Results 1 to 25 of 25
Thread: Golf R vs Sti
  1. Junior Member
    Apr 13th, 2012
    Socal
    2012 CandyWhite Mk6 GTI
    04-23-2012 12:38 PM #1
    Who would win in from a dig? or from rolling from 40mph
    I understand that the golf r is the EA113 uses direct fuel injection and double overhead camshafts with variable intake timing. Because the Golf R develops more power and torque than the GTI—256 horsepower and 243 lb-ft compared with 200 hp and 207 lb-ft—a number of changes have been made. The cylinder block is reinforced, stronger connecting rods are fitted, and a BorgWarner K04 turbocharger is used, boosting at up to 17 psi.
    and sti is 2.5L 4 cylinder engine with 305hp at 6500rpm and 290lbs torque at 4,000rpm
    both is AWD
    I honestly think the Golf R would win, because it is lighter and just a beast . i own a 2012 gti stock and it is beastly fast. Imagine if i add an intake, k04 turbo, and exhaust!
  2. Member snubbs64's Avatar
    Oct 23rd, 2004
    2010 A3q, 2003 20 AE GTi 1.8BT, 2004 CBR 600F4i
    04-23-2012 12:55 PM #2
    There are a lot of sites that list 1/4 mile times. I'm sure you can find a time slip from both an STi and R with all the deets. It'll give the story of who would win on what type of race well enough if its broken down properly.
    That being said and without looking any further, stock vs. stock, STi everyday, all day.
    JUST a tune, that'll be a driver race.
    Modded stock turbo and a tune, back to the STi.
    Even with the EA113 K04 fsi, the hardware on the STi is seriously more beastly with a good size larger snail. Its also not substantially lighter.
    And the K04 you're talking about is what comes on the R.
    To be honest, you've highlighted one of the main reasons i dropped my golf R deposit and picked up a great deal on an A3q 2.0t with the EA888 once i made the connection (TFSI, not FSI for those who may not know). The FSI in the Golf R isn't much more than an EA113 1.8t from the MKiv's with a seriously updated head and direct injection. Its the same basic architecture. The EA888 2.0t TSI is an all new motor which is beefier in base trim (which the R model is not the base trim, uprated internals and such) and much more capable. The TSI will gain a lot more hp from the k04. Not to mention much more reliable.
    Come to think of it, though, this means you've posted in the wrong forum, ooops! The giant TSI on the engine cover and in all their propaganda is bull****, its an fsi.
  3. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    04-23-2012 01:16 PM #3
    even the turbo on the wrx is larger than the k04.
    but idk how it would turn out, tbh. STI would prob win, but not the WRX. my buddy down the road has an 05 or 06 WRX, full bolt on, FMIC, Manual WG controller so hes boosting 16psi. and hes lighter than me, but i still fly by him, even from a dig, which is weird. we did an AutoX last month and i even had the better times. they arent all they are cracked up to be.
    2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
  4. Member DRedman45's Avatar
    Aug 7th, 2009
    NOVA
    07 SB Rabbit(sold), 10 UG 4dr GTI(sold), e86 //M coupe
    04-23-2012 02:33 PM #4
    sti will take the .:R...vw has been behind the power curve for a long time
  5. Member snubbs64's Avatar
    Oct 23rd, 2004
    04-23-2012 06:27 PM #5
    Krieger you're also FWD, a lighter and less parasitic drivetrain than the galph R. You're probably getting as much power to the ground as an STI at least.
  6. Member DRedman45's Avatar
    Aug 7th, 2009
    NOVA
    04-23-2012 07:12 PM #6
    Quote Originally Posted by Krieger View Post
    The 05-08 wrxs are entirely different from what they are now...09+ make 265 stock and have been known to be quicker to 60 than the sti due to the five speed...mod for mod they will likely still take the r
  7. Member Aguilar's Avatar
    Jan 28th, 2006
    El Paso, TX
    02 Z06, 93 MX-5 LE, Mk6 GTI
    04-23-2012 07:26 PM #7
    Yup, newer WRX are no joke. Every weekend used to run my buddy, k04 GLI (TSI, 300whp) vs 2010 or 2011 WRX, all bolt-ons and a good tune (305 awhp). He had me by half a car every time. The GLI was DSG, and my buddy knows how to drive his car real good.
