Results 1 to 4 of 4
Thread: cis-e issues to lean (hight NO for smog test
  1. Member so.cal.sparky's Avatar
    Nov 8th, 2006
    Ventura CA
    04 r32 ,87 16v gti,64 5.0 ranchero,04 v6 passat
    04-19-2012 10:35 PM #1
    First off My car is 87 gti 1.8 16v cis-e
    I failed smog due to high NO ( which is high combustion chamber temp)
    I have checked for vac leaks None!
    dpr is at 4.5 to 5 at idel when hot
    changed injector seals
    seal for idle adjustment
    new vac lines
    two years ago had same issue with no fix
    then i changed
    fuel filter
    fuel pumps (both)
    cat
    02 sensor
    help
    Aug 14th, 2005
    Germany
    04-20-2012 02:07 AM #2
    You don't state ignition timing or engine coolant temperature. As you said, high engine combustion chamber temperatures are the cause of high NO readings and both of these can raise it enough to fail. I know they are watchfull where you live of tricks that some people have used to pass so I'll skip any of them, like rigging the radiator fan to stay running or the heater to be stuck on high. So make sure the timing is set to the low side (not advanced more than the book and maybe a tad lower) and make sure you not running too hot. You also have to come to terms with the possible fact that a CAT ages and could just need replacing.
  3. Member so.cal.sparky's Avatar
    Nov 8th, 2006
    Ventura CA
    05-23-2012 10:04 PM #3
    so I timed it to spec
    changed water/coolent
    fixed a exhaust leak off the manifold
    new injector seals
    i sill failed today ready to put a bullet in it
  4. Member so.cal.sparky's Avatar
    Nov 8th, 2006
    Ventura CA
    05-27-2012 01:06 AM #4
    ok so i hooked in a wideband o2 sensor at idel its at 14.4-14.7 as soon as i drive it 16 to 22 full lean out i need some help please
