VWVortex.com - clutch issues any ideas?
    Results 1 to 11 of 11
    Thread: clutch issues any ideas?
    1. Member --Klutched--'s Avatar
      Sep 20th, 2003
      87 16vt scirocco, 96A4Q
      04-23-2012 04:42 PM #1
      Can any give some advice? Ive done alot of clutches in my life with success however on my rocco i seem to be having issues this is the 2nd one in a row ive done this to. Is it improper installation, faulty clutch or bad driving?
      [IMG][/IMG]
      [IMG][/IMG]
    2. Member --Klutched--'s Avatar
      Sep 20th, 2003
      04-23-2012 05:28 PM #2
      Both were sachs sport clutches.
    3. Member kaltblutig's Avatar
      Jun 26th, 2004
      Grand Rapids MI
      Well, It's a '49, '50, '51, '52, '53, '54, '55, '56 '57, '58' 59' automobile It's a '60, '61, '62, '
      04-23-2012 08:33 PM #3
      Well it looks dry, so you can probably rule out a leaking rear main.
      It doesn't look burned?
      I don't know. I have never seen that before. It looks like the glue let loose and it fell apart.
      Are you especially hard on it? Any reason it would get really hot?
      Are the flywheel and pressure plate smooth or chewed up? It almost looks like someone went at it with a cheese grater.
    4. Member --Klutched--'s Avatar
      Sep 20th, 2003
      04-23-2012 11:24 PM #4
      Both times clutch was replaced with new PP and machined flywheel
    5. Member Smiff's Avatar
      Jan 4th, 2011
      Something about Buckeyes I think
      03 B5.5 4mo wagon
      04-23-2012 11:29 PM #5
      Holy crap, the devastation! I'm inclined to think there's a problem with your flywheel/pressure plate, barring manufacturing defects. This being the second time you're seeing this, I think you should look at your contact surfaces and related assemblies.
      Edit: Just saw your response ^ This is quite a mystery. Balance issue with the crank perhaps?
      Edit #2: All your shims in place? I seem to remember seeing at least one shim the last time I looked at an assembly off the car. I know it's basic, but the devil's in the details sometimes.
    6. Member --Klutched--'s Avatar
      Sep 20th, 2003
      04-23-2012 11:39 PM #6
      I am a little rough on it sometimes but nothing i that should destroy the clutch. whats the torque limit on these clutches?
    7. Member --Klutched--'s Avatar
      Sep 20th, 2003
      04-23-2012 11:53 PM #7
      By shims are you referring to the dowel pins? Crank and rotating assembly is all good.
    8. Member Smiff's Avatar
      Jan 4th, 2011
      03 B5.5 4mo wagon
      04-24-2012 11:18 AM #8
      Nvm on the shims, I've been tearing into too many motors and transmissions here lately, probably thinking of a passat auto trans.
      Aug 14th, 2005
      Germany
      04-24-2012 12:30 PM #9
      I have to assume the picture shows just how it cam off the engine. Look at your own picture real careful. Notice that on the hub there are words printed around it. Notice the ones which say "flywheel side". Your picture shows the flywheel side facing the engine, bad thing to do. But thanks for the pictures I can store in my files.
    10. Member Jones84's Avatar
      Sep 5th, 2007
      Gresham Oregon
      84 GTI 2.0 High comp 16vT on MegaSquirt, 00 Subaru Outback
      04-24-2012 01:15 PM #10
      You put it in basakwards. The plates that hold the disk are bent to hell and just like the one before said, ( read the hub Flywheel side)
      84 Rabbit GTI, 12.1.1 comp 16VT, 15psi 307whp 278wtq Winner 2012 bugRun Pro class
      JONES PERFORMANCE VW, Swaps, Custom Builds, MS install & tuning. MK1, MK2, Specialists
      2vwjones@gmail.com Website under construction.
    11. Member --Klutched--'s Avatar
      Sep 20th, 2003
      04-24-2012 01:15 PM #11
      Ah yes thanks. i was wondering about that.
