Results 1 to 3 of 3
Thread: Edit Function?
    Apr 21st, 2012
    Millersville, MD
    2012 Passat TDI, 2005 Ford F-250 6.0 diesel, 2007 Artitic Fox 5th Wheel
    04-22-2012 09:37 PM #1
    I use other forums using this same software and it allows me to EDIT my own posts so I can correct typo's etc. Is there a special way this (VW) forum is set up to do this?
    Thanks for any clearification....
    2012 Passat SE TDI NAV
    2005 F250 PSD 4X4 LB CrewCab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover
    2007 Arctic Fox 30' Fifth Wheel
  2. Vortex Media Group Staff Tim@VMG's Avatar
    Dec 11th, 2001
    Baltimore, MD
    2012 GTI Autobahn
    04-23-2012 07:28 AM #2
    You just click the "Edit Post" button, in the upper right part of the post.
    I circled it in red for you in the attached picture.
    It is worth noting, though, that while you can edit your own posts, if you want to change the title of a thread, you'll have to have a moderator do it for you, as we don't let users edit threads. You can use the "report to moderator" button (the little "!" in a triangle at the bottom of each post) to let them know that you need help.
    Welcome to our forums!
    -Tim
    The artist formerly known as SilverSLC
    Forum Rules | How To Use vBulletin
    VWVortex | Fourtitude | INR8 | Kilometer Magazine | Swedespeed
    "When you're traveling at lower speeds, and by lower speeds I mean anything under 120 miles per hour..." -Allan McNish
    Apr 21st, 2012
    Millersville, MD
    04-23-2012 09:50 AM #3
    OK - Duuh!!! Thanks!
