Results 1 to 18 of 18
Thread: Am I going to need an impact driver to remove the rotor set screw?
  1. 04-22-2012 12:41 AM #1
    I have new rotors and pads and am willing to install them. I have done a couple other brake jobs before but not on VW and of course VW makes like SO EASY for DIYers!!
    I had the one front tire off today and realized I didn't have the 7mm hex driver in my tool set so I had to bag the operation before T-Storms came rolling in. One thing I tried to do was get the rotor set screw off. I took one look at the corroded phillips screw and thought no way is that coming off by hand, but I gave it a try anyway and sure enough it didn't budge and I almost stripped some of it. A PHILLIPS screw???!!! REALLY, VW??? A screw is bad enough for that area of the car but at least make it a torx or hex? PHILLIPS???
    Just for kicks, I tried my cordless screwdriver on max power and no movement on that either. So, am I wondering if anyone out there has had any luck removing that blasted screw with anything other than an impact driver, which conveniently enough for me, I DON'T HAVE right now!
    Oh, and if you were wondering, these are the original rotors and brakes on my 2002 VW Jetta wagon so there is plenty of SEIZE power to overcome in this whole brake job. That set screw is not coming out without a fight. Even if I get that screw out, I have heard the rotors can seize in there pretty nicely. Great. I am ready to throw out the DIY white flag and take it to the pros.
  2. Member dkline87's Avatar
    Feb 10th, 2007
    Kent Island, MD
    24V32T
    04-22-2012 01:02 AM #2
    try a manual impact screwdriver. I had to use one the first time I did the brakes on my '03 GTI and it worked like a charm. The one I used was really old, but something like this should do the trick.
    http://www.harborfreight.com/impact-...ase-37530.html
    heres another one if there is a Sears near you.
    http://www.sears.com/craftsman-impac...1&blockType=G1
    Goodluck!
  3. Member cuppie's Avatar
    May 3rd, 2005
    Redford, MI
    88 Scirocco 16v (Wilda); 86 QSW (still unnamed); 90 325iX (Nina - kid's car)
    04-22-2012 02:21 AM #3
    ^ ^ ^ This.
    An impact gun (if that's what you were thinking of) will just make a mess of the screw. An impact driver (pro tip: a 3lb short-handle sledge is the perfect implement for it. Ear protection is recommended!) is the right tool. Reason: it drives itself into the screw as it twists the screw. Prevents round-outs.
    (For installation: Just snug it up with a screwdriver. It's only an M6 screw...)
    As to the rotors being stuck:
    That's Brakes 101. Cast-iron rotor, steel hub, aluminum wheel... Add wheel cleaner (nearly always corrosive), water, road salt, heat, and time, and... it'll corrode. But, that's what a big hammer (like, the aforementioned 3lb sledge) is for.
    Put one wheel bolt in (4-6 turns), so you don't launch the rotor.
    Strike rotor from its backside with the nice heavy hammer. It'll come off.
    Clean hub with wire wheel on drill.
    Before installation: wipe a coat of anti-sieze around the snout on the hub (a little on the face of the hub is OK); and apply some to the rotor screw, too. It'll help things to come apart a lot easier next time (and, help keep the wheel from getting stuck too.)
    - Cup
    '88 Scirocco 16v, 'tastefully' modified.
    things currently broken (Scirocco): 3
    things currently broken (QSW): too many; but, slowly getting better
  4. Member OddJobb's Avatar
    Nov 6th, 2004
    Greenville SC
    2004.5 Jetta GLI, 1995 Golf III City
    04-22-2012 11:04 AM #4
    Worst case you can simply drill the rotor screws out and get new ones. This is what is done most of the time when they're corroded/rusted in.
  5. 04-22-2012 06:44 PM #5
    All good advice. Thanks!
  6. Member
    Jan 20th, 2000
    Falls Church, VA
    1993 SLC, 1992 SLC, 2003 GLI
    04-22-2012 10:58 PM #6
    Manual impact screwdriver is the way to go.
    Mar 23rd, 2008
    N/A
    N/A
    04-23-2012 01:34 PM #7
    Use a plenty of anti-seize on the replacement rotor screw, and don't crank it in super tight.
    The screw is only used to hold the rotor in place when the wheel is off the car, once a wheel is mounted, the rotor screw serves no purpose. You can even mount the wheel on the car without the screw if it breaks broken off in a front wheel hub or rear rotor (it will be harder to start the first lugbolt since the rotor can turn and misalign with the holes in the wheel hub).
  8. 04-24-2012 10:19 AM #8
    More great info. Thanks!
    It was mentioned above by cuppie that these rotor screws are size M6 so I can just pick up a few new ones at the local hardware store, right? No 'special' VW feature that would require me to get these at the dealer? I want to be prepared in case I need to drill out some of these screws.
  9. Member cuppie's Avatar
    May 3rd, 2005
    Redford, MI
    04-24-2012 11:37 AM #9
    The only "special VW feature" that I can think of, would be their somewhat odd size.
