So 32 people have looked at this so far and no comments or help :S well i got a new switch today for the ebrake will put it in tomorrow and update any results i checked the fluid level before i went out and it is good
Ok i did a search on here to find an answer problem is i went through 11 pages of threads and nobody post if a suggestion worked or not we need to post after the fix of what worked I also noticed that alot of questions go with no replys at all . I am looking yo fix my problems and hopefully help others with theirs
1997 VW Cabrio Highline convertable
2.0 liter ABA engine all stock
black top Ripped rear seam both sides FIXED
5 speed with noise in reverse
All factory
All factory
Scan with VCDS or factory scan tool to get codes from the ABS.
I am trying to get down to my buddies to use his scanner not sure if it will work i have heard that the regular scanners sometimes dont
All factory
I am not sure but that would be great if they wanna fix it lol
All factory
I ran a scan with Modis and got a code but I wont be home to see what it was til friday
All factory
ok so Modis is giving me a code 00668 supply voltage terminal 30 signal outside tolerances
I was looking for the relay thinking that might be it but now another problem my fuse box doesnt look like any other I have seen a pic of
All factory
Do you have a Bently Manual for this car? That is the best way to track down the voltage supply for the ABS.
FS:Sunroof Deflector
http://wiki.ross-tech.com/wiki/index.php/00668
The Bentley manual will have the required wiring diagrams.
