Results 1 to 3 of 3
Thread: Fuel issue!
  1. 04-23-2012 02:30 PM #1
    I have an 89 Fox and the fuel pump went out on it last week. Ive replaced the fuel pump with one out of a 93 Fox and all it took was alittle bastardization and re-wiring. I installed it and the pump works however its not pumping any fuel. I know pumps generally work best when there is fluid running through them but how do I get fuel running through the pump? I checked if I wired it wrong and its working correctly. Please help!
    Sep 26th, 2010
    90fox 80scirocco s 76volvo 244dl 90jetta gl 83mb 240d
    04-23-2012 06:23 PM #2
    You need a pump from an 87-90 for cis-(e). A digifant pump will not work as far as I know as a main pump as the fuel rate and pressure differs. Did you check the fuse and fuel pump relay first?
    Apr 16th, 2006
    Brokelyn, NY
    90 fox, 85 gli
    04-24-2012 11:32 PM #3
    Main pumps are not compatible. You also have a pump in the tank as well. Check that one out too
    I really suck at smog.
