upgrade that bar to the garbage or make it smaller if you want to kick out the rear end more in corners.
#1
So I'm going to be dropping the k-frame to mess with the steering rack. It would be a good time to remove the front swaybar if I so choose. Anyone have auto-x experience before and after removing the front sway bar?
I am running an Neuspeed front bar, Shine rear bar, KW V3s with 512 lb/in front springs and 350 lb/in rear springs. Corner weights are near perfect and the front/rear balance is a horrific 62/38. This was after relocating the battery to the passenger side rear of the hatch, but before pitching the A/C system and power steering system (this weekend).
I've been auto-x'ing for the past 5 years, but I've always had the front bar on there. The car tends to understeer a little more than oversteer when pushed hard, but when the conditions are right, the rear end steps out a little.
WWVD? (what would Vortex do?)
-Wayne
#2
Forced convection.... Now we grillin.
Some times she goes, some times she doesn't.... Way of the road
Rem 870 super mag in max 4 camo for sale. Pm me
#3
I wouldn't lose the front sway bar completely - just reinstall the stock front sway bar.
If you don't have a stock front sway bar you can have mine (it would be awesome if you would help me install my new one though)
#4
Poop. I wish I would've asked earlier. I think putting a stock front bar back in would'e been a good intermediate step (if I still had it). I reinstalled the k-frame last night and left the Neuspeed swaybar in there. I figured I'd leave it since I just changed the springs to a 25% higher rate. I probably shouldn't change too many variables at one time.
I can definitely give you a hand when you install yours.
When are we gonna see you at some local auto-x's?
#5
When my suspension stops sucking. One of my rear coilovers is leaking a bit (Koni should warranty it) and the damping adjuster on one of the front coilovers is seized. I need to have all my coilovers rebuilt.
Despite having under 15,000 miles on my:
R32 control arm bushings
New stock front control arm bushings
Balljoints
Tie rod ends
Motor mounts
Subframe bushings
Steering rack bushing,
I still have a disgusting clunking/popping in the front end. It happens when I let off the gas or accelerate hard. One of my axles is new too. The whole front end is just crap![]()
#6
Wayne - I noticed that you have changed out your springs on the KW V3s a couple of times. Do you have any of the old springs? I'm looking to up the spring rates on my Konis (and switch to linear springs).
#7
Yes, I have the stockers. They are 60mm I.D. springs. Fronts are 70kg/mm (400 lb/in) and 170mm (6.7") free length. The rears are 50kg/mm (250 lb/in) and 200mm (7.9") free length. If those are an upgrade for you and the numbers work out, they're yours.
-Wayne
#8
Hmmmm OK, let me look into it. Are they linear springs, or progressive?
I still need to get my coil overs rebuilt (scared of how much it may cost).
#9
Linear rate. I don't have any extra helper springs though...
#10
#11
#12
