Results 1 to 15 of 15
Thread: Just finished install - no fuel pump signal from ECU
  1. Member BarryV's Avatar
    Apr 23rd, 2001
    Frederick, MD
    1992 12V 1992 16V 2012 TDI
    04-23-2012 09:19 AM #1
    So I spent this past weekend putting a Vortech V1 on my 1992 GLI.
    The car had an OBDII VR6 swapped in from a 1998 Passat, and the motor was fairly stock, with the exception of EGR and SAI, which were gone, and programmed into the existing GIAC software.
    Here is the current configuration:
    stock compression
    288 cams
    42 lb Bosch green top injectors
    4" MAF
    Vortech V1 with 8 lb pulley
    C2 42 lb race profile software - OBD II
    Walbro inline 255 LPH fuel pump, relayed off of mkII intank pump.
    We basically spent all afternoon yesterday trying to chase down an issue with the motor not getting fuel, only to figure out that the connection we were tapping into for the inline pump was corroded.
    I wired in a 30 AMP relay, using the factory harness going to the mkII in line pump assembly as the signal source. The fuse and relay are mounted in the fuel pump well with the Walbro pump.
    We got the car running pretty well last night at the shop with a little help from the Vagcom and mostly just a lot of going over things and making sure everything was tight.
    Here's the idle video
    I let the car cycle through two cooling cycles and ran it up and down the back street behind the shop, to make sure everything was good to go.
    Drive it home - 20 minute drive, and 2 blocks from my house, the car cuts out.
    I checked the relay and fuse... both under the car, and under the dash, and all were good. The ECU is not sending the signal to the fuel pump to turn on.
    Where do I go!? This is driving me to drink!
    Car in question:
    Who is Joel Goodson
    Alpine White
    #realityquest
    DCI MARYLAND
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    04-23-2012 09:40 AM #2
    Is stock pump turning on? Check to see that ecu is seeing rpm signal when cranking. The crank position sensors are notorious for going bad, especially becoming intermittent once they warm up.
  3. Member BarryV's Avatar
    Apr 23rd, 2001
    Frederick, MD
    04-23-2012 10:09 AM #3
    Quote Originally Posted by bonesaw View Post
    The stock pump is not getting a signal when cranking.
    If the tach sees the RPM, that is being sent from the CPS?
    Or do I need the Vagcom again?
    Who is Joel Goodson
    Alpine White
    #realityquest
    DCI MARYLAND
  4. Member Scurvy Bandit's Avatar
    Sep 12th, 2003
    Cambridge UK
    94 MK3, 81 Caddy
    04-23-2012 10:25 AM #4
    Is this like the older VW's where the tach and the fuel pump get the signal from the (-) side of the coil? Good luck man.
    I used to rollerblade.
    http://oldskoolvw.com/ do it.
  5. Member BarryV's Avatar
    Apr 23rd, 2001
    Frederick, MD
    04-23-2012 10:54 AM #5
    Quote Originally Posted by Scurvy Bandit View Post
    Dont believe so. I think it all comes from the CPS.
    Which... correct me if I am wrong, if the CPS is bad, I wouldnt have spark. I am definitely getting spark - confirmed that with the plug and wire.
    It should be mentioned - The car turns over, and tries to start. I will spin up to 1K but dies before it gets to idle.
    Who is Joel Goodson
    Alpine White
    #realityquest
    DCI MARYLAND
  6. Member xpalendocious's Avatar
    Nov 28th, 2003
    El Sobrante CA
    560AWHP VR6T Quattro 92 GTi / 2004 Touareg 4.2 / 1992 GTI VR6 PRPLVR6 / 88 Vanagon GL Weekender
    04-23-2012 12:07 PM #6
    chip fell out of the ecu? ive seen it many times
    My VR6 Turbo Quattro Golf
    Antaki Motor Work - Mechanic for Hire - NorCal area
  7. Member BarryV's Avatar
    Apr 23rd, 2001
    Frederick, MD
    04-23-2012 01:10 PM #7
    Quote Originally Posted by xpalendocious View Post
    I didn't check that, but I guess anything is possible. The chip was very snug, going into the socket on the ECU board.
    I drew out a quick current diagram, and the yellow X signifies where I don't have the 12V I should.
    Mind you, that was at a factory harness plug, behind the rear seat. There is a lot of harness in between the factory in dash relay and that plug.
    I feel like, and hope the factory relay in the dash went out. I can feel it click, when I turn the ignition key on, but that doesn't mean it is electronically passing current through. I am going to check the pins on the fuse block for the relay, for the 12V, ground and signal in tonight.
