VWVortex.com - The long-awaited "MkII FAQ/DIY Thread
    Page 1 of 20 1234511 ... LastLast
    Results 1 to 25 of 488
    Thread: The long-awaited "MkII FAQ/DIY Thread
    1. Global Moderator Paul@VWvortex's Avatar
      Apr 2nd, 1999
      Milk was a bad choice -- AZ
      '17 A3 E-Tron, '14 1500 HC, '96 VRT Cabrio, TDi Tristar Syncro, 1980 Scirocco S "Der Ott"
      10-30-2002 11:27 PM #1
      Ladies and Germs:
      Due to much peer pressure (and my overall coolness) I have decided to start this thread to hopefully serve as a resource as well as try to help cut down on the much-repeated questions in our thread that serve to add to the frustruation level here.
      Please add appropriate material to this thread; the things that are repeated will be deleted unless the general concensus is that they are more complete than the one that they come after. Please treat this as a working, breathing, living document and hopefully WE MkII'ers can lead the other forums by example.
      Carry on.....[IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Click the image to get The Bible
      [Modified by 16v, 1:31 AM 11-29-2002]
    2. Member vwtoys's Avatar
      Mar 31st, 1999
      Mk2 GTI, Mk1 TT, Q5
      10-30-2002 11:29 PM #2
      First one in
      G60 arches are the same as 91-92 GTI 16v arches, they are wider than 8v arches.
      [Modified by vwtoys, 8:30 PM 10-30-2002]
      Oct 28th, 2001
      Atlanta, GA
      '97 Audi A4, '03 BMW 325i, '06 Audi A4
      10-30-2002 11:30 PM #3
      To Search this thread use IE's search function by pressing control + F
      THIS THREAD IS NOT FOR QUESTIONS, IT IS FOR ANSWERS Thanks for understanding
      REPLACING SPEDOMETER CABLE/TEARING APART DASH
      look into buying it used or online or some place other then the dealership. it is not too hard for a novice mechanic, but it will take a while to tear apart a dash for your first time (first time 1 hour second time 5 min. ) the trick to doing this right is to pull the spedo cable from the tranny first, that is why so many suffer soo much with this. tell you what I will walk you through it.
      tools needed: #2 phillips, #3 phillips, any flat head
      1. pull the knob and dials off the climate control guage
      2. pull on climate control guage
      3. remove radio (good luck)
      4. remove switch blanks (pull)
      5. remove switches (push from rear of dash with figers) then disconnect from wires (pull on the plug not the wires)
      6. remove swrews holding inner dash (not the cluster) in place 2 at top of guage cluster, one on top of radio (I leave this one out so I don't have to pull my radio to pull my dash) 3 holding climate control (these are larger then all others) one behind headlight switch, one behind bottom left of the 6 switches
      7. remove the black plastic dash
      8. remove the 2 screws holding the cluster in place top right and left
      9. make sure the spedo cable is undone from the tranny and the screw is stored properly, like on top of the radiator support
      10. lift up and out on the cluster until you can see the plugs (some have 2 some have 1) on the bottom (use the flathead to unlock the plug the pull on the plug (not the wires!)
      11. remove guage cluster replace not attaching it to the tranny until the end
      "Becareful as there are two different speedo cables. One is a one piece unit from the trans to the cluster. The other is a 2-piece unit which runs from the trans to an O2 service indicator at the firewall and then to the cluster. Make sure you get the correct one." - 1987&2001Jettas
      MY REVERSE LIGHTS DON'T WORK
      this is a little switch on the transaxle (it is not a transmission, they are for rear wheel drive vehicles) just get another one. This as with all VW [IMG]http://*****************.com/smile/emthup.gif[/IMG] parts can be had for much less online or at your local parts store.
      Mike
      Modified by vedubya at 7:22 PM 3-3-2004
      I am not the transporter, I am not the transporter,I am not the transporter...
    4. Global Moderator Paul@VWvortex's Avatar
      Apr 2nd, 1999
      10-30-2002 11:30 PM #4
      Good start.... next?
