VWVortex.com - Oil leak around the turbo area, please view pic....
    Results 1 to 4 of 4
    Thread: Oil leak around the turbo area, please view pic....
    1. Semi-n00b
      May 12th, 2011
      CA
      2007-Passat Wagon 2.0T FSI / 2013 Passat Wolfsburg Ed.
      04-23-2012 12:22 AM #1
      I took the wagon to the dealer for servicing due to an oil leak. However, before taking it in, I put the car up on ramps and took a peek to see what was the culprit. I noticed that oil was dripping from the turbo area. Nine days ago they performed the following repair:
      (as per my invoice)
      --> Cause:Gasket for the turbocharger pipe leaking.
      --> Fix: Installed a new gasket, added engine dye to check for any other leaks and no more leaks were found after repair.
      However, today I noticed oil in my garage floor again from the same spot!
      The wagon is still under warranty (with 49k mi.) and I will schedule another service appointment on Monday.
      Has anyone else experienced this?
    2. Member SDbirdman's Avatar
      Jan 20th, 2011
      San Diego, CA
      2010 Candy White Passat 2.0 TSI
      04-23-2012 12:25 AM #2
      Oil saturation in the DV compartment is common on this engine. It is most likely a bad rear pcv. You probably have oil in your intercooler as well.
      Unitronic Stage 2+ -- K04 turbo w/Unitronic DV Relocation -- 42DD 3" catless downpipe -- APR Intercooler -- Unitronic Intake -- BSH Throttle Pipe -- AWE Outlet Pipe -- Votex front lip -- HiDef side skirts -- painted rear valence -- mkvi wheel w/DSG paddles -- R-Line Pedals -- TRS HID headlights & projector fogs -- Euro side markers -- Skyline Euro Tail Lights -- Podi gauge and pod kit -- GFB DV+ -- 034 Motorsport Steet Density Mounts
    3. Semi-n00b
      May 12th, 2011
      CA
      04-23-2012 04:04 PM #3
      Thanks for the info!! Can you please elaborate on this "rear PCV" and what causes the oil saturation in DV compartment. I just want to know more about it so that I at least have a mediocre understanding before going to the service department. THANKS!!!
    4. Member SDbirdman's Avatar
      Jan 20th, 2011
      San Diego, CA
      04-23-2012 04:14 PM #4
      To be 100% honest I am not sure how the oil gets down there. Although i believe I read somewhere that it is caused from excessive blow-by. What I Do know is that you should probably just replace the whole pcv system as it is prone to failure on this engine. It's not that expensive of a fix.
      My DV used to leak oil when I would start to loosen the bolts when I replaced it. Also leaked oil through the electronic connector... For me having oil where it wasn't supposed to be was the last straw. I could handle topping off the oil and checking on the cam follower from time to time. But the thought of my engine/turbo/intercooler being flooded with oil really freaked me out. I lemoned it earlier this year for excessive oil consumption (1.3qts per 1000 miles!) and haven't looked back.
    « Back