    Who is Joel Goodson
    Alpine White
    #realityquest
    DCI MARYLAND
  8. Member Smokestack's Avatar
    Mar 24th, 2007
    Colorado Springs
    92 ABA swapped GTI
    04-23-2012 02:51 PM #8
    You can try using a jumper across the pins on the relay to give the circuit a test. If they kick on then the issue is either the relay(s) or the signal wire from the ECU. It's also possible that the supply for the in dash relay blew a fuse.
  9. Member BarryV's Avatar
    Apr 23rd, 2001
    Frederick, MD
    04-23-2012 03:10 PM #9
    Quote Originally Posted by Smokestack View Post
    Chris! I need your phone number dude. You are my long lost mad scientist.
    I am buying a new relay today after work. Cant hurt to have a mkII relay on the shelf, with 2 mkII's in the garage, amirite?
    Jake - the guy that owns the shop we used to put the charger in suggested running a "stand alone" signal feed to the factory in dash relay, fed from the ignition switch. I think if all else fails, and the new relay doesn't solve my problem, I am going to just run with that idea for now. At least until I can get an ECU sent off to United, for a new tune.
    Who is Joel Goodson
    Alpine White
    #realityquest
    DCI MARYLAND
  10. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    :faceplam: :beer: :thumbup:
    buncha junk
    04-23-2012 11:51 PM #10
    Barry, like I posted on Facebook, mine did this a while back. I ended up just jumping the FP relay with a toggle switch to drive the car. It drove me nuts for the LONGEST time. I traced everything and tested everything. I ended up finding the ground pin on the FP relay wasnt grounding. I ran a ground jump to that pin and it worked. I replaced the fuseblock and it worked like it was supposed to. My fuseblocked ended up going bad somewhere inside and it caused all the problems.
    Just some food for thought
    Crooked Euros | Low is NOT a lifestyle | Slow & Quiet
    WTB - 04.5 GLI REAR VALANCE
    Pennsylvania Volkswagen Owners & Enthusiasts Page
    O/R/T
    We Do It Big In PA
  11. Member xpalendocious's Avatar
    Nov 28th, 2003
    El Sobrante CA
    04-24-2012 01:18 AM #11
    fp relay trigger is a ground signal from the ecu. feeding the signal wire +12v ign won't trigger the relay.
  12. Member xpalendocious's Avatar
    Nov 28th, 2003
    El Sobrante CA
    04-24-2012 01:20 AM #12
    position 12 on your ce2 fusebox pinout
    12 Fuel Pump Relay (80, 67 or 167)
    1 Main Fusebox Starter Power (not used)
    2 Main Fusebox Start/Run Power
    3 To ECU (Fuel Pump Turn-On)
    4 To Fuse 18, Fuel Pump, Oxygen Sensor Heater
    5 G2/6 (not used)
    6 Main Fusebox Battery Power From 30B
    7 G2/7, T1 (not used)
    8 Main Fusebox Ground (not used)
    9 M/4, U1/8, G2/5 (not used)
  13. Member xpalendocious's Avatar
    Nov 28th, 2003
    El Sobrante CA
    04-24-2012 01:21 AM #13
    On the engine wiring harness going to the fusebox
    G1/03 ECU- Fuel Pump Relay Turn-On (gas) - Fuel Pump Relay Power - Red/Yellow (gas),
  14. Member BarryV's Avatar
    Apr 23rd, 2001
    Frederick, MD
    04-24-2012 09:32 AM #14
    Quote Originally Posted by steveo27 View Post
    5 G2/6 (not used)
    Well... thats amazing info!
    Steve... I saw your spot on FB. I started setting up to trouble shoot and then passed out on the couch after dinner. Guess I saved myself a lot of trouble.
    Thanks guys, for the great advice. I will be looking at the ground now.
    Who is Joel Goodson
    Alpine White
    #realityquest
    DCI MARYLAND
  15. Member BarryV's Avatar
    Apr 23rd, 2001
    Frederick, MD
    04-26-2012 09:09 AM #15
    So I feel like a complete dumbass.
    I guess the fuel pump relay circuit has a slight delay in it.
    Troubleshooting with everything back together, and a buddy cranking the car, I found 12 V sitting on the Walbro, and the pump was actually turning on.
    Car would start, sputter, and then die. WTF
    Takes a closer look, and MAF coupler had fallen off the intake tube, inside the inner fender, below the frame rail.
    Wow.
    Ok... so T-bolting the intake couplers today and re-assembling tonight.
    Who is Joel Goodson
    Alpine White
    #realityquest
    DCI MARYLAND