    5. Member vwtoys's Avatar
      Mar 31st, 1999
      Mk2 GTI, Mk1 TT, Q5
      10-30-2002 11:38 PM #5
      BBS Wheels on Mk2's:
      In North America
      88-92 GLI 16v(GTX in Canada) ---- 15x6 BBS RA's, 1 pc cast.
      90-92 GTI 16v ---- 15x6.5 BBS RM's, 2 pc, 30 bolts, cast inner, rolled outer.
    6. Member SauerKraut's Avatar
      Jan 12th, 2001
      PNW
      TDI, Watercooled-aircooled Westfalia
      10-30-2002 11:46 PM #6
      anythig from brakes to clutches to speakers and gauge lighting
      Dubsquad Tech Support...pretty informative.
      [Modified by SauerKraut, 8:54 PM 10-30-2002]
      DCI FOR LIFE
      vansquad - poppin your top, bitch!
      dmiw.
    7. 10-30-2002 11:47 PM #7
      back when I was into making my webpage, I started this.....
      The A2 / MK2 VW FAQ
      1) What does Mk1/Mk2/Mk3/Mk4 or A1/A2/A3/A4 stand for?
      It refers to the body style of a vw. There are basically two main chassis designations for watercooled VW's.
      The "A" chassis includes GOLF (RABBIT)/JETTA/CABRIOLET/SCIROCCO/CORRADO/CADDY (RABBIT PICKUP)/NEW BEETLE. "MK-1" and A1 are the same thing, the british use "mk" designations which are pronounced "Mark - one" (not "emm-kay one")
      A1/Mk1 - - - Rabbit (american name for golf), Scirocco (both mk1 and mk2 sciroccos), Cabriolet,
      Jetta, Caddy (pickup) 1974-1984 with exceptions for cabriolet (92?) and scirocco ('88)
      A2/Mk2 - - - Golf, Jetta, Corrado with exception for corrado (a few '95s)
      A3/Mk3 - - - Golf, Jetta, Cabrio -exception to Cabrio which is still in production (2002)
      A4/Mk4 - - - Golf, Jetta, New Beetle
      The "B" series refers to the Passat cars. The B1 was known in America as the "DASHER," B2 was the "QUANTUM," B3 and later was known as the "PASSAT". B 5.5 is the latest model Passat (2002) that had visual updates but the chassis stayed the same.
      Mk is pronounced "Mark", mk designates the body style, A or B designates the chassis. So a scirocco is on the a1 chassis, but has two bodystyles designated mk1 and mk2. Otherwise all other VW's have the same chassis/bodystyle designation.
      2) What repair manual should I buy?
      The only repair manual that you will ever need is the Robert Bently, aka Bently repair manual. These are available from the publisher, http://www.rb.com , along with just about every VW parts shop and amazon.com and barnes and noble. These cost around $40 USD and are well worth it, if you are tight on money check out ebay or used book places (amazon and BN have used sections on their websites), sometimes they come around and are cheap.
      3) What engines were available?
      All watercooled VW's prior to 1986 were some variation of an 8v, none were larger than 1.8 liters. The Scirocco 16v was the first to recieve the 16v in 1986.5 (partway through '86 model year), followed by the GTI and GLI.
      '85-'87 GTI/GLI
      Prior to the 16v the GTI and GLI's were equipped with a high compression 8v engine which put out around 100-105+hp. These engines used CIS-e (KE jetronic) which had a knock sensor and control box to manage "pinging." All were 1.8L
      '85-'88 base/CL/GL
      The non GTI/GLI engines were low compression which usually put out around 90 HP. These engines were managed by CIS (with o2 sensor aka Lambada) All were 1.8L, some early "GX" engines had smaller valved heads and put out 85hp.
      88-92 8v
      Any engine that isn't a 16v that came stock was a 1.8 liter 8v. These put out 100 hp, unless the engine has a dual downpipe and exhaust manifold. These engines put out 105hp and more torque, they usually came on Jetta Carats or 90-92 8v GTI's. Engine management was controlled by Digifant II, this was VW's first "electronic" fuel injection. Some people refer to this as "digifart or digif*#^", it isn't a bad fuel injection, but it can be no fun to work on if you don't know it.
