where in NY? I live in Owego near Binghamton. might be interested.
PM if you like.
#1
Im selling my 93 cabriolet as is. it's not running right now from blown head gasket. i started working on it so the head is off and i completely lost interest. i have put well over $1400 into the car since february of this year and much more in the months before.
since feb...
New fuel pumps (both)
New front struts, mounts and bearings
New rear shocks
New shifter rebuild kit (very smooth)
New wheel bearings all around
New rear muffler
New alternator
New radiator hoses
New low temp thermostat and low temp fan switch
New drivers side axle
New expansion tank and cap
New front rotors and pads
New fuel pressure regulator
New reverse light switch and coolant level sensor
New clutch cable
past six months...
New master cylinder
New rear drums, brake shoes and wheel cylinders
New tires
New timing belt and tensioner
New water pump
the car is dark green with tan leather. also has new matching top boot never used til now for pictures. the top is not in the best shape. the hood left fender and front bumper cover are black. the bumper cover is off right now from towing it home and never put it back on. im sure theres more im forgetting. blue LED's in the gauges and console pods.
new plugs, wires , cap and rotor, oil and filter and fuel filter also done recently. the car has 200,000 miles. no rust around windshield or anywhere except a tiny spot over rear wheel.
price is $1000. put a head gasket and new studs and drive. thats it.
#2
PM if you like.
1993 Cabriolet In Progress...
#3
i will also throw in the tow bar i bought to tow the car home. you just need a trailer hitch with a 2" ball. i towed it 130 miles no problem.
#5
Bump
Off topic, where did you find the boot cover with the seat belt cutouts? Im having a hard time trying to find one.
Good luck on the sale.
"help control the pet population, have your pets spayed or neutered"
#6
#12
BUMP for my car's twin. Same colors, in and out
Goodluck on your sale
#14
After a 4 hour tow ride It now rests in my garage. New home Rochester NY. I will keep you posted on the progress. Thank you for a smooth transaction.![]()
