hey wusup bro im intrested in this car, very intrested please call me or txt a.s.a.p. 732 372 59 04 thankss
#1
**sale pending**
Hello, I’m selling a 1987 VW fox gl wagon. This wagon is white on a gray interior and overall looks and runs great. The engine has been swapped for a 2.0 3A engine with a 1.8 8V head; it was also converted to a 5 speed manual. The car will come with tons of extra parts which will be listed. I bought this car from my brother who owned it for 5 years; this car was his baby and he did a lot of upgrades and repairs; he had to sell it due to downsizing his home. I purchased it from him about 6 months ago; the car was in good shape as is, I just gave it a good cleaning and fixed a few things. The car drives great! It has tons of power and handles well for having manual steering. The clutch works properly as well and reasonably tight. I am selling due to some hard times and I already own another car. I believe in full disclosure and I know that when I buy a car I like to know as much about it as possible, so I took plenty of pictures, shot some videos, and am including all information I have on the car that I have and can remember. If you have any questions please don’t hesitate to ask me.
163k on the body, under 40k on the rebuilt engine
Easily get gas mileage in the high 20’s with over 30 HP over stock!
Original paint, glass, & body panels
Bentley service manual
*Brand new NJ state inspection*
Powertrain:
Audi 3A 2.0L engine
1.8 Big Valve Head with solid lifters
1.6 Hi-Po Cam (the stock 1.6 cam yields Hi-Po results in 1.8 head)
Big throttle body with WOT switch (not hooked up, needs different ecu)
Dasher Dual Port Exhaust Mani
TechTonics Tuning Dual port Downpipe
2" custom exhaust into Thru flow muffler
TechTonics Hi-Flow CAT
11.5 pound Flywheel
PSA 5-speed mani
BMW E30 motor mounts
New radiator
Changed coolant to pink R12
New-ish clutch cable
Newer belts
New transfer fuel pump and main fuel pump
Newer cap, rotor, wires
New bosch platinum plugs
New oil pressure switch
CIS-E fuel injection system working properly
K&N drop in air filter
Newer battery
New O2 sensor
Fresh oil change
NO LEAKS!!!!
RUNS GREAT!!
Exterior:
Paint looks great for year
Some rock chips
All body panels are straight
Some rust
NO scratches, only 2 tiny dings
rare “brazilian” smoked taillights
Clear coat is peeling in drivers side in some spots
Windshield will need to be replaced, it is cracked
14” audi multi-spoke wheels
Rare window vent visors
Front struts need replacement
Rear shocks need replacement
All lighting functional
Autopal E-code headlights with sylvania silverstar ultra bulbs
Brand new trico teflon shield wiper blades
TIRES: will need replacement…. Fronts have some meat but are slightly dry rotted and rears are bald
Brakes are good but would hurt to be replaced sometime in the future….. front pads have plenty of life left and rotors look good, rear shoes are fine and parking brake engages in only 1 click
Interior:
Modded cluster with tach, blue LED lighting (glows blu/green at night)
Crank windows work properly
Carpets in decent shape and seats are alright as well…. There is a small hole in drivers seat bolster and the drivers seat back rest is a little tired but still comfortable
Sony am/fm radio with an aux jack included (cd player broken)
Front dash speakers work well
Includes a small sub with amp….. it is cracked but fully functional and not obnoxious
Overhead console with dome light and modded map light with a blue LED
Heater works great
Has air conditioning…… it is working properly and the compressor is cycling as it should…. It is cold but not freezing cold so it probably just needs a charge; it is filled with the original R12 freon
Could use new shifter bushings
RH side rear ¼ panel not secured properly but its just cosmetic
Rear door panel not currently attached….. needs new push clips
Overall its clean and fully functional
Extra parts:
These are included in the sale…. Use them for your own use or sell them for profit! This is a list of most of the stuff…… some if the items there is more than 1
L&R door panels; LH rear ¼ interior panel; door latch, both exterior door handles; both outside mirrors; horn button; exterior light lens’; 2 fuel filters; front strut mounts; 1 front hub; 2 cv boot kits; 1 rotor; turn signal/wiper switch; door armrests; wiper arms; unknown wire harnesses; 2 non-oem rectangle fog lights; overhead console; RH visor; speedo box and cable to speedometer; coolant tank; 2 fuel distributors (unknown if functional); lower intake box; intake pipe to throttle body; crankshaft pulley; wagon taillights; insulation and weatherstripping; RH headlight trim; ignition coil; bulb sockets; 2 H6054 headlights; fuse panel block; 3 engine computers (I think one is for an audi 4000 to use the WOT switch) and I also found a wiper switch that was a bit odd….. it has a sliding part on the front (delay setting I think?) and a button on the end saying MFA
Again if you have any questions please ask! Please contact me through PM on the vortex or email me at fatngs@yahoo.com
$1850obo
http://photobucket.com/foxforsale
http://youtu.be/FAyXqYoWuEo
http://youtu.be/i1JiEFNyxA8
http://youtu.be/6DPLw9lXNjI
http://youtu.be/8wPjjCU91Ks
*i know i did mention in the video that i would be relacing the plugs, wires, and vbelts but i will leave it as is because its running perfect as is*
*when attempting to check a squeaking alternator vbelt i noticed the bolt holding it up stripped and sheared off..... removed the bracket, drilled out the old bolt, and replaced it with a brand new bolt and locking washer..... shearing alternator bolts is common on these foxes so thats one less thing to worry about!*
i am located in south jersey near atco raceway
thanks!
#2
#3
sure thing, ill try to txt u 2moro if i can get a chance (im workin all day)
#4
car is fixed back up and running perfect..... brand new upper alternator bolt.... one less thing to worry about!
#5
PM sent have cash in hand want car.
Dieselgeek sigma6, APR carbiono stg1/2, APR tbe, golf r tails, euro switch, RNS-510 retrofit/w video in motion, 40%side 35%rear tint, rear wiper delete, bsh CC, neuspeed ic-tb pipe, AWE pancake pipe, S3 intercooler, defi gauges, Apr Ko4, VW RVC, AST 4100's, Hochkis F/R swaybars, 18x8 TD 1.2, 235 Dunlop star spec, F 6pot-R 4pot brembo
#7
If u don't sell plz txt or call me at 267-374-2760 near Philly really want to look at car soon. Thanks ron
#14
Hi Friend,
I need a straight answer...Is this car for sale or not? What's the deal with the Chrome siding?
I live in Vermont and Ihave own two of these and I'm looking for a "cream-puff."
IF? there is anything that this FOX Wagon needs or may need what would that be?
What you say my friend?
Sincerely Ralph
#15
been 4 months. its 2 grand, i doubt that its a lapse of attention to his selling need, two options come to mind, he dont wana sell, though no one types that much and doesn't intend to follow up, second is he sold it and his purpose fulfilled he didnt update,. much of society is like this, layercake, like how at the end of the credits they show more movie, and people that left react with hurt when they hear. but then again if people thought things out and had patients we wouldnt need pawn shops.
