VWVortex.com - Greased my door latch now door unlatches over bumps
    Results 1 to 13 of 13
    Thread: Greased my door latch now door unlatches over bumps
    1. Member scirockinit's Avatar
      Oct 16th, 2008
      Fred
      82 Scirocco
      04-22-2012 10:16 PM #1
      82 rocco.... Greased passenger door latch now when I go over bumps my door unlatches. It doesn't open all the way tho. Also just put on new rims with a wider offset and lower profile tire. Don't understand why this is happening
      Quick to the SLOW!!
      Fastest you can go 50!
      Wish i had a scirocco..(A. Einstein)
    2. Member 16V_Scirocco_GTX's Avatar
      Jul 18th, 2001
      In the 94086 California
      98 Passat V6, 90 Corrado TDI, 84 Scirocco GTI
      04-22-2012 11:10 PM #2
      Have you pulled on the door after you close it? Does it open then? Don't think I've ever heard of this happening - best guess is that the hook isn't fully engaging.
      Tobias
      98 Passat V6, 90 Corrado TDI, 84 Scirocco GTi
    3. Member scirockinit's Avatar
      Oct 16th, 2008
      Fred
      82 Scirocco
      04-22-2012 11:37 PM #3
      Door shuts and latches. Even when pulled on. I've noticed on uneven ground door is a pain to shut. Slam push hip shove....lock it and shut it...boom good to go....im a little at a loss. Maybe my suspension being a bit higher on passenger than driver? Maybe its tweeking the chassis a lil... Ill adjust could and check again
      Quick to the SLOW!!
    4. Member
      Dec 30th, 2006
      1992 Volvo 740 Turbo
      04-23-2012 11:49 AM #4
      How are the door pins? If it's down to the metal, the door won't shut all the way and stay shut. My brother's GTI does this. If I take a hard corner or go over a big bump the door will come loose. They're $7.00 each at GAP, iirc. Always a good investment!
      Quote Originally Posted by Mach700 View Post
      In the absence of Wars, people become lazy and sex slaves (not everybody).
    5. 04-24-2012 11:56 AM #5
      *LOL* I'm not going to offer any advice since everybody else already covered it but....I love the thread subject title.
      hahahahaha
      Anyway...hope you get it fixed soon
      -Rob
      www.GoKraut.com
      "I didn't break it, I just adjusted it out of spec!"
    6. Member ginster86roc's Avatar
      Apr 19th, 2005
      oviedo fl
      86 volkswagen scirocco, baby
      04-24-2012 09:51 PM #6
      Quote Originally Posted by scirockinit View Post
      bent chassis and/or suspension mounting points?
      bad (read: rotted out) door hinge(s)?
      i good vibes... and sciroccos.
      Quote Originally Posted by sciroccojim
      Yes. Follow the adjustment procedure in the Bentley. Works like "magic."
      Quote Originally Posted by punchbug
      That's just how we roll.
    7. Member scirockinit's Avatar
      Oct 16th, 2008
      Fred
      82 Scirocco
      04-24-2012 10:27 PM #7
      I do have coilovers lower maybe they r adjusted wrong and tweekin my chasis. I have just recently put rims with lower profileprofile tire by alot!.
      Quick to the SLOW!!
    8. Member ginster86roc's Avatar
      Apr 19th, 2005
      oviedo fl
      04-24-2012 10:47 PM #8
    9. Member scirockinit's Avatar
      Oct 16th, 2008
      Fred
      82 Scirocco
      04-24-2012 11:00 PM #9
      Car it's rust free. No rot
      Quick to the SLOW!!
    10. Member
      Dec 30th, 2006
      04-25-2012 01:34 AM #10
      When the door's open can you lift the door up and down an inch or so? I had a broken lower hinge on one of my old 16v's door that caused a similar problem.
    11. Member scirockinit's Avatar
      Oct 16th, 2008
      Fred
      82 Scirocco
      04-25-2012 07:11 AM #11
      No door doesn't move.
      Quick to the SLOW!!
    12. Member scirockinit's Avatar
      Oct 16th, 2008
      Fred
      82 Scirocco
      04-26-2012 09:43 AM #12
      Gonna grab another latch.and see if this one is defective. altho this was just baught in 09
      Quick to the SLOW!!
    13. Member scirockinit's Avatar
      Oct 16th, 2008
      Fred
      82 Scirocco
      04-30-2012 05:23 AM #13
      Got a new striking pin and fixed problem
      Quick to the SLOW!!
