Results 1 to 13 of 13
Thread: Electric Pressure Washer for Mossy Patio Pad and Driveway?
  1. 04-22-2012 01:29 PM #1
    My next equipment purchase will need to be a pressure washer. The purpose will be to clean moss off concrete.
    I am wondering if I can get away with an electric unit. I have only used industrial-type gas power in the past for car detailing applications.
  2. Senior Member spockcat's Avatar
    Jun 4th, 2003
    07 Z4MC, 11 328i Touring
    04-22-2012 03:48 PM #2
    I've got a 6.5 hp gas powered pressure washer and it is only acceptable for cleaning concrete. I doubt an electric one is going to be acceptable. However, you might try using a house cleaning and mildew killing product that mixes with bleach, available from Home Depot. I recently used it on our vinyl siding and it worked well. It should kill the moss and make it easier to remove.
  3. Member emmettlodge's Avatar
    Nov 7th, 2007
    Ohio
    2012 Tacoma 4x4, 2010 Tacoma 4x2, 1990 E30
    04-22-2012 06:25 PM #3
    The minimum pressure (PSI) that's generally acceptable for "blasting off" biological growth is about 1700 PSI with a 20 degree tip. Going over 2,000 PSI is highly suggested, especially if you want to use a wider tip such as a 40*. If you can find an electric pressure washer that does that pressure, then go for it.
    Biological growth is hard to get off because it literally lays roots which grow into the pores and cracks of the surface, making it latch on really well.
    Personally, I've never owned a pressure washer less than 3,500 PSI.
    All rights reserved. No fur-bearing animals were harmed during the creation of this post. Caution: May cause irritability, sleeplessness or warts after prolonged reading. May cause some laboratory rats to rip through their cages, fly across the room and brutally murder hundreds of innocent people. Not to be combined with other posts except under the advice of a physician.
  4. 04-22-2012 10:56 PM #4
    Alright, I will now consider the price of hiring someone vs. a real pressure washer. Thanks for the input.
  5. Member Gorgeous's Avatar
    Aug 15th, 2005
    Bellevue, WA
    2009 370Z sport/touring
    04-23-2012 07:22 PM #5
    You can rent a 3,500psi pressure washer at Home Depot.
    http://www.homedepotrents.com/diyTools/washer_3500.asp
    Not sure what the day rate is for one of these, though. I'm looking to do the exact same thing as you and this will be my solution, as I don't have ongoing needs to justify owning one.
  6. Member Tornado2dr's Avatar
    Mar 31st, 2001
    Split Pants, VA
    04-24-2012 07:12 AM #6
    I've got a hand-me down electric one that works fine for cars, blasting dust off the patio set/patio, here and there stuff - but it isn't nearly as strong as a gas-powered unit.
    The best thing about it is that it was free and I can't hurt anything with it.
  7. Member wildcar's Avatar
    Dec 4th, 2003
    hagerstown md
    IY 20th
    04-24-2012 08:57 AM #7
    I have an electric one and it does fine on concrete and siding. They have some newer electric washers that have really high presssures. remember that if you have gas you have to fill it and not let it sit for months on end with old gas and then does not want to start. Electric is quiter and only runs when you are activly spraying and stops when you release the handle, gas run constantly and gets louder under load. Another thing is electric is usually more compact than gas units so its easier to store. if you going to be doing massive amounts of cleaning than a gas is probably best
  8. n00b
    Feb 15th, 2012
    NYC, NY, USA
    04-25-2012 09:25 AM #8
    Electric Pressure Washer for Mossy Patio Pad and Driveway and rest of all items at 7% off just use this and get discount. This is a limited offer and I have already used it.
  9. 04-26-2012 11:48 AM #9
    Quote Originally Posted by wildcar View Post
    I've literally never had an issue starting a four-cycle power washer or mower after a winter season. That's with gas sitting all season.
    I have to say, there is nothing more gratifying than the before/after effect of a power washer on pacific northwest concrete.
  10. Geriatric Member ATL_Av8r's Avatar
    Oct 17th, 2002
    Gapiana
    04-26-2012 01:49 PM #10
    Try nicking the power cord and standing in a puddle near the nick.
  11. 04-26-2012 07:16 PM #11
    Quote Originally Posted by Markos View Post
    You'll never believe where this project is
    It'd be cool to have a gas unit, but I just don't see the value in dropping $500+ for my purposes, and I don't think I have enough water pressure to get into the 3 GPM range.
  12. Member vw fiend's Avatar
    May 9th, 2002
    Carmel, Indiana
    1966 Beetle, 1989 Jetta, 2001 Jetta, 2002 Jetta, 2011 JSW
    05-02-2012 11:35 PM #12
    tried the same thing with electric two years ago and gave up; it would have done the trick, just taken way longer. About three weeks ago, I tried again with gas:
  13. Member charlatan's Avatar
    Jan 7th, 2004
    Moline, ILLannoy
    MKV R32 / Jeep GC (WJ)
    05-09-2012 04:23 PM #13
    You could always rent one.
