Results 1 to 19 of 19
Thread: 2011 MkVI Golf 2.5L 5spd manual top gear?
  1. Member icon5585's Avatar
    Apr 29th, 2006
    Kansas City, MO
    2011 VW GTI
    04-23-2012 12:48 PM #1
    Is it possible to upgrade any 5 speed manual bolted to the 2.5L 5 cyl engine with the 5th gear from a 2011 Golf (it gets 33mpg now) and has really low revs at 60mph
    Jan 16th, 2011
    Chicago burbs
    10' Golf Mk6 2.5 MT
    04-23-2012 04:51 PM #2
    im not too sure but you probably could swap it out with one of the newer ones. They also changed the final drive ratio too fyi. I like my 2010 ratios though. I don't do to much highway and this car does not have enough power at high speeds as it is.
    5 cylinder FTW
    Jan 22nd, 2000
    NJ
    2010 Golf 2.5
    04-23-2012 06:09 PM #3
    Quote Originally Posted by icon5585 View Post
    There was more done to the 2011+ 5-spd manual transmission than just the 5th gear:
    2010 5-speed manual gearing:
    3.78
    2.12
    1.36
    1.03
    0.77
    Final Drive is 3.65
    2011+ 5-speed manual gearing:
    3.78
    2.12
    1.27
    0.87
    0.66
    Final Drive is 3.39
  4. Member itskohler's Avatar
    Jan 7th, 2011
    Jacksonville, FL/Dallas, TX
    2012 Jetta, 2008 Jetta RIP
    04-23-2012 08:32 PM #4
    Go with the TDI fifth. I think Kevin did it and posted an increase in MPGs.
    Sep 30th, 2009
    Guelph, ONT \ Daytona Beach, FL
    06 Jetta 2.5L 5spd (LSD+ .717 TDI 5th swap)
    04-23-2012 08:56 PM #6
    Quote Originally Posted by thygreyt View Post
    It was anile_eight
    Sent from my GT-P7510 using Tapatalk 2
    Thanks Fred, ya, I had an increase of about 3-4 mpg from a .717 TDI 5th at cruise on the highway. If you want to go lower, I probably would only if you plan to have a lot of highway driving. This is great for the city, I really don't have to rev out 4th more then I would normally. I think the lowest RPM I can shift at is around 1500-1600 ish? If you do a lot of highway driving my suggestion is no lower than .700. I would not go any shorter then .717 btw.
    C2 tune, Peloquin LSD, .717 TDI 5TH gear swap, USP test pipe, AWE exhaust (AMAZING), BSH CAI, H&R street sport coilover + 25mm RSB, neuspeed short shifter, 17x8 BBS RGR. **********FOR SALE THREAD:********** http://forums.vwvortex.com/showthrea...-%28OEM-LED%29*****http://forums.vwvortex.com/showthrea...0#post76396880
  6. Member itskohler's Avatar
    Jan 7th, 2011
    04-23-2012 08:59 PM #7
    D'oh!
    Im just gpong to start saying "one of the OGs"
  7. Member Fudgey Memory's Avatar
    Oct 26th, 2011
    Charlotte, NC
    2012 Tornado Red Beetle Turbo
    04-24-2012 08:59 AM #8
    Didn't thegreyt do a six speed? I'd love to do that, or a SG, though that might be a tad harder :-)
    “Some say that he’s a CIA experiment that went wrong, and that he only eats cheese. All we know is he’s not the Stig, but he is the Stig’s American Cousin.”
  8. Junior Member Zoolook_'s Avatar
    Mar 17th, 2012
    Brooklyn, NY
    2011 VW Golf 2.5l, 5 sp Manual, 2dr.
    04-24-2012 09:06 AM #9
    4th gear looks like it might squeal a little on the 2010?
    I really like the pull range in 3rd on my 2011 - from 25mph to 75mph it's a really smooth steady acceleration all the way through the revs - perfect for down the ramp onto the highway. More power would always be nice, but I don't usually find myself wanting.
  9. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    1k-m-cbta-02q-PTE5858
    04-24-2012 09:12 AM #10
    Quote Originally Posted by Fudgey Memory View Post
    yup. im a 6spd guy...
    awesome lil transmission! the ratio trully is amazing.
  10. Member
    Jan 16th, 2011
    Chicago burbs
    10' Golf Mk6 2.5 MT
    04-24-2012 01:59 PM #11
    Quote Originally Posted by Zoolook_ View Post
    woulda you mean squeal? 3rd gear is too long even on my 2010. Depending on the on ramp I usually start in 2nd cause 3rd does not always do it in some situations and I am not bone stock. The gap from 2nd to 3rd is already big. I like 3rd to 4th shift as its a small gap and keeps in the engine in its power band better(at those high speeds you want your engine to create max hp) shorter gearing at high speeds is better for acceleration too.
    5 cylinder FTW
  11. Member icon5585's Avatar
    Apr 29th, 2006
    Kansas City, MO
    2011 VW GTI
    04-24-2012 02:08 PM #12
    How would you do a 5th gear swap from a TDI? I do a lot of highway driving and 3-4mpg would be nice
    Sep 30th, 2009
    04-24-2012 05:58 PM #13
    http://www.myturbodiesel.com/1000q/m...ar-swap-VW.htm
  13. Junior Member
    Mar 25th, 2010
    PNW
    2011 Golf , 2000 Golf GLS, 87 GTI (gone)
    04-27-2012 12:14 AM #14
    as an 011 owner, i'm longing for an 10 transmission. The fuel economy is nice, i can hit 36 MPG (measured) with the Carbonio intake.
    However, the 3rd and 4th are to wide, id much prefer the shorter versions....
    (its a grass is greener issue)
  14. Junior Member
    Jul 25th, 2011
    norwalk, ca
    2010 golf 2.5; 2011 Kawasaki Versys
    04-27-2012 12:50 AM #15
    Quote Originally Posted by trickery View Post
    Yes, 2010 owner here. The grass SURE is greener on the other side. The 6 speed side, that is...
    Peter
  15. Member
    Jun 1st, 2002
    YUL
    '01 Wolfie, '08 Rabbit
    05-04-2012 11:33 AM #16
    Quote Originally Posted by Anile_eight View Post
    I'm shopping around for a .717. Firstly where did you buy yours? Also at 75mph how are the revs? Right now with the 08 I'm right at 3000rpm.
    Sent with the information provided from an electronic device.
  16. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    05-04-2012 12:42 PM #17
    Um... Can someone post transmisison gears/rpm and speed data tables I made??
    Just go to my facebook: www.facebook.com/Fred.tamayo
    And search on one of the albums... Copy the url and paste it here.
    Right now I'm on my cel... Can't do that here.
    Sent from my HTC Sensation 4G using Tapatalk 2
  17. Member GTACanuck's Avatar
    Feb 20th, 2009
    08' Rabbit 2.5T
    05-04-2012 01:02 PM #18
  18. Member
    Sep 30th, 2009
    05-04-2012 03:01 PM #19
    Quote Originally Posted by Teknojnky View Post
    From what I recall last time it is around 2650 ish. I know when I was at 75 I was at 3200. It's around a 500-650 rpm drop
    Some good places to look:http://www.advancedautomotion.com/in...f4e0d85019953a
    http://shopping.boraparts.com/produc...roducts_id=326