  8. Member Bullitt_TDI's Avatar
    Dec 12th, 2006
    Oberaurach DE
    2011 GTI
    04-23-2012 11:00 PM #8
    Isn't this TCL material?
    of course your talking @ the track right?
    Golf R is a FSI engine
  9. Member StylinVR6's Avatar
    Jan 21st, 2008
    Aurora
    2012 CW GTI
    04-25-2012 09:09 PM #9
    Not sure where everyone is getting that STI's are that fast. My stock MK6 GTI was an even run against a eagle eye STI with unknown mods 60-130. Closed track of course.
    2012 CW GTI: AWE Turbo pipe, H&R SS Springs, 42DD 3" Exhaust, Autotech Intake, Catless DP, Euro Shifter, ATP FMIC
  10. Member hazy450's Avatar
    Jul 22nd, 2010
    Panama City, Fl
    2013 RB Golf R, 2010 Bagged Tiguan (sold)
    04-26-2012 02:40 AM #10
    go to youtube.com and type in this "golf r vs sti" and you will have your answers.......
    "The thing is it's a gearbox. OK, it has one job to do, one job. Pull the lever: 'Am I a pencil? Am I a cauliflower? Am I a nuclear power sta-I'm a gearbox! Oh, heavens I'll swap some cogs around!" -Jeremy Clarkson
  11. n00b
    Apr 26th, 2012
    exit 384
    maxima, a4, 2 wrx
    04-26-2012 04:59 AM #11
    Quote Originally Posted by StylinVR6 View Post
    hawk eyes***
    those are the problem sti.
    i would like to give you a run of your money. your stock mk6 with my e85 2012 wrx.
  12. Member StylinVR6's Avatar
    Jan 21st, 2008
    Aurora
    2012 CW GTI
    04-26-2012 01:54 PM #12
    Quote Originally Posted by ocean48 View Post
    hawk eyes***
    Not stock anymore, its stage 2. I would gladly run u with the mk3 vrt in my garage :-)
  13. Member snubbs64's Avatar
    Oct 23rd, 2004
    04-28-2012 11:00 AM #13
    I don't think anyone said they were super fast. But they are a standard target and the big boys in the tuning market so everyone wants to compare to them. They do have killer hardware but stock, they are not the quickest thing on the road. A mkVI GTI is lighter and only FWD. My 1.8t with its stock turbo cracked out would pull on them, no prob, even mildly modded. If you're trying to get serious with tuning the car, you get to a certain point and they'll all be comparable. Its just a matter of how far you want to take it.
  14. n00b
    Apr 26th, 2012
    exit 384
    maxima, a4, 2 wrx
    04-28-2012 12:55 PM #14
    You have a dyno sheet ? ill show you mine if you show me yours
  15. Member StylinVR6's Avatar
    Jan 21st, 2008
    Aurora
    2012 CW GTI
    04-28-2012 01:05 PM #15
    Sadly it has never seen a dyno. Im sure ur wrx is quick, not saying anything bad about it. This thread was comparing stock vs stock, not a e85 tuned wrx.
  16. Junior Member
    Apr 13th, 2012
    Socal
    04-29-2012 02:49 PM #16
    Yeah, but vws are a monster when tuned.
  17. Member
    Dec 14th, 2009
    mohnton, pa
    05-01-2012 01:46 AM #17
    Golf r is priced with cars its WAY out classed by.
    it really doesn't matter which is straight line faster stock...ultimately, its no contest.