      87-89 16v
      GTI's and GLI's had these, they put out 123 hp. Controlled by CIS-E
      90-92 16v
      90-92 GLI and 91-92 GTI 16v's (not all GTI's were 16v from 90-92). These put out 134 HP and engine management was accomplished by CIS-e/Motronic. This was VW's first chippable (or easily chippable, digifant II can be chipped) FI.
      maybe someone could save these images and host them on vortex, or change the format to a html table...
    8. Member SauerKraut's Avatar
      Jan 12th, 2001
      PNW
      10-30-2002 11:49 PM #8
      DCI FOR LIFE
      dmiw.
    9. Member vwtoys's Avatar
      Mar 31st, 1999
      Mk2 GTI, Mk1 TT, Q5
      10-30-2002 11:50 PM #9
      Front Brakes:
      All Mk2's came equipped with 9.4" brakes and 20mm MC except 88 up GLI which has 10.1" brakes and 22mm MC, Golf GL and 90 up GTI 8v has solid discs up front, drums in the rear. 85-87 GTI 8v's and 90 up big-bumpered 16v's had 4 wheel disc and front vented 9.4".
      Front solid disc equipped cars can be upgraded with vented 9.4" rotors with thinner pads as the calipers are of a floating design.
      Any 9.4" upgrade to larger brakes means you'd need to swap steering knuckles, calipers, carriers, and a 22mm MC. Late model ball joints is also required if your car isn't equipped with one already.
      Any 10.1" brake setup can be upgraded to 11" by swapping carriers/calipers , discs and pads from a G60 Corrado.
      The big brake donor cars include:
      90-92 Corrado G60, 11"
      88-92 GLI 16v, 10.1"
      93 and up 4 cyl Mk3's, 10.1"
      B3 Passat GL (16v), 10.1"
      [Modified by vwtoys, 8:52 PM 10-30-2002]
    10. 10-30-2002 11:56 PM #10
      Golf (or Jetta) Growl"
      gives your car a nice throaty growl when floored, and maybe 1h.p.
      Shopping List:
      misc hand tools
      How To:
      If you have a Digifant II (88-92 8v) or a cis-e motronic engine (90-92 GTI/GLI 16v) this procedure is really easy. Take your lower airbox out, it is connected by two rubber band thingies (one in back fender side, one forward engine side), and three or four clips attatching it to the upper airbox. Take the airfilter out. You will see a cone thing in the bottom, take this out. I found the easiest way was to use a wide flattipped screwdriver on the outside portion to get it started, once that is loose push out from the inside of the box. Put a k&n filter in, if not so equipped.
      (again, if vortex hosted images...)
      digifant II box shown, take highlighted out.
      If you have a cis or cis-e car then you will need to cut out part of the box. I used a swiss army knife saw to cut mine. You don't want to cut a hole on the engine side, as this will suck hot air in (hot air=expanded air=less oxygen=less hp). Cut on the front or on the fender side. The hole should be about the size of an audio casset tape.
      feel free to take anything from my little how to page,
      http://members.aol.com/mk28v/howto.htm
    11. Member Tornado2dr's Avatar
      Mar 31st, 2001
      Split Pants, VA
      10-30-2002 11:57 PM #11
      On Jetta Coupes or Two-Door Jettas.
      Produced all the same years that regular MkII Golf, GTi, Jetta models produced(some say yes some say no for '92).
      Coupes are Basically Jettas with the longer doors that fit all two doors. The back seats are Jetta, they do not fold down.
      There were no coupes that caome from the factory badged as GLi models, and none came with 16-valve motors.
      The motors that were available were the 4-cylinder gas and diesel, with auto or 5 spd.
      The injection systems are just like the other models, it depends on date of production.
      Some coupes came with big bumpers, just like the other cars 1990 was a flip year for the bumper style.
      Anything else i am missing?
      Quote Originally Posted by Turbio!
      They make my ass look pretty.
