Results 1 to 6 of 6
Thread: Need an Excel expert
    Sep 6th, 2008
    Expat in VA
    2006 A4 Avant
    04-20-2012 12:50 PM #1
    I need some help with Excel. I have 3 columns of data:
    1 - Job
    2 - Machine
    3 - Date
    The data basically shows a job, running on a machine, at a particular date. A job runs on several machines over various dates. What I want to achieve, is to have a single line per job, have the machine numbers running across the top of the sheet (column 2 onwards) and populate the date under the machine for the job.
    Kind of like setting up a pivot table, but instead of counting the dates, I simply want it to show the date.
    Any way to do this? I want it to be repeatable on a weekly basis, so the less manual steps the better.
    Thanks.
    Quote Originally Posted by SSLByron View Post
    People do so much stupid **** around me that I'm just past the point where I waste my blood pressure on it. I find my way around them and get on with my life.
    Xbox Live: DaDa5069
  2. Member Godsspeed's Avatar
    Apr 13th, 2008
    Fishers, IN
    2000 passat 1.8t auto
    04-20-2012 01:10 PM #2
    give me a second......
    you would like the following:
    | Machine 1 | Machine 2 | Machine 3 | Machine 4 | etc..
    Job 1 | 4/18/12 | 4/18/12 | 4/19/12 |
    Job 3:| 4/18/12 | 4/19/12 |
    (my formatting didnt stay.. the vertical lines rep a column.....
    correct?
    Im REALLY close, but have an issue if a job is on the same machine for 2+days......hmmm
    Sep 6th, 2008
    Expat in VA
    2006 A4 Avant
    04-20-2012 07:55 PM #3
    Quote Originally Posted by Godsspeed View Post
    correct?
    Yep, that is correct. And a job can be on a machine for more than 1 day (will have to double check on that though).
    Xbox Live: DaDa5069
  4. Member
    Sep 6th, 2008
    Expat in VA
    2006 A4 Avant
    05-04-2012 03:14 PM #4
    OK, so I managed to figure the first part out. But now am stuck with a different problem. I am trying to calculate start/end times for jobs running on a machine based on a 20 hour day, 5 day work week. Shift starts at 6am, and ends at 2am (the following day).
    I am using the following formula in cell C1:
    =WORKDAY(B1,CEILING((B2+MOD(B1,1)-B$3)/(B$4-B$3),1)-1)+MOD(B1,1)+B2-CEILING(MOD(B1,1)+B2-B$3,B$4-B$3)+B$4-B$3
    B1 - Start Time (5/4/12 11:00am)
    B2 - Run Hours (4 hours)
    B3 - Shift Start (6:00am)
    B4 - Shift End (2:00am)
    C1 would then show End Time as 5/4/12 3:00pm.
    If my Shift End time is before midnight, then it works no problem. As soon as I change that time to 2am, I get a #NUM! error.
    Any ideas? It's got me stumped.
    Thanks.
    Xbox Live: DaDa5069
  5. Member GreenandChrome's Avatar
    May 24th, 2002
    Washington State
    Sportage
    05-04-2012 06:19 PM #5
    Quote Originally Posted by naiku View Post
    Thanks.
    Format cell to recognize/transpose to 24-hr time?
    //// twitter: mbull //// flickr ////
    //// Humans are the only beings on the planet that raise trees, cut trees, process trees to make paper, and then write on that paper: "Save the Trees." ////
    //// Stop making things idiot-proof. We're just making better idiots. Not the way we need to be going. ////
  6. 05-06-2012 12:31 AM #6
    Hello,
    Salutation to this one of the forum site.
    Myself Jyaky Petter from the nation of India
    at this point we are going away to thrash out in the automobile discussion
    We can argue many kind of debate from the forum
    We not only discuss but also dig up a lot more knowledge from
    Various Google experts.
    Thank you………………………………………………………..
    2013 MERCEDES BENZ SL-CLASS