    M6x1.0 (normal so far...), by 15mm (slightly wierd length - 16mm is a little more "standard", and would work), countersunk Phillips-head screw (that's where it gets hard to find.)
    They are available from the dealer, you know.
    Auburn VW (1stVWParts.com) shows list price (part# N90529301) as 60 cents each.
    - Cup
  10. Member
    Mar 6th, 2002
    Morris Plains/Parsippany, NJ
    1998 GTI 2.0
    04-27-2012 09:33 AM #10
    If the screws don't come out nicely, just drill them out (I usually use an acetylene torch if it gets to that point), or if they break off in the hub, just leave the broken piece in there.
    If it does come out nicely, use plenty of anti-sieze during re-installation.
    As mentioned above, the rotor can be installed without that screw. The screw does make installation of the wheel a little easier, but it's no big deal. Probably half the cars I repair with a Phillips screw on the rotor (mostly Honda and VW) go back together without said screw due to complications during removal.
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  11. Junior Member
    Feb 12th, 2012
    Where the Navy sends me...
    '03 Jetta GLI, '93 Corrado SLC
    04-27-2012 07:49 PM #11
    Just try some liquid wrench before going to the extremes. It could take more, but I've always had good luck with that stuff.
    -Holmes
    People are always surprised that my car smells of crayons
    Mar 6th, 2002
    1998 GTI 2.0
    04-27-2012 08:42 PM #12
    Quote Originally Posted by Holmes741 View Post
    You can try Liquid Wrench, PB Blaster, WD-40, etc...but if an impact driver doesn't break it loose, the only answer in my experience is heat (or drilling if heat isn't available).
    Then again, it'll probably pop right loose with an impact driver. VW's generally don't seize so bad. Hondas/Acuras on the other hand, probably 7 in 10 they seize and the new rotor goes on with no screw.
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  13. Member arethirdytwo's Avatar
    Apr 4th, 2007
    Austin, TX
    '07 335i Sedan, '04 R32, '82 300D, '95 Jetta
    05-04-2012 10:59 PM #13
    Get the driver, cheap and easy. I'd hit it with bolt breaker, heat it with a MAPP torch and then it should come out.
  14. 05-23-2012 04:53 PM #14
    I just want to follow up on how things went and provide some additional info that might be helpful to the next person who does this job. First off, I purchased the manual impact screwdriver from Harbor Freight. It ended up being like $5. What a DEAL compared to the $25 Craftsman. This thing worked like a charm. I first sprayed PB Blaster on it and then used the impact screwdriver and it worked EASILY. For the next three rotor screws, I tried to get them out without even adding any PB Blaster and the impact screwdriver made short work of them. I HIGHLY RECOMMEND this tool in your arsenal and a big THANKS goes out to dkline87 for that link to Harbor Freight. It seems like those rotor screws were not bad after all; maybe it was just that one that was stuck more than the others.
    The tougher problem ended up being the rear caliper carrier bolts. Those beasts were on their super tight. I had to spray them a couple times and then use a breaker bar to get them to budge. I was putting a ton of torque on that thing as well and almost stripped one of the bolts. Therefore, I recommend that you be prepared for those ones if you are doing a rear brake job.
    Thanks to all for the good advice!
  15. Member
    Mar 6th, 2002
    1998 GTI 2.0
    05-23-2012 05:09 PM #15
    Quote Originally Posted by The_Dark_Knight View Post
    Depending on the car, those carrier brackets may not have to be removed to change the rotor. In my experiences with VW, they usually don't have to come off.
    1998 GTI 2.0
    1993 Jeep ZJ 4.0
    World Automotive
  16. 05-27-2012 09:33 AM #16
    Whenever I have problems with screws or bolts corroding or sticking, I replace them with stainless steel versions. No more rust, corroding, or sticking. I normally get them at a nut an bolt shop here in town. If they don't have them they'll order for you.
  17. n00b
    Oct 1st, 2009
    Kingsland, GA/ Miramar, FL
    02 Jetta wag gls, 02 Golf gls tdi, 03 F-250 dsl, 01Honda Civic EX 2dr, 1985 Honda VF1000R bike
    03-30-2013 10:16 PM #17
    Quote Originally Posted by cuppie View Post
    Found these Countersunk Phillips-head screws at Lowes Home Improvment Store. The Hillman Group 2-Count 6mm-1.0 x 16mm Oval-Head Zinc-Plated Metric Machine Screws. Item #: 138592, Model #: 880757, Price $0.92
  18. Member GTijoejoe's Avatar
    Oct 5th, 2001
    OH
    '98 GTi, '06 Evo Mr
    04-02-2013 06:54 PM #18
    Just a little FYI out of left field.
    50/50 mix of Acetone and Power steering fluid is far superior to liquid wrench/WD-40/and PB blaster..... just thought I'd give that tid bit of secret info to you for breaking rusted stuff free... I promise you won't be disappointed.
    2.0T+034efi+meth = 300+whp = Part out PM me for anything
