nice!! good luck with the swap. check out my build threa, its basically the same swap, or if you have any questions/pointers
So here is my first build thread...first, the car....
92 Jetta GLI 16v 2.0 with 166k in really good shape, fully loaded with every option available, lightly modded and ran beautiful till about 2 weeks ago, I heard my lifters starting to knock....put it up on a lift and found this....
JB WELD ON THE SIDE OF MY BLOCK/HEAD!!!which lead to all my oil leaking out and being all over the underside of my car.....
sooo couple minutes later i bought this...
alittle dirty at the time but its a 20v 1.8t out of a passat wagon with a mk4 gti intake manifold and turbo setup.
passat was totalled after first owner flipped it with 300 miles on the motor! buddy of mine bought the car for parts and stripped it down.
The donor car....
and after 2 1/2 hours of cleaning the motor and touching up some things, this is what i ended up with....
sprayed down, wire brushed & polished...all ready to go!
bagged it up to keep it clean while i wait for parts to come in...
More pictures and updates soon!!!
Volkswagens get CEL's like girls get there periods
1.8t Mk2 GLI project build
Waiting for my stage 2 clutch to come in the mail very patiently......and the wiring harness is soon to be sorted through for things not needed
so some parts came in over the last 2 weeks...
APR R1 diverter valve (bought this off a buddy)
New pressure plate and flywheel bolts
2.5 inch intercooler piping with silicone fittings and clamps (going to tig weld most of the piping)
2 inch to 2.5 inch turbo fitting
(my cat murphy in the background lol, he likes new parts)
and also a quick mock up on some 15x8 & 9 TH Lines i might be purchasing from my lovely girlfriend
Thats all for now!
THEY FINALLY SHIPPED THE STAGE 2 CLUTCH!![]()
looking good brother...what wiring is it that your useing for your 1.8t swap im doing the same swap lmao just curious what route your going lol ...
sub for sub. bump for a cool dude.![]()
#11
#12
ok so i know a build thread involves pics of it actually happening and problems that i run into but the build hasnt started just yet! in two weeks is when it gets dug into and ill be taking pics and showing you guys how its going! BUT i did receive my stage 2 clutch in the mail the other day!
Via clutchnet.com $317.99 with 15% off came to $271.15! SCORE![]()
thats all for now! i promise that this thread will get more interesting!
#13
Nice clutch... but did you really paint your toenails blue????![]()
#15
I second that...
Nice toe nails
what you doing with the 16 valve n harness?
#17
#18
#19
#21
LITTLE UPDATE:
picking up a turbo oil return line and ordering a wheel bearing due to a rear bearing starting to go1 more week till the swap begins!
#22
I see this car at cvs in bristol quite often. Were are you from in ct? Good to see a local build going on![]()
#23
#24
Yea walgreens haha always get those confusedI figured you worked there as I usually see it outside. Thanks for the good words the cars coming along slowly, but its getting there.
Keep up the good progress on this. Looking forward to seeing were it goes.
#26
we'll have to have a shoot when my rocco and your gli are done.can't wait to see some big progress!
#27
#28
#29
picked up a oil return line yesterday from a new friend! good dude, helped out alot with some info on the swap.
also i was recently part of staff for staggered 2012 and found a picture that wasserwerks took of my car at the show
#30
Looks good! I'm in for some solid progress![]()
Best 4x100 Thread! Show What You Got!
Build Thread: Victoria, My 1990 Jetta GLI
"I'm 17, with a GLI that's 3 years younger than my High School. How's that for survival of the fittest?!"
#31
little update:
Oil return line is on and motor is ready for drop in!
excuse the chopped downpipe (custom one is being made)
#33
#34
Sorry but I must tell u something,I see a mistake because the tube must not be dull in the oil for the oil return must be on the block.When oil are being accumulated in the oil pipe and oil is not being able to return to the crankcase oil in the crankcase will erupt on these seals on turbine. Sorry on my bed english![]()
#35
