Results 1 to 23 of 23
Thread: VRT HELP!!! Twin Disc is damaged, ok to run??
  1. Member 98rzvr6's Avatar
    Nov 12th, 2005
    Grand Rapids, Michigan
    92 GTI VRT 3.0
    04-22-2012 06:15 PM #1
    Hey guys i had an issue last year with my competition twin disc getting it to fit, i called the company directly and was told that i would have to ship it back and they might be regrind the plate down or i just might have to regrind the bellhousing down to fit, they said " they never seen this issue before" so i decided to grind down the bellhousing because i needed to get the car back on the road. I got it running last year but she never drove, i did put it in gears multiple times so i know im ok there, i did also move it in my driveway while it was in gear and everything so i know it does move the car and it does engage into gears very smoothly but what do you guys think? I shaved it down a lot and i used grease on the plate itself to see if it would be touching the bellhousing and it wasnt so i just took the tranny off now because i was gonna check on the timing and i see this, I dont have warranty anymore i think so should i just shave it down a little bit more and call it a day? The discs look fine and so does the flywheel, nothing looks damaged besides the plate and bellhousing, thanks for the help guys
    98 Jetta VRT 3.0 with a Garrett GT4294r and Lugtronic Standalone
  2. Member GinsterMan98's Avatar
    May 19th, 2008
    Panama City FL
    96 GTI VR6 08 Hyundai Santa Fe SE
    04-22-2012 07:33 PM #2
    Holy crap, I would be worried about the damage to the bellhousing. That is right where the pinion bearing sits.
    98 GTI - Mustard Mayhem - 1/4 - 11.679@117.58mph - .8 bar - parted Timeslip
    96 GTI - Turbo Panda - 1/8 - 7.63@97mph - 1.1 bar of turbo fun!
    89 325is - New turbo project
    www.lugtronic.com
    May 12th, 2010
    Mk3 VrT Gti
    04-22-2012 08:25 PM #3
    That's allot of interference, enough to think it's the wrong application. I wonder if you have a crank thrust washer any more. Is that flywheel for that clutch? I always see the cm twins come with a flywheel and don't know if they fit stock ones.
    OBD1, Mk3 12v, 3L, HG, 8.5, JE, stock rods, 263, 3"DP to 3" MBS, Kinetic Mani, t3/t4 .63ar, Intercooled, PW39, C2 36# 4 bar, IE 044 surge, Stock intake, Peloquin, AEM truboost/uego/fp, Mocal OC
  4. Member 98rzvr6's Avatar
    Nov 12th, 2005
    92 GTI VRT 3.0
    04-22-2012 10:01 PM #4
    Yeah it came with the flywheel, its all one package but what should i do? Should i get a new set up and trans? I really dont want to obviously, this **** isnt cheap
    May 12th, 2010
    Mk3 VrT Gti
    04-22-2012 10:27 PM #5
    In my view it's not a problem to make more clearance but it must be done with machine tools not by hand. I would have to think that all that damage happened more or less all at once on start up. short of a missing thrust washer there can't be that much movement in the crank. And even then. So yeah...take some off the flywheel and I personally would take some truing cuts on the clutch just for balance sake. You might be able to gain some by taking a cut on the pillars/bosses that mate to the flywheel as well. My guess is if you could gain .10" you would be good, though even .075 might get you there. For sure put a pinion brace on.
  6. Member GinsterMan98's Avatar
    May 19th, 2008
    Panama City FL
    04-23-2012 01:56 AM #6
    I would not run that case in a high hp car, recipe for disaster. I think they sent you the wrong one. Maybe someone else who runs this will chime in.
    www.lugtronic.com
  7. Member .therealvrt's Avatar
    Mar 29th, 2006
    Ottawa
    94 golf vrt ( sold after 18.5 years of fun)
    04-23-2012 10:04 AM #7
    o2a or 02j bellhousing?
    11.91@121 mph. slicks, pump gas, full exhaust vrt v.2.0
    12.09@127 mph. 205 40 17 falkens, pump gas, full exhaust vrt v.3.0
    member since 2002 -banned several times
  8. Member 98rzvr6's Avatar
    Nov 12th, 2005
    92 GTI VRT 3.0
    04-23-2012 02:31 PM #8
    Its 02a
  9. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    04-23-2012 03:13 PM #9
    boost + traction = boom
  10. Member 98rzvr6's Avatar
    Nov 12th, 2005
    92 GTI VRT 3.0
    04-23-2012 04:52 PM #10
    Quote Originally Posted by TBT-Syncro View Post
    Thanks for the help, you're actually one of the guys that knows what he is talking about on here so im surprised to see a comment like that from you.
    Anyways, Im sending the clutch back right now to them so hopefully here soon I'll know what happened.