    12. Member fopeano's Avatar
      Mar 2nd, 2002
      Rusty Upstate NY
      87 Jetta Coupe getting K20 Swap, 99 Accord Coupe DD, 83 Celica GT-S future project
      10-31-2002 12:16 AM #12
      Ken's Digifant Page- Great info for 88-92 8v owners
      Swapping a VR6 into an A2
      How I removed the A/C on a 1992 8v Jetta
      8v non A/C conversion kit 16v non A/C converion kit
      Two great technical tools: The discplacment calculator The compression ratio calculator
      THIS is the best of the best for dyeing the black plastic on your car. I've dyed the bumpers, mouldings, dash, and engine parts with great-looking and long-lasting results.
      Always use OEM/Bosch tune-up and maintenence parts to ensure optimum performance on a watercooled VW.
      I work at a VW dealer selling parts, and I do all my own work on the car. One thing I learned is don't take your car to a mechanic/shop that doesn't specifically work on VWs. I have gotten numerous calls from shops that deal with American cars, and they say things like "what's with these volkswagens?". VW's are kind of unique, mechanically. It seems that mechanics that don't work on VWs get confused sometimes. I would never take a VW to a shop that didn't say "VW" or acknowledge german cars in the name of the shop.
      I am somewhat frequently asked for tech advice over the phone when barney's shade tree repair shop calls to order a part, or to ask how to perform a repair procedure.
      Hope This Helps [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      [Modified by fopeano, 7:02 PM 10-31-2002]
      I used my 6 years of Mk2 hobbyist training to become a professional tech in 2006, but that makes you not want to work on your car as much.
      YouTube channel of my cars, blown up cars from work, and some of the more interesting work I've done
    13. Senior Member Big Dac With Fries's Avatar
      Feb 1st, 2002
      Spatula City
      6000 SUX
      10-31-2002 12:33 AM #13
      Using a G60 ValveCoverGasket:
      ~ Changing the studs, IS NOT necessary
      ~ The rubber gasket can be used with the "shouldered" studs
      ~ Simply remove (carefully) the metal inserts from the rubber gasket.
      The AKTIV Myth:
      ~ Some 6 speaker MKII's are Aktiv, while some arent.
      ~ It is to my belief that the high end (GTi/GLi/GTX) models were so equipped.
      ~ To find out if you are cursed with AKTIV or not, simply pull out your radio (heidelberg) and see what plug/slot is occupied by the brown (IIRC) plug. You'l see a plug marked for ACT. and one for NO ACT, Mine was the latter, and I did not have the AKTIV.
      Steering Spline/Steering Wheel Swaps
      ~ All A2's are not equal.
      ~ Sometime in 1989 (IIRC), VW changed the spline size, therefore post '89 steering wheels will not work on pre '89 models, and vice versa.
      Centre Consoles
      ~ All centre consoles are not equal.
      ~ I learned this the hard way, after modifiying a brand new console to house my radio.
      ~ The reason my new console will not fit 100 percent the way the old one did is because of different ducting within the console. My car is a/c equipped, whetehr this has something to do with it or not . . .
      ~ You can spot the difference by the number of side exits the console has, my stock AC one has one, while my new (maybe non ac) has two smaller ones.
      ~ The vital difference lies within the fact that the "intake" portion of the consoles are 1/2" different. Be aware of this, dont end up like me.
      The difference between the "spongy" rear spoilers and the "hard plastic" spoilers
      ~ When VW started to paint the rear decklid spoilers on the Jetta, they changed from the spongy black spoilers to the hard plastic spoilers. . . . they did so for a good reason
      ~ The spongy spoilers are flat black, and truly oldschool, but they hide a dark secret. The overall build of them is a steel skeleton, surrounded in polyurethane foam, then enclosed in rubber. Awesome design . . . . back in the 1970's. The flaw lies within the use. Once the rubber gets punctured, it turns the entire spoiler into a big wet sponge. The metal "frame" will quickly rot out, and stain your decklid with fugly rust stains.
      ~ The newer hard plastic spoiler is easily paintable, and is far superior to the older one. The studs are rust-resistant, and there's no sponge to soak up water.
      . . . i'll make another post in the morning.
      "I was thinking about what a friend had said, I was hoping it was a lie."