    Put the wrong, right?, motors in everything
    95 240 sr swapped : 03 s2k sr swapped : 93 rx7 sbc swapped : 89 Colt 4g63t swapped : 98 A4 : soon to be gone 03 Evo : soon to be aquired 02 Camaro
  18. Member snubbs64's Avatar
    Oct 23rd, 2004
    05-01-2012 10:42 AM #18
    Quote Originally Posted by akauf View Post
    You're right on about the engine/drivetrain. When it comes to creature comforts and fit and finish, the golf is above all of its competitors. If you're planning on heavily modding (turbo swap, built motor, etc) that would be my pic since all the same stuff is getting replaced anyway and most of the advantage the others had with their standard hardware is lost, but the build quality of the "shell" is still there. The AWD system may be more advanced and performance oriented on the others (not sure tho since i'm not all up on AWD's design and function) but there are mods and software out there for that, too.
  19. Member rdjr74's Avatar
    Jun 26th, 2007
    Cincinnati
    05-01-2012 01:22 PM #19
    Quote Originally Posted by snubbs64 View Post
    You're right on about the interior and comfort. I've been pricing 2011-12 WRX and the only way I'd get on is if it has leather seats. The interior is a joke and the sound system is not comparable either. Doesn't come close to VW. I can't really speak of the engine/ drivetrain but I would lean towards the WRX. Also I have to note that the engine bay on these Subaru's looks so so easy to work on compared to my VW.
  20. Member DRedman45's Avatar
    Aug 7th, 2009
    NOVA
    05-01-2012 01:29 PM #20
    ^you are incredibly mistaken as far as the wrx brim easier to work on...they are actually a major pain in the ass
  21. Member rdjr74's Avatar
    Jun 26th, 2007
    Cincinnati
    05-02-2012 12:47 PM #21
    Quote Originally Posted by DRedman45 View Post
    I just said it looks easier to work on compared to my MK5. Just curious for future reference (if needed), how is it more difficult to work on comparing the wrx to the mk5/6 engine bay layout?
  22. Member DRedman45's Avatar
    Aug 7th, 2009
    NOVA
    05-02-2012 01:00 PM #22
    look at the orientation of the pistons, where the spark plugs are located, the routing of the exhaust...subarus are ridiculous for normal stuff like that...a spark plug job on an STI can be a 6+ hour job
  23. Member
    Dec 14th, 2009
    mohnton, pa
    05-02-2012 01:03 PM #23
    Modding doesn't fix the drive train problems. There aren't good fuel options, maybe soon but as of now tuning is junk, haldex is a joke... It goes on
    I could go into a lot of long winded detail about all this but having a very good understanding of both platforms makes tugger choice ready. I prefer theEvo but sti is nice to, I guess.
    Evo has good cam options, dual dynamic cam timing control, open ecu software, a clutch that controls center diff lock, yaw control, fits wide tires ( I have 18x10.5 +18 with 275s on all corners under the stock fenders), all aluminum motor, list goes on.
    I like all the cars in question, not knocking anything for no reason here but there is a reason the r is produced in sick small numbers. Its for a niche market of vag die hards. if you give anyone one unbiassed individual all three cars the golf r isn't the number one pic.
    I think the whole fit and finish thing is meh too. They are put together well no doubt, but its really not much if any better than the other cars. I mean, when I hear someone say that I just think your only looking at the surface, its like picking a hooker cause she's wearing the nicest dress only to find out she's got a Dick underneath of it.
    For example,I have a few large boxes of Volkswagen hardware (nuts, bolts) left over from some parts cars (mostly mkv and iv, where talking full part out like entire car gutted/disassembled) and I won't even use them on another car. They are such low quality compared to say the hardware on a Toyota, generally speaking. That speaks more about the build quality than anything else.
    I guess ask I can really say I'd everyone hasthere own preference but try to really understand the differences between the cars, don't just read mag articles/reviews, I mean hard technical **** sort each platform.
    being too brand loyal is boring, get good trades and own each car for a few months. go back to the one that left the most laying impression. Ultimate win ensues
  24. Member rdjr74's Avatar
    Jun 26th, 2007
    Cincinnati
    05-03-2012 01:31 PM #24
    UUUGGGHHHH! Well ok that helps me. Yeah spark plugs on the good'ole VW takes 10 min.
  25. Member rdjr74's Avatar
    Jun 26th, 2007
    Cincinnati
    05-03-2012 01:33 PM #25