  11. Member GinsterMan98's Avatar
    May 19th, 2008
    Panama City FL
    04-23-2012 05:13 PM #11
    Quote Originally Posted by 98rzvr6 View Post
    Hope it works out. I know they are not cheap. Let us know what the verdict is.
    www.lugtronic.com
  12. Member .therealvrt's Avatar
    Mar 29th, 2006
    Ottawa
    04-23-2012 05:22 PM #12
    Its 02a
    i remember some bellhousing issues with another brand of twin disc and 02j trannies
    look it up , it was early clutchmasters twins that had issues (iirc)
  13. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    04-23-2012 05:46 PM #13
    my opinion is that the housing is now toast. The pinion is going to move, the gears will spread and fail.
    just me being my usual blunt-self.
  14. Member pimS's Avatar
    Jan 7th, 2009
    Nearby Amsterdam
    96' VRT
    04-23-2012 05:52 PM #14
    Both the clutch and bellhousing ar scrap. imho
    if you have the power to need to run a twinplate, the housing will deff. not hold
    DCA Facebook
    Build it, Run it, Break it, Fix it, Repeat!
  15. Member
    May 12th, 2010
    Mk3 VrT Gti
    04-26-2012 06:24 AM #15
    Clutch looks fine. If you look close it's just picked up aluminum from the pinion boss. Very little material has left the clutch. Clean it up and verify balance.
    But I agree there is not enough wall left of the pinion boss to stand up to a whole lot. So change the housing. Sucks but it's not a total loss.
    But of course you still need to deal with the clearance.
    Anyway if you bail on the clutch I'll buy it and make it work. With no handiwork into it that is.
  16. Banner Advertiser pete@integrated's Avatar
    Jan 1st, 2009
    Salt Lake City, UT
    '92 Gti 20v, '96 M3, '10 Shop Van :)
    04-26-2012 11:23 AM #16
    Another vote for that bellhousing being toast.
    .:IntEngineering.com:. .:Facebook:.
    Check out some cutting edge R&D Work on our blog! IE Behind the scenes Blog!
  17. Member JoHnsVrT's Avatar
    Feb 1st, 2007
    union nj
    89 jetta carat, 90 gti vrt
    04-26-2012 01:51 PM #17
    anything over 450 that bellhousing will crack everywhere lol
    67mm - vrt
    mad slow
  18. Banner Advertiser nothing-leaves-stock's Avatar
    May 16th, 2006
    230 E. landis st coopersburg pa 18036
    a few.
    04-27-2012 09:05 AM #18
    both junk....
    www.nothingleavesstock.com
    NLS's full line of parts on our online store!http://nothingleavesstock.com/online...=0&sort=normal
    Email us at sales@nothingleavesstock.com 230 E. landis st. Coopersburg PA 610 282 5487
  19. Member 98rzvr6's Avatar
    Nov 12th, 2005
    92 GTI VRT 3.0
    04-27-2012 12:06 PM #19
    Hey guys so i got really good bews, Bob from competition clutch called me yesterday and basically told that for mk3's, there are about 5 or 6 transmission codes so the test vehicle that they had in the shop was a different code so what they are basically going to do is grind down the flywheel a little to get it to fit. They believe that the flywheel will still have enough material to be perfectly functional and of course clear the bellhousing. Everything is covored under warranty and i should be receiving it within the next week. I was pretty worried thinking they would blame it on me but they were honest and lets hope this time everything will be alright. I just ordered a new case so im gonna have to take the gears out of it the old and install everything. I did order a pinion brace from USRT so im really hoping everything fits. I'll definitely spin the engine around multiple times to make sure its not touching anything and if still is, im gonna raise hell
  20. Member KubotaPowered's Avatar
    Jan 27th, 2005
    Tucson, AZ
    2006 Subaru WRX
    04-28-2012 12:58 AM #20
    Ive had issues even with Competition single disc clutches not clearing the bell housing. After about an hour with a file, the rivets were short enough to clear. Both clutches were bolted to the stock VR6 flywheel and then again to the flywheel they offer with no change in fitment.
    Quote Originally Posted by ..Derek.. View Post
    Clearly you aren't familiar with the "Golden Corrado". It's so clinically clean that in the event that you must urinate it must be done at least one zip code away in fear that it may catch a staph infection.
    Tucson Forced Induction
  21. Member .therealvrt's Avatar
    Mar 29th, 2006
    Ottawa
    04-28-2012 09:17 AM #21
    they should be replacing the bellhousing and cover the labour to split the tranny apart, if they are not take what they give you and then call them everyday and complain.
    If they didn't cover everything and that was my car theyd have a clutch and bellhousing thru their front window.
  22. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    04-28-2012 01:31 PM #22
    Quote Originally Posted by .therealvrt View Post
    x2
  23. Member heyfu's Avatar
    Mar 26th, 2006
    norfolk va
    8716v 89vr6 80rocco 16v
    04-28-2012 03:21 PM #23
    Quote Originally Posted by KubotaPowered View Post
    had the same problem then the springs on the disc came out
    the mk4, mk5 crowd is a bunch of posers
