Results 1 to 3 of 3
Thread: universal fan
  1. Member jaso028's Avatar
    Aug 12th, 2007
    02.5 24v GLI, 05.5 Jetta 2.5l
    04-22-2012 02:29 AM #1
    Anyone ever try to run a universal fan on our cars instead of the regular radiator fan?
    More or less wanna know if you can wire it in to the existing wires?
    Looking to use the connector portion of it, so it runs off the stock FCM??
    N.E.R.D.
    White Lightning
  2. Member Snitches Get Stitches's Avatar
    Jul 21st, 2007
    Southern NJ
    2002 Hybrid VR6T Jetta, 1997 Lifted Subie Outback
    04-22-2012 09:04 AM #2
    Yes...very easy to wire up aftermarket fans to the stock wiring. Find the oem wire diagram and go from there. From what i remember, the stock fans have 3 wires each...allowing a high and low fan speed. My Flex-a-Lite fans each have only a power and a ground. We wired mine so one fan comes on for low speed, but both fans kick on at the high speed setting. Good luck!!
  3. Member jaso028's Avatar
    Aug 12th, 2007
    04-22-2012 01:59 PM #3
    Nice.. Figured it was simple enough..
    Thanks for the pics!
    N.E.R.D.
    White Lightning
