Results 1 to 4 of 4
Thread: High Ron gear changes
  1. Member codergfx's Avatar
    Jan 10th, 2009
    Cali
    03 GTI GT3076r
    04-20-2012 04:35 AM #1
    Well I just got my new motor running and new setup. On my old cheap eBay clutch I didn't have these issues. It would switch gears without grinding @ 7.5k rpms. But now with a ACT 6 puck it doesn't go in into gears under high rev. I did take the motor and tranny out, bled the clutch twice but still comes up with some air after usage. Installed new slave cylinder.
    It switches into gears but takes about one 1-2 seconds to do it, rpms have a chance to drop 1k before i hit next gear, if you do it fast enough itll grind. Even with pedal fully depressed before attempting to shift. Only past 6.5k rpms, before that shifts go fairly smooth
    My thoughts: bleed the clutch and realign the linkage? Am i missing anything else?
    Update: Bled the clutch, drove around same amount of air. USED VAS TOOl to power bleed the brakes, then clutch again. Came home still air in clutch. Bled one more time (got all the air out) started the car then pressed brake 15 times turned it off, checked for air and sure enough still a good amount of air in clutch system. Brake master or Clutch master?
    MY BUILD | 2003 Volkswagen GTI 1.8T | CTT - Carrot Top Tuning - GT3076r, 3" to 2.5" turboback exhaust (vbanded), Tial 38mm wastegate, fx400 6 puck, Peloquin LSD, VF Poly Engine Mounts, Greddy Profec B Type II, walbro 255 inline fuel pump, ID1600cc @ 3bar running on e85. AMB head, AWD bottom end. 424whp 369wtq @ 30psi (OLD: 383 whp 333wtq @ 23 psi)
  2. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    04-21-2012 04:00 PM #2
    try different gear oil.
  3. Member codergfx's Avatar
    Jan 10th, 2009
    Cali
    03 GTI GT3076r
    04-21-2012 07:37 PM #3
    I think the issue is my clutch no fully disengaging because of the air issue, i did however install a new ACT 6 puck clutch during the build could it be faulty?
  4. Member codergfx's Avatar
    Jan 10th, 2009
    Cali
    03 GTI GT3076r
    05-06-2012 03:34 AM #4
    Well now replaced the master cylinder, drove done didn't really get on it first startup after bleeding clutch felt hella good, trying to get on it from second to third and it just grinds @ 7k rpm and now even brakes feel a bit mushy. Gonna go home re bleed everything again.
    So far new slave, new brake master. So time for a new clutch master fml?