    14. 10-31-2002 12:49 AM #14
      Everything you'll ever want to know about MkII (and not only):
      http://www.nwlink.com/~vdb/cars.html
    15. Global Moderator 16v's Avatar
      Aug 4th, 1999
      laying the smack down from MA for 15+ years
      '14 Cdale Carbon Synapse, '13 allroad, '12 Cdale Bad Boy, '06 3.2 Avant
      10-31-2002 01:04 AM #15
      Lighting-
      Q: What are the options for OEM headlights on my A2?
      A: Stock Quad Round http://the16v.com/images/vw/djk/lites/djkround.jpg
      Stock Rectangular (Aero) http://the16v.com/images/vw/86/86front.jpg
      Single Round http://the16v.com/images/vw/djk/lites/djk91_lrp.jpg
      Single Round w/badgless grill http://the16v.com/images/vw/djk/lite...badgeless2.jpg
      Rallye Golf conversion http://the16v.com/images/vw/djk/lite...16v_rallye.jpg
      [Modified by 16v, 12:21 AM 11-29-2002]
    16. 10-31-2002 02:49 AM #16
      POWER SUNROOF
      16v AC removal
      Bearings
      Brakes
      custom votex
      flares
      LED dash lights
      mono wiper
      all found here
      http://chip.vwmafia.net/howto/
    17. 10-31-2002 02:52 AM #17
      Which is better...16v or 8v?
      Note: Either engine can be modded for high performance if done right.
      An engine is like an air pump.
      VW started out with 8 valves, then they figure then can pump air faster on the 8v by making it 16v...as a result, the motor got a little more complex, thus making it more expensive to repair and get parts. Four valves/cylinder makes pumping air easier. Four holes usually take up more surface area than 2 valves for air to flow through. Basically, the more air that can go in and out the engine, the more horsepower can be made. This is why you port and polish your cylinder head (especially the people with 8v) to increase power. Also, 4 smaller valves are individulally lighter and has less momentum than 2 big valves. Alot of people say 8v has more torque. This is not true because an 8v motor torque curve just peaks at a lower rpm. This creates the effect of more torque because the power comes on quicker without you having to rev it high. However, just because the peak torque in the 8v comes on earlier, it does not neccesarily means it is overall greater than a 16v. The 16v needs to rev a little higher in the rpm to get to it's peak torque but the peak can be more. The reason why an 8v is more ideal for dailing driving and normal commuting is because it is smoother due to the low rpm torque. It feels smoother because you don't gotta rev it up. Alot of people love this because high revving engine scares them and it make them feel like they are torturing the car. Why does 16v have to rev higher for torque? Because air passes in and out too fast so the explosion energy don't stay compress long enuff in the cylinder...it has to explode repeatedly quicker (higher rev) before the energy fade away.
      [Modified by 87GolfKart, 12:06 AM 10-31-2002]
    18. 10-31-2002 05:22 AM #18
      Information on special Editions (e.g. Edition One aka Wolsfburg Edition, Edition Blue, Limited, etc.) as well as everything else you'ld ever want to know about your Golf/Jetta MKII:
      http://www.doppel-wobber.de
    19. Banned
      Aug 4th, 2000
      10-31-2002 07:44 AM #19
      Make sure that you disconnect the negative battery terminal when doing most work under the hood that involves anything with the electrical system. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    20. 10-31-2002 08:14 AM #20
    21. Member VRpoweredA2's Avatar
      Oct 8th, 2000
      NYC
      10-31-2002 09:04 AM #21
      Damn...why couldnt this thread had been around about 2 years ago when i bought my first dub....
      This is seriously the best thread i have ever laid eyes on. [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    22. Member 2035cc16v's Avatar
      May 18th, 2000
      New England
      2012 GLK350 1999 A4 Avant
      10-31-2002 10:13 AM #22
      Volkswagen's part numbering scheme
      Each part number is composed of nine numbers in three groups,
      followed optionally with a letter suffix:
      vvv ggg ppp suffix
      Vehicle type (vvv):
      155 = Convertible
      171 = Golf I
      161 = Jetta I
      165 = Jetta II
      191 = Golf
      261 = 16V GTI
      531 = Scirocco I
      535 = Scirocco II
      Primary index (ggg):
      100-199 = Engine/Cooling/Clutch
      200-299 = Exhaust, Fuel Tank
      300-399 = Transmission/Transaxle
      400-499 = Front Axle/Suspension
      500-599 = Rear Axle
      600-699 = Brake
      700-799 = Cables, Bumpers and Foot control
      800-899 = Body/Interior
      900-999 = Electrical, ignition, fuel injection
      Individual Part Number (ppp):
      000-999 = Individual part
      The primary index and the part number are the most important numbers because many of the cars share the same parts. So do not be surprised to see a 171-Rabbit type part in a Jetta.
