VWVortex.com - Always runs better with cold start pulled?
    Results 1 to 7 of 7
    Thread: Always runs better with cold start pulled?
    1. Junior Member
      Sep 22nd, 2004
      Harvard, MA
      2004 VW Golf R32, 2001.5 Audi B5S4, 2003 Honda S2000, 1990 Audi Coupe Quattro, 1990 Audi 90Q20V
      04-23-2012 06:50 PM #1
      A tired 1.6 TD, MF engine number, in an '83 Caddy starts right up with the cold start pulled belching plenty of smoke but even when warmed up seems to run better with cold start pulled( therefore injection timing advanced?). Much more smoke when cold start pushed in. Could this symptom reveal anything else? I know compression is poor.
      Aug 25th, 2009
      Fraser Valley, BC
      1992 Golf gasser to 1.6TD swap , 2002 Jetta TDI
      04-23-2012 08:03 PM #2
      Might just be from wear and tear.
      Sounds like you should just be running your pump more advanced. I'd advance it about a pencil mark and go from there.
      Do you hear much claking/marble when the cold start is out, and your driving it with it out? If not, push in your cold start and advance the timing on the pump just until you start hearing marbles on a plate. Then back the pump off a hair and take it for a spin.
    3. Junior Member
      Sep 22nd, 2004
      Harvard, MA
      04-23-2012 09:53 PM #3
      Quote Originally Posted by steevz View Post
      Thanks for the helpful advice.
    4. Member
      Aug 25th, 2009
      Fraser Valley, BC
      04-24-2012 04:13 PM #4
      No problem. Give an update.
    5. Junior Member
      Sep 22nd, 2004
      Harvard, MA
      04-24-2012 05:53 PM #5
      There's more to my story of better running with cold start. I'd been having all kinds of starting problems that required a lot of jump starting as even with a fully charged battery I couldn't get it to fire. The other day as I was mentally going down my list of possible culprits I saw out of the corner of my eye that the fusible link had burnt through instantly explaining the hard starting. It was after I replaced the link and got the glow plugs glowing that starting wasn't a problem but running without the cold start was. I used to have an old-timer friend who always talked about "driving power into that engine" and now I know what he meant. All those days of unsuccessful cranking had left a lot of unburned fuel in the system making for tougher combustion without advancing the injection timing I'm guessing. Anyway it runs fine now or I should say as fine as it ever did being a tired old smoky 1.6 td out of a Jetta. Thanks to all who replied.
    6. Member
      Mar 31st, 2008
      PNW - Oregon
      04-24-2012 09:11 PM #6
      Quote Originally Posted by moran65 View Post
      if you have access to a timing gauge (dial indicator & adapter) for a bosch VE pump, then you should check your timing. make a note of where it is, and advance it to .95 - 1mm..
      or, if you dont have a timing gauge, draw a pencil line from the injection pump bracket, to the injection pump body, and advance the pump the width of the pencil line.
      that should make it start easier, and have more power, as well as make your smoke go away.
    7. Junior Member
      Sep 22nd, 2004
      Harvard, MA
      04-24-2012 09:28 PM #7
      thanks again -
