Results 1 to 9 of 9
Thread: need some help
  1. Member steakinator's Avatar
    Apr 12th, 2011
    East Stroudsburg Pa
    H22 swapped triple turbo vr6
    04-23-2012 08:35 PM #1
    the inside of my car has smelled like gas for about a month now, yes ive checked the lines, the fuel pump, the obvious, no leaks anywhere, i cant find any reason why it would smell of it, any help would be appreciated.
    99 mk4 vr6
  2. Member steakinator's Avatar
    Apr 12th, 2011
    East Stroudsburg Pa
    04-24-2012 09:56 PM #2
    no one?
    99 mk4 vr6
  3. Member Doctor Meat Does Housecalls's Avatar
    Aug 27th, 2010
    Boston
    Silver MK4 On Orange Rims
    04-24-2012 10:03 PM #3
    The fuel pump is under the rear seat. Maybe the seal on it isn't tight enough?
    IlleststanceGangBang2011|TheThirdReich|DoctorMeatDoesHousecalls|ATEP|WTH:VolkswagenGF2011Survivor|YourPriusIsNotGreen|My Build Thread
    Quote Originally Posted by MurryEB View Post
    Doctor Meat is doing a housecall right now
  4. Member steakinator's Avatar
    Apr 12th, 2011
    East Stroudsburg Pa
    04-24-2012 10:23 PM #4
    i tightened it up already
    99 mk4 vr6
  5. Semi-n00b
    Feb 22nd, 2012
    2001 Wolfsburg Jetta 1.8T
    04-24-2012 10:30 PM #5
    Had this problem but on a different car and found out that the fuel tank neck leaked when fueling up. For a day or two after going to the gas station the cabin would smell like gasoline. The car was a 1997 Firebird.
    I ran my hand under the car and around the inside area of where the fuel door was (took out the rear wheel well cover) and felt gasoline in there. Slower fueling seemed to fix the problem most of the time. It was cheaper then replacing the fuel tank.
  6. Member steakinator's Avatar
    Apr 12th, 2011
    East Stroudsburg Pa
    04-24-2012 11:05 PM #6
    see the funny part is when the fuel level decreases the smell intensifies. But when i top the car off no smell at all its weird.
    99 mk4 vr6
  7. Member steakinator's Avatar
    Apr 12th, 2011
    East Stroudsburg Pa
    04-25-2012 01:39 PM #7
    does anyone know of how the carbon cannister is hooked up? is there any type of purge valve, or anything that would prevent the fumes from being absorbed.
    99 mk4 vr6
  8. Member Jeff_Edison's Avatar
    Jul 29th, 2007
    Rotterdam / The Netherlands
    2002 Volkswagen Golf IV 1.6 16V / 1994 Volkswagen Golf III GTI 2.0 16V
    04-25-2012 02:39 PM #8
    I dont now how you call it, but i searched a translate program, and this came out..
    structure attached to the carter which picks up and accelerates the air flow
    Check the hose's from that..
    If a hose is leaking, then the carter air flow wil come in the interior trough your interior filter..
    *** Jeff Edison -- Golf IV 1.6 16V Sportline -- Golf III GTI 2.0 16V -- The Netherlands -- www.VW-CLUB.nl ***
  9. Member steakinator's Avatar
    Apr 12th, 2011
    East Stroudsburg Pa
    04-27-2012 06:24 PM #9
    thanks guys turned out to be some type of electronic valve on one of the vent lines stuck shut from being old and not allowing fumes to be vented thanks again
    99 mk4 vr6