      Note that some part numbers are exclusively related to certain parts of the car.
      For example, vvv = 020 are related to the transmission.
    23. Member 1badMKIrocco's Avatar
      Jan 18th, 2002
      Estes Park, Co
      Mutt Mobile
      10-31-2002 10:35 AM #23
      My ODOMETER Does not Work! http://www.nwlink.com/~vdb/vw/Body/speedo_fix.txt This is a link to a very detailed process of how to take apart you gauge cluster and make your Odometer work again and never break again, took me about 3hrs start to finish 1st time
      Also http://www.nwlink.com/~vdb/cars.html Site with lot's of good tech articles been on the net for a long time [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      http://home.att.net/~t.goddard/ This is a great site too links to all kinds of VW stuff and lot's of info on Racing VWs [IMG]http://*****************.com/smile/emthup.gif[/IMG] [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      [Modified by 1badMKIrocco, 3:36 PM 10-31-2002]
    24. Member 2035cc16v's Avatar
      May 18th, 2000
      New England
      10-31-2002 10:49 AM #24
      Vehicle Indentification Number
      DIGIT: 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7
      EXAMPLE: W V W D B 4 5 0 5 L K 2 4 5 6 7 8
      WMI.. VDS........ VIS............
      WMI = World Manufacture Index
      VDS = Vehicle Descriptor Section
      VIS = Vehicle Identifier Section
      1 - Manufacturing Country
      W - Germany
      1 - USA
      3 - Mexico
      9 - Brazil
      2 - Manufacturer
      B - VW of Brazil
      V - Volkswagen
      3 - Vehicle Type
      1 - Pickup
      2 - MPV (Multi Purpose Vehicle)
      W - Passenger Car
      4 - Series
      1987 - 93 Fox
      A - 2 Door Basic
      B - 2 Door Economy
      C - 2 Door Custom
      D - 2 Door Wagon
      G - 4 Door Custom
      1985-95 Golf
      B - 2 Door Custom
      D - 2 Door Sport
      D - 2 Door GTi
      F - 4 Door Custom
      H - 2 Door GTi 16V
      K - 4 Door Golf III
      1985-95 Jetta
      K - 2 Door Base
      M - 2 Door Custom
      P - 4 Door Base
      R - 4 Door Custom GL / Caret / Economy
      S - 4 Door GLS / CustomT - 4 Door GLI / GLX
      1983-95 Rabbit / Cabriolet
      A - 2 Door Base
      B - 2 Door Custom (1992-93)
      C - 2 Door Custom (1983-91)
      D - 2 Door Carat
      E - 2 Door Etienne Aigner
      1983-88 Quantum
      A - 1983-88 2 Door Basic
      B - 1983-88 2 Door Custom
      C - 1983-88 2 Door Deluxe
      D - 1983-88 2 Door Sport
      E - 1983-88 4 Door Basic
      F - 1983-88 4 Door Custom
      G - 1983-88 4 Door Deluxe 1983-88
      Scirocco (USA) 1983-89 Scirocco (Canada)
      A - 1983-88 2 Door Basic (USA)
      A - 1983-89 2 Door Basic (Canada)
      B - 1983-88 2 Door Custom (USA)
      B - 1983-88 2 Door Custom (CAnada)
      C - 1983-88 2 Door Deluxe (USA)
      C - 1983-89 2 Door Deluxe (Canada)
      D - 1983-88 2 Door Sport (USA)
      D - 1983-89 2 Door Sport (Canada)
      B - 1983-88 2 Door Custom (Canada) 1990-94
      Corrado(USA)
      D - 1990-92 2 Door Sport
      E - 1992-94 2 Door SLC 1995
      Corrado (Canada)
      E - 1995 2 Door SLC
      1983--92 Vanagon
      X - 1983-88 Kombi
      Y - 1983-92 Bus (Vanagon)
      Z - 1983-92 Camper
