Results 1 to 7 of 7
Thread: Searched Guessing new issue?
  1. Junior Member
    Mar 25th, 2010
    weslaco tx
    99 cabrio 5sp
    04-21-2012 11:10 AM #1
    So I read the manual and it stated when your check engine light blinks it is your catalytic converter. When it did that only once, but since then sometimes I start my cabby and it idles low and almost wants to turn off. So I drive it around and I get this funny smell then the car idles fine (i think my gauges dont work). thats the first problem
    2nd. I get this loud noise when I drive it sounds like it is coming from the exhaust, but when I am idle there is no noise.
    3rd. As I accelerate, there is a loud ticking noise from the engine. I think it has to do with the oil I am using 10w40 but like I said I am unsure
    Thank you for your help
  2. Junior Member
    Mar 25th, 2010
    weslaco tx
    99 cabrio 5sp
    04-28-2012 03:08 PM #2
    bump
  3. Member backinthegame's Avatar
    Dec 13th, 2004
    Virginia Beach, VA
    92 Cabriolet(RIP),89 Cabriolet, 03 A6 Avant, 93 Trek mtn. bike
    04-28-2012 03:50 PM #3
    Solid check engine light means get your car looked at soon, flashing means turn it off and get it looked at ASAP or you could do damage.. CELs are emissions related. Can be a sensor, coil pack, cat, or anything dealing with your emmissions. If the funny smell you get smells like sulpher (rotten eggs). that is a bad cat.
    Sent from my Droid using an escape pod to Tattoine.
    Quote Originally Posted by mad8vskillz View Post
    they're trying to skip out on their contracts via rapture. not very christian of them
  4. Member vwdtag's Avatar
    Feb 2nd, 2005
    1981 Rabbit Conv, 1995 GTI
    04-28-2012 10:13 PM #4
    a blinking cel means a engine missfire. a missfire will cause damage to catalytic conv.
  5. Member ToplessBunny85's Avatar
    Jan 6th, 2009
    Whitby
    The Laffnstalk
    04-28-2012 10:51 PM #5
    ^ What they said. Engine light on means something's wrong but isn't major. Engine light blinking means something is doing immediate damage to the catalytic converter. You might have cooked something, a sensor, possibly your cat.
    As for the exhaust noise the only things that really make noise around an exhaust are heat shields and internal bits. Not sure what your problem could be there.
    And ticking on acceleration is typically valves. 10W40 is what I run in the winter, 20W50 is usually the best choice for summer. Maybe do an oil change and throw some Lucas oil in.
    Doing it right is overrated.
    Quote Originally Posted by builtvw View Post
    girls + vw = hot....vw girl from canada...daaaaammmmn
    Volks R Us
  6. Junior Member
    Mar 25th, 2010
    weslaco tx
    99 cabrio 5sp
    04-30-2012 08:35 AM #6
    thank you guys, I went to advance auto and the cel was misfire in cyl 2....sadly I already replace my sparks and wires so they were thinking it was a fuel injector. I bought some seafoam and see if that will clear it up thank you again
    Nov 30th, 2010
    Apple Valley, MN
    86 Cabriolet, 73 Super Beetle
    04-30-2012 08:59 AM #7
    I wouldn't be so fast to call it an injector. Sounds like a coil pack
    dink and flicka
