HOMEGROWN MOTORSPORTS:1:4.9 SuaSponte #13Dead Rabbits. Ungluck on IG. MKIforLife
      Quote Originally Posted by .Ant View Post
      What vegeta said.
    18. Member
      Sep 15th, 2005
      Silver Spring, MD
      06-07-2012 05:54 PM #118
      i bet lose PP or FW bolts
    19. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      06-07-2012 05:59 PM #119
      Quote Originally Posted by Issam Abed View Post
      Yes sir
      Quote Originally Posted by Vegeta Gti View Post
      I have a guy coming over that works at a VW repair shop in town here (the same guy that put my LSD in a couple years ago) I will have to start it one more time so he can hear, then most likely removing the damn thing starting tonight
    20. Member schwartzmagic's Avatar
      Apr 29th, 2007
      MIA
      2011 Jetta TDI; 05 VW Jetta GLI 5857BT
      06-07-2012 06:09 PM #120
      This
      Good luck man... Hopefully it's nothing significant.
    21. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      06-07-2012 06:30 PM #121
      Don't get me wrong anything is possible but the pressure plate is torqued to specs as I use a torque wrench for everything, and the flywheel has ARP bolts torqued down and red locktite on them.... Will be posting pics this weekend when I get the thing out so I can satisfy mine and everyone elses guesses
      Appreciate the ideas from everyone
    22. Member SB_GLI's Avatar
      Oct 17th, 2005
      Stevens Point, WI
      04.5 TR GLI, 10 Wolfsburg Tiguan, 03 Allroad
      06-07-2012 07:59 PM #122
      didn't know you had this build thread. Subscribed. I hope the issue stands out like a sore thumb for you when you drop your tranny. You must have that down to a 1 hour job anyway by now.
      Don't start losing sleep. I know I probably would
    23. 06-07-2012 08:11 PM #123
      Yikes! That is pretty loud for a chatter! I hope you sort everything out and fix the problem.
      01' BT Jetta
      14' Audi Q5 TDi
      14' JSW TDi
    24. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      06-07-2012 08:15 PM #124
      Quote Originally Posted by SB_GLI View Post
      Thanks Man, pulled starter and checked flywheel and its not moving, turned engine over by hand a little at a time and looked for rubbing ect with my inspection mirror and nothing looks out of the ordinary, marked one of the pressure plate bolts while turning over and there all there...
      I'm starting to think my reinforced clutch fork is vibrating hitting the pinion brace, (not 100% sure yet) I have my slave cylinder out and am waiting for my buddy to come over, gonna pull the wires off of my clutch pedal so I can start car without clutch pushed in and fire it up, and use a magnet to stick to the clutchfork and keep it sucked in towards drivers side fender and see if that noise disapperars...
      Its probably a shot in the dark but I can always hope (would rather not have to pull transmission)
    25. Member One-Eight GTI's Avatar
      Jan 4th, 2010
      Duluth MN
      01 GTI 1.8T
      06-07-2012 08:16 PM #125
      Quote Originally Posted by EF9Si View Post
      Yeah its not chatter, workin on it