      1992-95 EuroVan
      H - EuroVan CL
      K - EuroVan GL
      1990-95 Passat
      C - 4 Door GLS
      D - 4 Door Wagon GLS
      E - 4 Door GLXF - 4 Door Wagon GLX
      F - 4 Door Custom GL
      G - 4 Door Wagon GL
      H - 4 Door Base
      J - 4 Door Deluxe GLX / GLS
      N - 4 Door Wagon Custom GLX
      5 - Engine
      Contact Dealer for Detailed Engine Information
      6 - Restraint System
      0 - Active
      2 - Passive w/Man Lap Belt
      4 - "ELRA"
      5 - Active Belts w/Driver Air Bag
      8 - Active Belts w/Dual Air Bags
      9 - Passive
      7-8 Model
      15 - 1983-93 Convertible, Cabriolet
      16 - 1983-88 Jetta
      17 - 1980?-92 Rabbit, Pickup, Golf, GTi
      1C - New Beetle
      1E - 1995 Cabrio
      1G - 1989-92 Golf / Jetta
      1H - 1993-95 Golf / Jetta
      24 - VW Transporter (Pickup and Multivan)
      25 - 1983-92 Vanagon, Transporter Van
      30 - 1987-93 Fox
      31 - 1990-95 Passat
      32 - 1983-88 Quantum 2 Door and 4 Door
      33 - 1985-88 Quantum Station Wagon and Quattro
      3A - 1995 Passat
      43 - Audi 5000 / older
      44 - Audi 5000/100/200/V8
      4A - Audi S4/100CS/V8
      50 - 1990-95 Corrado
      53 - 1983-88 Scirocco
      60 - 1994-95 Corrado
      70 - EuroVan
      78 - Passat?
      81 - Audi 4000
      83 - Audi 4000
      85 - Audi Coupe GT
      89 - Audi 90
      8A - Audi 90
      8B - Audi Coupe
      9 - VIN Check Digit
      Manufacturer's Internal Code
      10 - Vehicle Model Year
      D - 1983
      E - 1984
      F - 1985
      G - 1986
      H - 1987
      J - 1988
      K - 1989
      L - 1990
      M - 1991
      N - 1992
      P - 1993
      R - 1994
      S - 1995
      T - 1996
      V - 1997
      W - 1998
      X - 1999
      Y - 2000
      1 - 2001
      2 - 2002
      11 - Assembly Plant
      A - Ingolstadt
      B - Brussels
      E - Emden
      G - Graz
      H - Hanover
      K - Osnabruck
      M - Mexico
      N - Neckarsulm
      P - Brazil
      S - Stuttgart
      V - Westmoreland, PA, USA
      W - Wolfsburg
      Y - Spain (SEAT)
      12 - 17 Serial Number
      Sequential Production Number
      *whew* getting that to come out right was a b1tch!
      [Modified by 2035cc16v, 7:52 AM 10-31-2002]
      [Modified by 2035cc16v, 7:54 AM 10-31-2002]
    25. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      15 Jetta 92 Corrado VR6
      10-31-2002 11:20 AM #25
      Mk2 VR6's handle fine with the right suspension. Not quite as tossable as their 4cyl brothers, but pretty darned nice. For comparison, drive Corrado SLCs as they handle *really* close to the way a Mk2 VR6 drives.
      Beyond that, us owners of such cars still feel the need to make fun of the Mk2 VR6's awful handling. The running joke is the flipping-over Mk2 VR6 .. here are the pictures for such use in threads, credit: me.
      Flipping image:
      Oops into the canyon pic:
      Oops into the canyon continued:
      The Official MK2 VR6 bumper sticker:
      I could have added something useful, but this is waaay better
      -Paul
      1992 Corrado - ALL MOTOR Drag Project
      1995 GTI VR6 - Retired - 12.90@106 R32 power - 12.833@106 12v power
      KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
