Results 1 to 17 of 17
Thread: Vr6 turbo problems
  1. 04-22-2012 11:26 AM #1
    I have a 1995 GLX Jetta which I turbo over one year ago.I have a C2motoersport chip,36 pound injectors,a five bar ajustable pressure regulator I had a extra feul pump , C2 mass housing.i did every they said I should do and I can't get the car running.when I start the car it idle rich and when I go on boost I break up at 4000 rpm. It's my first time doing a turbo set up and being in Jamaica west indies every thing we need cost a arm & leg. I really need some help .
  2. Member d15nonvtec's Avatar
    Dec 18th, 2006
    PA
    00 A4, 06 GTI
    04-22-2012 01:22 PM #2
    Quote Originally Posted by delicate View Post
    Why do you have a 5bar regulator? Isn't the stock one a 4bar for OBD1?
  3. 04-22-2012 03:18 PM #3
    Quote Originally Posted by d15nonvtec View Post
    Yes it is but I was told I need to get the five bar
  4. Member d15nonvtec's Avatar
    Dec 18th, 2006
    PA
    00 A4, 06 GTI
    04-22-2012 03:21 PM #4
    What turbo and what sort of boost you pushing here?
  5. 04-22-2012 03:29 PM #5
    I have a t70 turbo and about 5lb boost
  6. 04-22-2012 03:51 PM #6
    If this is ok with you just call my number and hang up and I will call you right and you can help me out wit your information (1876-406-1117).I would apricate it.
  7. Member d15nonvtec's Avatar
    Dec 18th, 2006
    PA
    00 A4, 06 GTI
    04-22-2012 05:53 PM #7
    You should not need a 5bar reg at that boost level. I will assume you have older c2 software. If you called them recently the answers you get are hit and miss unfortunately. You should not need an inline pump either at 5lbs but it wont hurt to have it. I would swap to a 4bar, reset the ecu to start with.
    Check your o2 sensors, check your MAF, look for issues with your intercooler tubes/couplings (if you have an intercooler)
  8. 04-22-2012 11:48 PM #8
    Ok that I will do in the morning, as for the pluming what I should check for leaks? I have got a big enough inter cooler at the front and I also have a water injection system which I don't used yet.So in other words you are saying I should send the chip back to C2 for reprogram ing. My friend got a chip too for a 2.0 and having similar problem too and because we are so far away it cost a lot to send back the chip.i will try what you say and then see what happen and let you know.Thanks and as BOB MARLEY SAY ONE LOVE
  9. 04-24-2012 09:15 PM #9
    I did ever thing you mention but the same thing is happening
  10. Member BonusParts's Avatar
    Aug 1st, 2009
    Blue Bell, PA
    98 GL, 95 GLX
    04-24-2012 10:12 PM #10
    Okay, so the car still idles rich and breaks up past 4K?
    Is your CEL on? If so what codes does it give you?
    Secondly, is this OBD1? If it is, i'd try this: DELETE your Idle stabilizer valve, and set your idle via the set screw on the throttle body itself. Also, test your TPS with an ohm meter, its called a sweep test. With leads on the pins that give you a resistance, have someone slowly press the pedal down. the reading should be linear between 0-100ohm.
    One other suggestion would be to pull the ecu and remove the C2 chip. clean the board with compressed air, especially the socket and reseat the chip. I've heard AWFUL horror stories about C2 chips doing goofy **** like this and being nothing more than an improperly seated chip.
    Good luck! VR-T
  11. 04-24-2012 11:28 PM #11
    What is your wideband reading when it breaks up?
    What are your fuel trims long term and short term?
    If you don't have a wide band, and can't log fuel trims/knock/ect, then you are guessing in the wind waiting for disaster, and there is no possible way for anyone to help you on here.
    DON'T swap down to a 4bar reg, without knowing where you are sitting A/F wise, and being that the tuner told you the tune was made for 36lb injectors at 5 bar. That is the single worst troubleshooting advice for a FI setup you could give.
    Are you from New Jersey, or did you just get the paint job in New Jersey?
  12. 04-25-2012 10:38 AM #12
    I just bought a wide band 02 on line I don't receive it yet but the check light is in the car and I don't have a a scan tool to see what's going on. I am really a hands on person so I am trying by best to follow all instruction.
  13. 04-25-2012 10:48 AM #13
    I will try that but I have to get some help to walk me through it
  14. 04-25-2012 12:29 PM #14
    You ask if my CEL is on what does CEL mean? My car is a obd1
  15. Member VW_MK3_270's Avatar
    Feb 1st, 2012
    US
    Slammed&Cammed Golf
    04-25-2012 12:38 PM #15
    Check Engine Light.
  16. 04-29-2012 11:31 AM #16
    Quote Originally Posted by VW_MK3_270 View Post
    Check Engine Light.
    How do you tell the defference between 0bd1 and obd2
  17. Member brandon0808's Avatar
    Mar 19th, 2009
    West Bend, WI
    2003 jetta 20v. 1991 12v gti.
    05-05-2013 11:09 PM #17
    Where are you at right now with this issue? My vrt also breaks up at 4k
